| Project by woodreamer | posted 551 days ago | 838 views | 1 time favorited | 5 comments | ![]() |
This was a project that was an experiment that sort of went wrong. I tried for the first time to take a scrolled inlay pattern, then fill it in with polymer clay and bake according to the instructions. At first I was very pleased with the results, then I looked closely. Yikes! The lid now has a serious amount of cupping (last photo). Thinking about it later, I realized that heat removes moisture quickly which makes wood do strange things. I’m trying to think how I can straighten it out. Of course the topic of warping is as old as woodworking itself. The method i’ve tried before, with moderate success is wetting the concave or cupped side, then applying gentle heat, such as a hair dryer. Unfortunately, i laminated a thin piece of basswood to the underside of the lid to hide the rough underside of the design, so the glue would prevent the added moisture to penetrate the cupped side (I suppose I could simply remove the basswood by sanding), but a less destructive way would be preferable.
Anyways, any thoughts,opinions or suggestions are welcome.
Thanks,
Woodreamer
-- Bob, BC, Canada http://www.etsy.com/shop/abby702
| Pin It |
5 comments so far
Ken90712
home | projects | blog
12662 posts in 1358 days
#1 posted 551 days ago
Wow, sorry to hear that this happened. Hope you can save it. The lines and inlay look great.
Eagle1
2044 posts in 1234 days
#2 posted 551 days ago
Sorry that happened tp you. Such a beautiful box. Can’t you just make another lid.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
shipwright
3392 posts in 968 days
#3 posted 551 days ago
When you laminate something on one side like that you should always laminate something similar on the other side as well. This is a very important rule in veneering and it applies here as well. that’s likely your biggest problem. I think sanding it off would be the best plan.
All that aside, Nice box ! I hope you can fix the top.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
woodreamer
61 posts in 863 days
#4 posted 551 days ago
Thanks all for your comments. The more I think of it , I’ll probably suck it up and just make another lid with conventional inlay technique. Harsh lesson.
thanks,
Woodra
deon
1181 posts in 1195 days
#5 posted 550 days ago
If you cannot add moisture to the bottom you could try to take it out of the top in order to recreate the ballance…..
-- Dreaming patterns
