Bosch - 82571 10" Sliding compound miter single beve' (Rating: 4)
This saw is discontinued now, replaced by a new model but some stores around me still have a few left on their shelves. I picked mine up for about $360.00, that price for a Bosch slider is pretty good in my books. As with any other miter saw out there dust collection sucks but that is to be expected I guess. It came with a 60 tooth blade that worked great but after its life was up I replaced it with a Freud. The only real problem that this one has is that it is very hard to pull down when you first start a cut because of the blade guard mechanism, as pictured above you can see there is an abrupt angle against the bearing which causes the problem. There is an easy fix to this, I took the metal piece off and rounded over the edge using my belt sander as pictured below, now the saw works without a hitch.
