All Replies on RIDGID R4330 Planer Paddle Switch Replacement
View HorizontalMike's profile
by HorizontalMike
posted 11-23-2016 01:31 PM
13 replies so far
View Joe Lyddon's profile
Joe Lyddon
10369 posts in 4290 days
#1 posted 11-23-2016 06:01 PM
Glad you lucked out!!
Do you have your planer working now?
Have a good one!
View toolie's profile
toolie
2148 posts in 2866 days
#2 posted 11-23-2016 06:02 PM
congrats on a creative fix.
TopamaxSurvivor
18423 posts in 3913 days
#3 posted 11-23-2016 07:59 PM
Lucky break, some days you eat the bear, some days the bear eats you ;-)
5236 posts in 2731 days
#4 posted 11-23-2016 08:18 PM
Good deal….
View Druid's profile
Druid
1932 posts in 3033 days
#5 posted 11-23-2016 08:29 PM
Glad that you found such an economical solution, and it even comes with a spare set of contacts. ;)
-- John, British Columbia, Canada
View SignWave's profile
SignWave
452 posts in 3273 days
#6 posted 11-24-2016 12:31 AM
I’m glad that one worked for you.
-- Barry, http://BarrysWorkshop.com/
HorizontalMike
7770 posts in 3151 days
#7 posted 11-24-2016 01:10 AM
Thanks guys! Once I got past the frustrations with the LSA and distance to get service, I figured that I could do it cheaper myself. Especially with the advice from folks like Topomax and others…
We are good to go, and I have now thickness planed all my Claro-Walnut for a new box. FWIW, I spent a few minutes/hours setting up my Incra I-Box for 3/8in. box joints. Looks like I will have a 12” X 6” box when all is said and done. I even made a new zero-clearance insert for the TS just to celebrate!
. 8-)
Everything is running as new. Life is good, even without Jack (in the box ;-) if you know what I mean).
HorizontalMike
#8 posted 11-24-2016 01:11 AM
- Druid
You know,... I wasn’t even thinking about that, HOWEVER, you may be right! I guess it all depends on how bad the “next” burnout is, assuming that there is one! Great idea!
TopamaxSurvivor
#9 posted 11-24-2016 03:05 AM
Make sure the spade connectors make good, tight contact and there probably won’t be another burn out.
HorizontalMike
#10 posted 11-24-2016 11:17 AM
Make sure the spade connectors make good, tight contact and there probably won t be another burn out.
- TopamaxSurvivor
You bet. I replaced the burnt spade connector with a new one. The others were fine. Plus, I bought a second switch as a backup, just in case… ;-)
Happy Turkey Day folks!
TopamaxSurvivor
#11 posted 11-26-2016 06:47 AM
I don’t like those slip on connectors for anything but light, low voltage connections. On motor or power circuits, the heat and cool cycles cause metal fatigue and loosening over time which leads a totally unnecessary failure. The heat from the deteriorating connection usually kills the device it is attached to. I saw this quite a few times on the multi-circuit emergency generator transfer switches used for 6 or 8 residential circuits. I can’t believe UL approved them.
View kowwpokey's profile
kowwpokey
2 posts in 960 days
#12 posted 05-12-2018 11:13 PM
I have the same problem so I appreciate the link for the part, but how does the old switch come out?
-- I've cut this board three times and it's still too short...
HorizontalMike
#13 posted 05-16-2018 05:24 PM
- kowwpokey
Look at the right hand image and notice the plastic clip on each end. It take a little finagling, but I ‘m sure you’ll get figured out. As I recall, I had to take off the left side cover in order to have access to the back of the switch. Good luck!
