Dust Deputy
Review by Jim posted 1287 days ago 3538 views 1 time favorited 5 comments Add to Favorites Watch
Dust Deputy Dust Deputy No-picture-s Click the pictures to enlarge them
Multiple reviews already of the $99 Dust Deputy system sold by Oneida – thought I’d throw my two cents in on the $59 version that is just the cyclone sold separately. For the cost of a $5 painter’s bucket from Lowe’s and the time it takes to make a plywood lid, you have the same result as buying the complete kit with arguably a better lid/long term durability.
I routed a groove in the plywood as someone else had suggested and put a layer of weather stripping in the bottom of that groove to help seal the lip. The j-bolts are not really necessary for sealing but they do help in moving the unit by making it easy to just grab it by the lid.
In terms of performance, I couldn’t be happier – I’m without my normal dust collector while we live here in Hawaii and with just a small Ridgid shop vac hooked up it sucks up dust/debris better than the vacuum would/could by itself while keeping the filter and inside of the vacuum free of any dust – very impresive.
For those who bristle at the high cost of a piece of plastic as I did, get over it and just spend the money, you’ll be happy you did… :-)
Jim
-- Jim
View Jim's profile
Jim
34 posts in 2080 days
5 comments so far
View khop's profile
khop
134 posts in 1847 days
#1 posted 1287 days ago
Jim, Good move on buying the DD. I have the metal one with the metal tank/bucket. Like you said, almost no dust in the shop vac. I put an internal bag in the shop vac, now I don’t even need to clean the filter either. I use mine as a centeral vac system. I ran 1-1/2” pvc to multiple spots in the shop and use a long hose for general clean up. I connected the vac to a remote control for $10. The small vac system also works great with my biscuit jointer and Kreg pocket hole jig. No dust or chips to clean up. Congrats, and thanks for the review. KHOP
-- How am I doing? Better than I deserve. Dave Ramsey
View dbhost's profile
dbhost
4748 posts in 1403 days
#2 posted 1287 days ago
How often do you need to empty using a planer? I’d imagine that 5 gallons fills up fast.
87310 posts in 1748 days
#3 posted 1287 days ago
Good review Jim
View Aaron Taylor's profile
Aaron Taylor
37 posts in 1321 days
#4 posted 1287 days ago
Since you make your own lid and all, I wonder if it would be possible to use a larger trashcan or maybe even a 55 gallon drum?!?
Do the instructions list specifications as to what size container you can use with the system?
Just some thoughts.
Aaron
-- "Insanity runs in my family. It practically gallops."--Cary Grant from the movie Arsenic and Old Lace
View Jim's profile
Jim
#5 posted 1287 days ago
Aaron – good thought on the larger can idea; I think the only issue is how well the whole thing is sealed so tha the “smaller” CFM of a shop vac isn’t lost in a 55-gallon drum, otherwise it should work the same. My temporary situation is trying to opearate out of a small work space without my full complement of floor tools and real dust collector that I normally have. This works great for the time being but as dbhost asked above, it necessitates more frequent emptying than my full-size dust collector.
DBHost – you’re right, the bucket fills somewhat quickly but since I’m only using “smaller” tools with it, the pace of fill is tolerable and easy to monitor with a translucent bucket – far better than guessing when the shop vac is full…other than the clue that it isn’t picking up dust anymore!
-- Jim
