Reply by EarlS
Posted on Minwax Polycrylic
View EarlS's profile
EarlS
1899 posts in 2546 days
#1 posted 01-06-2012 04:39 AM
I’ve refinished the same tabletop 4 times because the 600 grit Abranet scratches from the random orbit sander keep coming through. I finally resigned myself to using 800 grit wet sand paper on a block going with the grain end-to-end. I think it is working but it is building very slow which is OK since the thinner coats also dry pretty fast and keep the dust nibs down. If I ever get the top finished out I will post the table on Projects.
