for years ( 45 ) i have been using the jointer , and from day 1 , my shop master ( Lincoln Morinaga ) said
that this tool was the most dangerous in the shop . in my work , i often have to joint 12’ boards or longer .
with or without a helper , this is a tedious and risky task , as you have to force the board down with lots of pressure,
to counteract the forces of gravity and increasing outboard sagging .
my thoughts , have allways led me to using gravity in my favor , and letting my ” fingers do the walking ” !
first i want to thank you topamax , for answering my electrical questions about the switch and motor 220 v
without frying everything in the middle of the night .
line =In = power from electric panel .load = out =from switch to motor . you were there bud , thank you .
so here is my solution :
this is my chopsaw table , the motor for jointer has been mounted on the wall,
on hinged board , for belt tightening
i wanted kent to come and do this , but didnt have any bubinga to work with !
this is the inside of motor cover box and base for jointer to mount to.
with vacumn tube to isolate jointer from motor .
the 2 holes are for take apart belt from motor to jointer .
thanks for looking , and work safe !
and 3 bolt mounting holes for jointer .
box and jointer mounted . this platform is 6” higher than chopsaw table .
i needed to have room under the jointer to still use the rail ,
and adjustable stops for chopsaw . when platform is removed .
these registry holes 3 in fence and 2 in table ,one set either side of
jointer table .
correspond with dowels in bottom of jointer platform .
i slide platform along back rail until 1/4” dowels register ,
and drop down into 3/4” holes in table .
this way platform doesn’t move , and it cant tilt ,
because back dowels are holding it down .
platform in place
far end of table and registry mode . i still wanted to use the chopsaw to cut up to 3 1/2” behind platform,
so it was different atachment .
underside of far platform and “hooks” and dowels .
here i slide platform until “hooks” drop in holes ,
and slide back until “hooks” are grabbing table and drop down
in corresponding dowel holes , it cant move or tilt either .
platform in place , with space to use chopsaw still .
platform with dowel pins to fill space in front of chopsaw .
and in place .
infeed side attachement detail .
infeed platform in place , with folding leg ,
over all it is 18” long ! and it all breaks down for wall storage !
just 1 old guy working alone !
i just made this , i will get a guard soon !
finished jointer and first edge !
as soon as i get back from denver and see bibb about rosewoods and his wood ,
i will get a spiral cutter head from grizzly for this and feel better about jointing long boards ,
i still have a delta DJ20 long bed jointer on the floor for regular edjeing and face jointing
26 comments so far
Craftsman on the lake
home | projects | blog
891 posts in 409 days
posted 220 days ago
This is a cool idea and really extends the use of the jointer for you. Those exposed spinning knives scare me though. Please be careful. You couldn’t still have the protection swivel plate on?
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
degoose
2520 posts in 326 days
posted 220 days ago
Really outside the box my man.
-- Drink once, cut twice. @ lazylarrywoodworks.com.au
3317 posts in 312 days
posted 220 days ago
can;t find the plate ,
will get one from grizzley soon ,
or make one ,
again gravity will help with that .
PurpLev
3440 posts in 619 days
posted 220 days ago
thats a great idea for edge jointing!
But for face jointing this seems a bit risky as you have to put a TON of pressure against the jointer bed whereas in normal operating position gravity would help a bit. and those exposed spinning cutting metals also would freak me out too.
you should really talk to Kent about replacing this with Tiger Maple and Ebony though ;)
James
160 posts in 252 days
posted 220 days ago
good details and idea my friend, now you are having fun in the shop too
-- James, Bluffton, IN
posted 220 days ago
thanks purp,
i got a 8” long bed jointer for face work !
this one is striktly for edging .
PurpLev
posted 220 days ago
that makes more sense patron… excellent idea…
Don K.
1093 posts in 297 days
posted 220 days ago
Wow….when I first saw the picture I was like “What the heck..is he holding the camera sideways” Lol….man thats some “Creative” thinking for sure…but very nice !!!...but like already said, be careful with those blades until you get a guard.
-- Don S.E. OK
28894 posts in 1371 days
posted 220 days ago
Never thought of mounting a jointer on it’s side. I’ve got an old sears 6” guy. Thay could be used for that purpose.
A cool idea.
Woodwrecker
675 posts in 546 days
posted 220 days ago
Outside the box is putting it mildly, but with the results you’ve displayed in your work, I’m with you Patron.
I’m glad I’ve subscribed to your blog. I’ve learned a lot already.
Mind those fingers my friend.
-- Eric
bowyer
341 posts in 367 days
posted 220 days ago
All this time we thought you were just another pretty face!!!!!!!! Very smart work around for those long boards you plane.
Rick
-- If at first you don't succeed...Don't try skydiving
posted 220 days ago
still got all 10 ,
and im almost as pretty as the guy in the mirror !
23636 posts in 548 days
posted 220 days ago
Hey David
This set up would work really well in a weight less atmosphere did you steal this idea from NASA. LOL
This is one original Idea guy well done .
-- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, http://www.heirloomwoodshop.com/
spanky46
775 posts in 361 days
posted 220 days ago
Your brain works different than the rest of us! That is meant as a complement Patron!
Nice job but get that guard on ASAP. Your students (we lumberjocks) can’t afford to have you MIA!
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
moshel
497 posts in 655 days
posted 220 days ago
Thats a very clever idea! i wish i had a spare jointer :-)
seriously, my only near accident so far was with edge jointing big board (for my rustic outdoor table). luckily, my hand touched the part of the jointer arbor that had no knives. could have been much worse, just got a scratch. with this setup it would have been a much simpler procedure. you just can’t maneuver 30kg board on your own and stay safe. also, i bet you will get much cleaner edges, as the jointer fences are not that wide and the long heavy board wobble.
-- The woods are lovely, dark and deep, but I have promises to keep...
posted 220 days ago
thats what i’ve been thinking all these years ,i was going to get a spiral cutter , but coudn’t find a way to mount it ,
and the fence paralell was to much of a problem, i went and looked at the 6” benchtops , then i remembered that i had a grizzly out on the porch i had bought for an indian friend of mine ,well he died , and his wife sold it back to me.
and when i built my house i didn’t have the room for it . i plan on getting a spiral cutter for this one , and a guard too for now i am trying to find a 1/4” nut to complete the wood guard .
wish me luck , it could take all weekend to find it !
posted 220 days ago
i just made this , and will get some parts needed soon !
jimp
160 posts in 732 days
posted 219 days ago
This is a great idea. I was wondering if you were able to change the position of the support table or jointer, so you are about to use a different spot on the blades once one area of the blades gets dull?
-- - Jim, Vancouver,WA
woodpeckerbill
43 posts in 244 days
posted 217 days ago
David, that’s a great job! You are the LJ innovator!! Glad you still have all 10 digits… But I just saw the man in the mirror and you ain’t that purrty!! Bill
SCOTSMAN
2330 posts in 556 days
posted 217 days ago
Patron my dear friend I have never seen this design of planer or jointer as you call them before I wish you well but please play safe.kindest regards Alistair
posted 217 days ago
thats the idea ,
i still hope to have another 45 years ,
so i can get serious about
woodworking !
thank you all ,
you be safe too !
Kent Shepherd
1170 posts in 257 days
posted 209 days ago
David, I just ran across this. Very unique idea. I can see the advantage to doing this, although my first impression was it is scary looking. I guess it almost makes a shaper out of it.
Maybe I need to bring you some Bubinga. New Mexico is not that far from here.
(Another 45 years——Whoa, I’m tired just thinking about that!!!!!!!!!!!)
ccarse
5 posts in 224 days
posted 207 days ago
I think this problem is what inspired the uniplane.
http://www.owwm.com/photoindex/detail.aspx?id=209
posted 207 days ago
ccarse . although i never got to use one ,
i remember wanting one ,
when their came out .
then they just disapeared ?
my system is just for long and heavy boards ,
as normal jointing is still done one my 8” DJ 20 .
stefang
2614 posts in 305 days
posted 169 days ago
A great idea. I’m glad I’m not working such big stock, but that sure looks like a great solution for edge jointing.
-- Mike, American in Norway - Do it the fun way
Durnik150
549 posts in 293 days
posted 169 days ago
Amazing ingenuity Patron!! Neccessity is truly the mother of Invention. Just goes to show you how creative woodworkers can be when they have to get around a problem.
Great work!
-- Behind the Bark is a lot of Heartwood----Charles, Centennial, CO
