part 2 - helping SPalm blog along - Moser End Tables Assembly
Blog entry by patron posted 03-12-2015 08:24 PM 1743 reads 0 times favorited 9 comments Add to Favorites Watch
sorry to take so long steve
this went to my spam file
i just found it
Well I doweled the legs to the sticks and beams. I went with a single half inch dowel that was six inches long. I don’t like it because the legs can rotate except for being held in place by the lower stretcher sticks. I hope it is strong. Maybe next time I will make square tenons on the top of the legs.
I started by drilling the beams from inside the mortise. I spent a bit of time and made sure my drill press was drilling straight (it wasn’t). I drilled all the way through. These will then become my drill guides for drilling the legs.
I then clamped a set of legs on the bench. I made sure everything was square and made a temporary stretcher to keep the spread correct. Then pressed the beam onto the legs and drilled through my “guide”. I repeated this for the sticks too. Every hole was numbered to keep it straight.
Then mortised the legs for the bottom stretchers. The blue tape markers are on the edges that are square to the floor. They end up on the inside corners. It is really easy to get mixed up with which edge is which.
I beveled the ends of the beams and sticks.
This is how the frame looks with all the cutting done. I like it.
Then I cleaned up the top and squared the ends. I beveled the sides of the top with a chamfer bit in the router table, but the largest bit I have did not remove enough. I would like the flat portion to only be a quarter inch or so. Maybe I will get a bigger bit, just leave it, or bevel it on the table saw.
So here it is. No scraping or sanding, or finish applied. The plan is to attach the top with screws through the beams.
Thanks for riding along,
Steve
edit later
here is part one of this blog
http://lumberjocks.com/patron/blog/52106
9 comments so far
13623 posts in 3424 days
#1 posted 03-12-2015 08:31 PM
it could be your i-phone or i-pad steve
i notice that some won’t send pics right or let them be cropped either
they come out sideways or so large that you cant even see them right
maybe that messes with the bandwidth or MGB thing
i’m no brain surgeon either
i do know this table looks great
View Lenny's profile
Lenny
1608 posts in 3610 days
#2 posted 03-12-2015 08:38 PM
Continues to look great Steve. In my opinion your concern about the dowels and also the tables’ overall strength (Is it enough?) is not necessary. I have faith in today’s glues, you make nice tight joints, dowels DO work and were our “go to” means of joinery for years, and lastly, they are end tables. As such, I can’t imagine you, your wife and others will place excessive weight or stress on them. Of course, there’s always that relative, chld or otherwise, who will want to sit on one!
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
#3 posted 03-12-2015 08:43 PM
before driving the dowels
i have run the ends into the band saw for a little bit
then put a small wedge into the bottom end
(if it is blind there)
and drive it in
and drive another small wedge into the top
it makes it into a ‘rivet’ to some degree
you try to have the wedge run across the wood grain
so it tightens to the end grains
instead of splitting the parts
but sometimes they spin in the drilled hole slightly
from the drill spiral
or you could drive a small chisel after you flush them
and do the wedge thing then
View SPalm's profile
SPalm
5321 posts in 3965 days
#4 posted 03-12-2015 10:28 PM
Thanks guys, I need to think about that wedge in the dowel thing.
Or like you say it it just an end table.
Steve
-- -- I'm no rocket surgeon
View BigRedKnothead's profile
BigRedKnothead
8524 posts in 2065 days
#5 posted 03-12-2015 11:40 PM
I’ve been wondering why I can’t click on your blogs with the link in my emails Steve. Hope they get it fixed.
I love Moser’s stuff too. Sweet build already.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View stefang's profile
stefang
15881 posts in 3417 days
#6 posted 03-13-2015 10:26 AM
Looks great Steve and you got some really tight beautiful joints. Your work is so meticulous. A great example for us all.
View JL7's profile
JL7
8676 posts in 3048 days
#7 posted 03-14-2015 07:23 PM
Looking good!
-- Jeff .... Minnesota, USA
View mafe's profile
mafe
11740 posts in 3172 days
#8 posted 03-14-2015 09:39 PM
Looks really good, nice thinking and rational use of jigs.
Lovely to see the process.
Best thoughts,
Mads
24135 posts in 3934 days
#9 posted 03-21-2015 12:22 AM
Great blog David.
