my experience with Grizzly g0555Lx
Review by paulsss posted 09-10-2017 05:22 PM 4987 views 0 times favorited 10 comments Add to Favorites Watch
my experience with Grizzly g0555Lx No-picture-s No-picture-s Click the pictures to enlarge them
I purchased the Griazzly and was excited when it arrived and was set-up per instructions. I wanted this model because it ranged 1/8” to 3/4” blades. I do alot of smaller pieces, so having the 1/8” was a large part of making final decision.
That’s when problems started piling up. I could not get the 1/8” blade to track, even after the tech support told me to take sandpaper to a perfectly good tire.
The manual clearly says all calibrations are done at the shop. All I needed to do was adjust the tracking knob. It won’t track. after several attempts to correct the coplanar ( at direction of tech support,) we found 2 small pieces of cast material that had snapped off during the adjustment .The saw was sent back. The saw was returned, set up and appeared to track properly.
I then changed the blade to a 3/16” only to find the next round of issues. The mounting bracket has the wrong dimentions to use the other eccentric bearings. About .080 too large.
No one at grizzly caught this.
To end this, I’ve had multiple parts shipped to me, and had issues every time. It now appears that the final solution has created an issue with the thrust bearing. The mounting bracket won’t allow the enough forward movement properly support the blade from behind. About 1/4” short!
I have nothing good to review here. I would suggest to anyone looking to purchase a quality bandsaw, make sure they provide local service. Grizzly doesn’t. I had to deal with Muncie Pa. Not exactly handy.
I hope to have this resolved shortly…..a boy can dream right?
-- Gizmo
View paulsss's profile
paulsss
1 post in 520 days
10 comments so far
View NormG's profile
NormG
6378 posts in 3239 days
#1 posted 09-10-2017 08:25 PM
Sorry you have had this issue. But I am glad you posted this review. A good friend of mine has ordered one and due to being back ordered, it is due to ship first week of October. I will have to call him now. This is his first new lectric tool he has ever purchased.
-- Norman - I never never make a mistake, I just change the design.
View Bob Kassmeyer's profile
Bob Kassmeyer
230 posts in 3161 days
#2 posted 09-10-2017 09:16 PM
Not my experience, I’ve had mine about ten years and other than replacing guide bearings, which are maintenance items, I don’t think I’ve had any problems. I have not tried using any blades smaller than 1/4 inch though. I have heard they changed plants maybe that’s what is going on.
-- Bob Kassmeyer, Nebraska
View mikeber's profile
mikeber
30 posts in 1096 days
#3 posted 09-11-2017 02:28 AM
Sorry to hear about your experience. I was also considering that bandsaw. In any case, if you have to cut small pieces with a 1/8” blade, maybe one of the 10” small bandsaws are more appropriate.
View TheFridge's profile
TheFridge
10815 posts in 1722 days
#4 posted 09-11-2017 03:47 AM
It should handle an 1/8 blade. I have one of the same models and I had to get a new guide post with my riser kit.
Luck of the draw with Chinese tools.
View Woodmaster1's profile
Woodmaster1
1089 posts in 2823 days
#5 posted 09-12-2017 11:55 PM
I bought the grizzly for my shop at school but it is not top flight quality. Tracking a setting guides are not easy to get right and keeping it set. Students could be some of my issues. I just bought a porter cable 14” from lowes and it turns out to be a great buy better than the grizzly.
View ChipSawdust's profile
ChipSawdust
18 posts in 491 days
#6 posted 09-13-2017 10:16 PM
- TheFridge
Aint that the truth +5
ChipSawdust
#7 posted 09-13-2017 10:18 PM
- mikeber
I have the small Grizzly bandsaw and it works, but the fence is crap, so beware of that. Setup was easy, and you can’t put more than a 3/8” blade on it either. I want a full size band saw but even though I have other Grizzly stuff, it’s like TheFridge said, Chinese stuff is luck of the draw.
View richardchaos's profile
richardchaos
583 posts in 615 days
#8 posted 09-19-2017 12:59 AM
I have the same BS and the same issues. SET UP AT GRIZZLY is laughable! You have to mess with the NON CO-PLANNER! WHEELS. And its very very touchy! I mean a slight tiny adjustment will throw it off front or back!
I doubt its any BAD parts more like BAD adjusting if any at the factory!
Watch this guys advise and go from there!
https://www.youtube.com/watch?v=wGbZqWac0jU
ALSO I have used mine VERY LITTLE and the BEARINGS are already LOAD!
YES I agree with a lot of the others on here about its a crap shoot with these Chinese made tools BUT I thinK Grizzlys are all are in the Philippines.
ALSO with the smaller blades this is maddening. One should ALWAYS Take the pressure off the blade when not in use. AND when you do it will ALWAYS throw the blade off the wheels
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View PlanBWoodworks's profile
PlanBWoodworks
152 posts in 718 days
#9 posted 10-27-2017 12:33 AM
I have the G0555LX. I had one of my lower guide bearings crack and Grizzly made the repair quick and easy. I found their customer service to be top notch. I am sorry for the issues that you are having, but have found that good blades make all the difference. I put a Timberwolf blade on, and haven’t had a single issue since. I hope that you get the resolution that you need. I am very pleased with my machine, but as it is the first bandsaw that I have ever had, my experience is certainly limited. Best of luck to you.
-- Why can’t I ever find my pencil???
View rhett121's profile
rhett121
14 posts in 1548 days
#10 posted 04-08-2018 11:22 PM
I have the same saw and had the same issues with setup and customer service. After all the shipping problems with my router extension wing and then the problems with this bandsaw I changed my mind on getting any more Grizzly tools. I was going to order a cabinet saw but I just can’t be bothered to have to rebuild their crappy products.
