Boat bookcase for Nicky
Project by AJ1104 posted 08-30-2017 12:56 AM 1095 views 4 times favorited 9 comments Add to Favorites Watch
This spring my wife spotted a boat bookcase at a local store and thought it would make a great project to give to our grandson, Nicky. I was inspired from a fellow LJ rwingnut’s project in 2014.
I used 1/2” birch ply for the back and shelves. The bullnose for the shelves are poplar. I followed rwingnut’s idea for the sides and used 1/4 birch ply relief-cut every inch. Some of the cuts seemed visible so I added a single sheet of 1/8” to the outside before I dyed and finished in poly.
I began by laying out the overall size in sketchup. I cut the dados first and then cut the shape out of the plywood. Next glue in the shelves and brad nailed them from behind. Each of the shelves had to be bevel cut to match the curved shape of the hull. The shelves and the base formed the structure to glue and pin the first layer of ply on the sides. The outer layers of ply were veneer layered on top.
The gunwales are made of sapele that were glued 3/16” strips and formed to match the shape. I felt the sapele gave it a genuine nautical look.
I made a template from the hull on plywood and made a bending jig. (I learned that from inlay cutting boards) I had a problem with the gunwale angles. They ended up a bit shallow in width so I needed to add two layers after the inital glue-up to make them look the way I had envisioned it. The gunwales were screwed and plugged.
I did not dye the sapele, just several coats of wipe on poly.
I always want to thank all of LJ’s for the inspiration for so many of the projects I build. This is an amazing site filled with amazing artists and craftsman.
All and all it was a very rewarding project as you can see, my reward is the picture of him and his boat which is now filled with books to read! I hope all of you are having a wonderful summer! AJ
-- AJ
9 comments so far
View BurlyBob's profile
BurlyBob
6032 posts in 2505 days
#1 posted 08-30-2017 03:40 AM
That’s really fantastic!
View Woodwrecker's profile
Woodwrecker
4211 posts in 3815 days
#2 posted 08-30-2017 05:07 AM
Nice work brother.
That boat-bookcase came out great!
View cmmyakman's profile
cmmyakman
214 posts in 2896 days
#3 posted 08-30-2017 01:08 PM
Very impressive build! You did an outstanding job!
-- You can't fail if you don't give up.
View helluvawreck's profile
helluvawreck
32086 posts in 3106 days
#4 posted 08-30-2017 03:13 PM
I love these boat bookcases and this is a very nice one.
helluvawreck aka Charles
View WayneC's profile
WayneC
13800 posts in 4337 days
#5 posted 08-30-2017 03:27 PM
Awesome work. A heirloom piece.
View AJ1104's profile
AJ1104
662 posts in 1899 days
#6 posted 08-30-2017 03:28 PM
Thank you very much for the comments! It was a lot of fun to build. I saved the templates for another when the time comes.
-- AJ
View ralbuck's profile
ralbuck
5543 posts in 2506 days
#7 posted 08-30-2017 04:23 PM
Very well designed and executed too.
-- Wood rescue is good for the environment and me! just rjR
View gargey's profile
gargey
1013 posts in 1015 days
#8 posted 08-30-2017 06:33 PM
Nice job
View oldnovice's profile
oldnovice
7380 posts in 3607 days
#9 posted 08-30-2017 06:35 PM
Outstanding project with some one special in mind.
The results show that you didn’t take any shortcuts!
