Aquarium stand with Peruvian walnut
Project by RS Woodworks posted 06-10-2012 05:21 PM 3910 views 2 times favorited 2 comments Add to Favorites Watch
I may have mentioned in the past that one of my other hobbies is fish keeping. Specifically, two species of African cichlids. I keep Cyphotilapia Gibberosa (Frontosa) from the Mpimbwe region of lake Tanganyika in a 180 gallon tank, and in this new 75 gallon tank I keep Tropheus Moorii red from the Kachese region of the same lake.
I build this stand and designed it with several key features. First and foremost, it has to be strong. A 75 gallon tank filled with sand and water weighs almost 800 pounds. The substructure is made of 2×6 fir vertical posts and 3 layers of 1/2” baltic birch plywood to make the cross beams. I used 5/8” dark cherry melamine to face the structure, and then solid Peruvian walnut to edge the melamine, add trim, and make solid frame doors.
I decided to try some power carving on this project as previously suggested to me by Rob Brown. I wanted a simple design that reflects the waves of water as well as the shapes of fish, depending on your interpretation. The power carving was easily done with 60 grit paper on my random orbit sander. The Peruvian walnut is quite soft, so it went quickly. The trim is not thick so I didn’t have to remove much material. I ensured that the lines carried over from the doors to the trim of the stand.
Thanks for looking and as always, I look forward to your comments, critique, and questions!
-- I restore the finest vintage tools! If you need a nice plane, saw, marking tool or brace, please let me know!
2 comments so far
View Jim Jakosh's profile
Jim Jakosh
20918 posts in 3188 days
#1 posted 06-10-2012 06:17 PM
That is a very neat looking stand- it looks so rich. Nice job!!....................Jim
I like the idea of the power carving with the orbital sander!!
View RS Woodworks's profile
RS Woodworks
533 posts in 3334 days
#2 posted 06-12-2012 12:07 AM
Thanks Jim. On harder wood or if doing much more carving, you would need something more agressive than the ROS, but for this project, it seemed to work just fine for me.
