stop/look/listen
Blog entry by patron posted 06-28-2014 02:36 AM 2337 reads 0 times favorited 30 comments Add to Favorites Watch
a number of years ago (maybe 15 – 16)
i knew a navajo man that supported his family
by cutting firewood for some of the indian ceremonies
he would get in his truck and go out into the washes and canyons
around gallup new mexico and adjoining arizona
and cut down dead cottonwood and oak trees
some up to 1’+ diameter trunks into logs around 5’ long
take them home and standing on them over a few cross logs
(for chain clearance) he ripped them with his chainsaw
into (i kid you not) 2”x2” firewood strips
and would sell a whole pick-up load for around $100
robert did me a few favors over the years
and when i saw this operation
i determined to get him some help
as he was now in his 70’s and still cutting wood this way
things were good for me then
i had a beautiful home and a 30’x60’ shop
and was doing fine (i even had a wife)
i bought him a 16” grizzly band saw
model g1073 and 6 – 1/2” blades for $900
a cast iron brute that could do the work he needed
to be able to re-saw those logs with
since he did have a home with power and a big ramada shed roof
to work under he was estatic when i brought it to him
all brand new and in boxes ready to asemble
which i would do when he had the time
to add a 220v line to his electric panel (10’ away)
so i could show him how to use it
he had come to my home at times for ceremonies
and seen how i used mine to do that
his jaw dropped watching how simple it really was
(this was freehand ripping not making wood lumber)
anyway as time went on
i lost my home /shop/wife
he passed on
when i called his wife to offer my condolences
she mentioned the band saw
still in the crates in the shed
said some had offered her $50 for it
i went and got it and gave her $200
and brought it back here to my then small beginner home
as my ‘living room’ was stuffed with all my own tools already
i had to leave it outside under a tarp
well the years took the tarp and any thing i used to cover it with
the boxes eventually rotted
and it sat for years in the weather rusting
when i built a covered deck
i did bring most of the parts under there
but the tool body sat where it was
and to my surprize one of the boxes was a 6” grizzly long bed jointer ?
someone a grizz must have added that by mistake to my order
so here is what i did with the jointer this is not an ad
since i now have a new shop with a sealed roof
i have started to load all the machinery there
and brought this band saw in too
what a friggin mess !
mouse houses and poop all thru-out
rust galore covered with cobwebs
as i had all the parts for it
i began to assemble the best i could
no manual or instructions survived the years
the plate on it was so faded i couldn’t even read what model it was
but i assembled the stand with logic
and having separated all the bagged screws/nuts/bolts and parts
counting bolts and holes for them got easier as i went along
got it on the stand loosely and as i had a rope pulley laying there
hooked it to a rafter and hoisted it upright
now for the hammer and some oil to get things loosened up some
to see if it might work at all
took most operating thing apart and oiled them and put them back on
the rubber tire was broken and lose on the bottom wheel
so i put some rubber glue on it and put it on again
but found that it had shortened up by about 1 1/2”
cutting a rubber inner tube into a 7/8” strip
and layering 3 pieces in the gap
i put a blade on it and spun the wheel a half turn and left it overnight
with the blade holding things tight as the glue dried
with the table and guide bearings on
and a 220v extension cord i made for temp use
i turned it on to see how it might work
the belt jumped of the pulley
so move the top and the motor bracket
and look down the belt till it looked right
tried again – IT WORKED !
so i cut a board to test it
and this with a rusty fine tooth blade
(at that time i didn’t know about re-saw blades)
my point in this post is that even without the manuals or fancy set-up tools
(that night i went out with an led flashlight and a magnifying glass
and got the model# and came in a googled grizzly manuals
got the right one now)
STOP/LOOK/LISTEN will do most of what you need
if something looks funny fix it
if it sounds funny check it out and fix it
you don’t need a starret $400 laser micro feeler guage
to set the tool to 1/1000”
common sense will help for most shop needs
and a good hammer
30 comments so far
View Napaman's profile
Napaman
5526 posts in 4223 days
#1 posted 06-28-2014 02:54 AM
Beautiful story! I think it is so cool that you bought him this gift…and then bought it back to help his wife. ..great save. Good lesson…I hope this tool brings many good years of service. I have this feeling this tool will be a part of ssome great gift or project!
-- Matt--Proud LJ since 2007
View DIYaholic's profile
DIYaholic
19657 posts in 2821 days
#2 posted 06-28-2014 03:00 AM
What a fantastic story of perseverance…. The saw’s that is!
What a fantastic story of determination… Yours!!
What a fantastic story of….
“What comes around…. Goes around!!!
13630 posts in 3487 days
#3 posted 06-28-2014 03:02 AM
thanks matt
now have 2 16” bandsaws
will use this one for re-sawing
when i get some good blades for it
and build some kind of long table
to hold the logs
i have 2 – 8”x8’ and 2 – 4’ and 1 – 3’ ones
black walnut to plank out
never done that before
#4 posted 06-28-2014 03:07 AM
hey dad
thanks for all your encouragement
i will be gone all week end
so if you or someone else
wants to shine this saw up
while i’m gone
rest assured
the rust is all yours
DIYaholic
#5 posted 06-28-2014 03:18 AM
So….
What is the model number of this relic???
I would gladly shine up your saw….
However, I have a clean, tune and test scheduled for a Grizzly Bear Sander!!! ;^(
#6 posted 06-28-2014 03:27 AM
it is a G1073
456lb’s
made in taiwan
lucked out finding the manual
as this was discontinued years ago
glad you got that sander down the stairs
looking forwards to seeing
what you use it for
besides washing the dinner plates
TopamaxSurvivor
18373 posts in 3821 days
#7 posted 06-28-2014 03:46 AM
That is quite a story David. You surely have had a lot of adventures. Glad the saw is back to good health.
View Woodwrecker's profile
Woodwrecker
4191 posts in 3721 days
#8 posted 06-28-2014 03:55 AM
Who knew that the saw would wind up where it is?
Funny where life takes us.
Good job David.
View NormG's profile
NormG
6252 posts in 3149 days
#9 posted 06-28-2014 04:01 AM
Kindness comes back in the end
-- Norman - I never never make a mistake, I just change the design.
View KOVA's profile
KOVA
1363 posts in 2524 days
#10 posted 06-28-2014 04:59 AM
ME ENCANTARÍA ESA BAND-SAW DAVID, PERO ESTOY
MUY LEJOS JAJAJAJAJAJAJAJAJA
VISTE CÓMO TODO VUELVE, SOBRE TODO LAS
BUENAS ACCIONES?????
UN ABRAZO VIEJITO ;-)
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
View Joe Lyddon's profile
Joe Lyddon
10265 posts in 4198 days
#11 posted 06-28-2014 05:06 AM
Beautiful Story!
Thank you very much!
Cool way you got that BS moved & raised into place!
How many Jointers do you have now! :)
Very good!
View stefang's profile
stefang
15947 posts in 3480 days
#12 posted 06-28-2014 05:10 AM
Great story and a great save David. I hate to think about good tools going to waste through neglect and the same goes for people too. It seems you have a habit of making things better for both.
View degoose's profile
degoose
7238 posts in 3500 days
#13 posted 06-28-2014 05:22 AM
Good to see you keeping busy….
View CFrye's profile
CFrye
10419 posts in 1985 days
#14 posted 06-28-2014 07:14 AM
Great story David! Must have broken your heart to watch it sit outside and rust away. Glad you were able to revive it!
-- God bless, Candy
View Monte Pittman's profile
Monte Pittman
29876 posts in 2484 days
#15 posted 06-28-2014 10:08 AM
Endever to persever.
you do very well.
showing 1 through 15 of 30 comments
