Central pneumatic air sander
Review by Jacksdad posted 11-22-2017 02:49 AM 1139 views 0 times favorited 2 comments Add to Favorites Watch
Central pneumatic air sander Central pneumatic air sander No-picture-s Click the pictures to enlarge them
I bought this sander at Harbor Freight for about $30, it works great for sanding bowls. It comes with sandpaper that you should just throw in the garbage, I use the New Wave brand of paper from Woodcraft, it a wave shaped paper so it doesn’t cut grooves in the bowls when it’s working the inside of the bowl. I have a 12 gallon air compressor and it can keep up if i only sand about 3 to 5 minutes. The only problem is the exhaust blows cold air on your hand.
View Jacksdad's profile
Jacksdad
195 posts in 509 days
2 comments so far
View mikeber's profile
mikeber
28 posts in 945 days
#1 posted 11-23-2017 07:43 AM
I was very intrigued by pneumatic ROS. Apperently they are smaller, less bulky and smoother in their performance. Companies that manufacture both electric and pneumatic sanders charge more for the electric tool.
However, two problems make these tools less than ideal.
1) Dust collection. Sanding generates the nestiest dust that sets on everything and while the electric tools come with dust collection, most air pressured ROS don’t. (I heard of only one model that does).
2) The compressor. The electric version consumes anywhere between 1/3 -1/2 HP. But the air pressured requires a compressor of roughly 40-60 gal and 7HP (the size of the space shuttle…)
View Mainiac Matt 's profile
Mainiac Matt
8274 posts in 2413 days
#2 posted 11-23-2017 04:07 PM
That’s an interesting little sander. Looks like a right angle die grinder with a different type of head. Is it a gear reducer? I’ve use sanding discs in a right angle die grinder for metal work and they spin at insane rpm and are a bit difficult to control.
Pneumatic sanders seem to be prevalent in commercial shops, where service air is abundant. My understanding is that they have a lot more power, remove material faster, and don’t burn out.
The only two commercial furniture shops I’ve seen both used pneumatic sanders exclusively.
-- I yam what I yam and that's all what I yam
