All Replies on Why end grain butcher blocks?
View socrbent's profile
by socrbent
posted 05-02-2012 04:33 AM
19 replies so far
View AttainableApex's profile
AttainableApex
347 posts in 2708 days
#1 posted 05-02-2012 04:39 AM
its like taking a butch of toothpicks tips up, put a knife in it and nothing really happens, it will still stay together.
but put the tips horizontal (face grain) and you start cutting the wood and making splinters
-- Ben L
View Doss's profile
Doss
779 posts in 2140 days
#2 posted 05-02-2012 05:10 AM
Much like Ben is saying, the wood fibers are more resilient in an end grain board against the chopping motion of the knife. Also, this style is somewhat easier on the blades (keeps them sharper longer) than something like an edge grain alignment.
Another comparison besides the toothpicks or skewers I’ve heard is that of cutting the bristles on a brush. If you try and cut the bristles by chopping from end (the part that touches your head) to end (the part that secures the bristles to the handle), you’re not going to do very much damage. But, if you try to cut across the bristles, you will cut them in half a lot easier.
Of course, you can use edge grain or any pattern you wish and the type of wood does make a difference, but end grain is the better known style for blade life longevity and will almost always be preferred because of that.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3058 days
#3 posted 05-02-2012 05:11 AM
End grain is easier on the knife’s cutting edge. When you cut into a board that is face grain the knife marks will remain and not heal as they will on end grain boards.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View eddie's profile
eddie
8565 posts in 2489 days
#4 posted 05-02-2012 05:17 AM
hay socrbent here’s a good link on the blocks hes a good teacher and goes into a lot of detail
http://www.youtube.com/watch?v=5B8oAJs3sik
-- Jesus Is Alright with me
View FirehouseWoodworking's profile (online now)
703 posts in 3148 days
#5 posted 05-02-2012 03:42 PM
What everyone above has said with respect to the knives. But there is a more practical reason with respect to safety.
If your butcher block was such that the surface was edge or face grain, as you run a nice along its length, you are essentially carving away slivers of wood that eventually become embedded in whatever food product it is you are cutting. And by extension, those slivers could later become embedded in your throat or digestive tract. Not a very appealing choice.
Hence, with end grain, the most you cut away is “saw dust” which can be passed through your digestive system without harm.
Cheers!
-- Dave; Lansing, Kansas
View Charlie's profile
Charlie
1100 posts in 2161 days
#6 posted 05-02-2012 04:09 PM
I thought slivers were a good source of fiber in the diet! :)
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2230 days
#7 posted 05-02-2012 04:13 PM
I have a totally different view on this, and why you shouldn’t use end grain. End grain can absorb fluids, and bacteria if not properly finished, as well as split easier, you don’t split a log on the face grain, you split it on the end grain.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Doss's profile
Doss
#8 posted 05-02-2012 04:40 PM
TCCabinetmaker, the force applied in log splitting is far greater and in longer duration than that of a knife. Not only that, the knife’s wedge shape is far narrower than a log splitter. The log splitter is designed to separate and displace the wood. A knife is designed to cut through with little displacement (it is more efficient to cut this way). Because of this, the wood “heals” when using end grain.
Cutting boards are supposed to be made of dense hardwoods similar in characteristics to maple. Your theory on bacteria growth in end grain has been studied and found to be untrue (at least in this research: http://faculty.vetmed.ucdavis.edu/faculty/docliver/Research/cuttingboard.htm). The USFDA actually recommends end grain cutting boards for restaurants.
The bacteria actually dies with failure to reproduce as it enters the end grain. In any case, you should properly disinfect any cutting boards after use.
View pintodeluxe's profile
pintodeluxe
5545 posts in 2689 days
#9 posted 05-02-2012 04:43 PM
end grain cutting boards are not better for planer knives though.
View crank49's profile
crank49
4028 posts in 2846 days
#10 posted 05-02-2012 05:47 PM
My wife’s uncle was a butcher. He had to switch from wood cutting blocks to plastic because of health and safety requirements. This was about 25 years ago. Has the requirement for plastic cutting boards been changed?
I’m not saying they haven’t, I just would like to know.
View Doss's profile
Doss
#11 posted 05-02-2012 06:28 PM
In my link above, please remove the “)” from the end. It will cause a linking error if it isn’t.
I am not aware of any requirement that says you can only use plastic. That doesn’t mean one doesn’t exist; I’m just not aware of it.
socrbent
571 posts in 2145 days
#12 posted 05-03-2012 01:15 AM
Thanks for the enlightenment. This now makes sense
-- socrbent Ohio
View oluf's profile
oluf
260 posts in 2914 days
#13 posted 05-03-2012 02:20 AM
The butcher blocks that I cut meat on years ago were three feet thick. We cleaned them by scraping off the top surface. As the blocks wore down , blocks were placed under the legs to get them back to a comfortable working height again. I don’t beleve that those blocks are allowed any more in the prosessing of food for trade.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View MrRon's profile
MrRon
4568 posts in 3119 days
#14 posted 05-03-2012 04:11 PM
End grain butcher blocks stay flat. Face grain wil absorb fluids/bacteria just as well as end grain. Most Chinese restaurants still use wood cutting boards. Butcher blocks were used for “chopping”. Bandsaws now replace chopping in processing plants.
View JPA's profile
JPA
2 posts in 2146 days
#15 posted 05-07-2012 06:08 PM
Crank49….The FDA didn’t do us any favors by requiring the use of plastic cutting boards in the meat processing industry. They acted under the false assumption that plastic is more sanitary than wood. In fact, the opposite is true. Bacteria is absorbed deep into the wood grain where it either dies or is trapped far enough from the surface to have any effect on the food being processed. Plastic, on the other hand, is impermeable and holds the bacteria at the surface where it can grow and thrive. Wood surfaces are “self-healing” whereas the cuts made in plastic are permanent scars which, as they accrue and become deeper, become harder to clean and must be discarded after a relatively short life time. Wood, if treated properly, can last for generations.
-- Heirloom Quality wood products for the kitchen and dining room at below factory prices.
View moineau's profile
moineau
2 posts in 695 days
#16 posted 02-27-2016 02:44 PM
End grain will ALWAYS be safer than edge or face grain… what’s my “non scientific” proof…
Simply look at the amount of mineral oil absorption the next day between an edge or face grain versus end grain board.
Recently I had some end grain butcher blocks and a few serving trays coated with mineral oil. When I checked “several days” later the face grain boards still had the original oil layer on it’s surface. The end grain boards absorbed the oil within hours. In one end grain board the wood was so thirsty, some cherry and maple pieces were so absorbent that by the time I put oil at the other end of the board, the first part was dry already (or technically absorbed).
Front:
https://www.flickr.com/photos/140520949@N02/shares/E81C2x
Back:
https://www.flickr.com/photos/140520949@N02/shares/xM4S60
(lemmee know if pix don’t show, I’m a neophyte…)
Yes, due to porosity and density of the wood… you will varying degrees of oil on the surface. But this still shows the degree of absorption is vastly different between the grain types.
Just to complete this old discussion, in one check of a completely cherry end grain board, I turned over the board after leaving the oil on it for no more than 10-15 min to oil that side and TAA-DAAA! some of the oil had already been absorbed through a 1.5” board in various spots all over the board.
NOTE: bacteria will not pass through due to it’s physical characteristics; it might eventually get through alive (though I doubt it) but not likely due to the wood fibers and lack of food for bacteria in mid wood bacteria dies.
Here’s the only university study showing wood is the same or better than plastic cutting boards:
Title of document: PLASTIC AND WOODEN CUTTING BOARDS
Provided by: UC Davis institute
socrbent
#17 posted 02-27-2016 02:57 PM
Thanks moineau.
-- socrbent Ohio
View Mojo1's profile
Mojo1
261 posts in 2566 days
#18 posted 04-30-2016 01:03 PM
They look great too!
View Aj2's profile (online now)
Aj2
1230 posts in 1673 days
#19 posted 05-01-2016 01:36 AM
I know this is a old thread.I guess I learned something new.End grain cutting I’ve made were to help keep the knife edge keen.Since it would be slicing down between the wood fibers instead of cutting across.
Never even considered the bacteria side to it.
-- Aj
