tutorial #5: easy utility doors - this one insulated
Blog entry by patron posted 06-15-2013 12:51 AM 2912 reads 2 times favorited 33 comments Add to Favorites Watch
« Part 4: framing tips for shop and house wall builds Part 5 of tutorial series no next part
thought some of you might like to know a simple way to make utility doors
for closets or sheds (or whatever)
like these i made for the new spray booth i am building
from straight 2×4’s and some 7/16” OSB (wafferwood)
as the booth is not enclosed by the ongoing shop build yet
i need it to be insulated too
from summer heat and winter cold
so i put 1 1/2” of sheet insulation
in between two OSB panels
(whatever you might have will work too
especially if they only have one panel)
the frames for any one is dado-ed (they could be rabbeted edges too)
the thickness of whatever material you are using
for single panel just one dado
and the 2×4’s can be on edge
making them thinner for say a standard lock and handle
for insulated two dado’s
(for this you might have to invent some handle and locking type
or do a cut-out in the thicker door
with a thinner block to attach to
for a standard handle
the tops of the stiles (sides up and down)
are notched over at least past the depth of the panels
and the rails (across top and bottom)
are just square cross-cut to the length needed
to make the door as wide as you want
(for a mid-rail dado the same
just do the panel dado on both sides)
and cut your panels the space there plus the dado depth by two
(i usually do a depth like 1/2” so just add 1”
to whatever the inner width and length is for the panels
in that inside frame size)
for the corner ‘joinery’ i just glue and screw them together
with long deck screws
setting the heads deep enough
to clear any trimming if needed on the edges when fitting
to the casing
(you could do any joinery if desired here
just account for any extra length in the rails)
to keep the wind and bugs out
and for winter sealing on old doors
(everyone needs them after those foam tape seals don’t work
or the aluminum finned ones with the little bead of rubber quit working)
i make re-trofit 1×2’s with a 1/8” grove (1/8” in from the edge)
and insert those folded foam and vinyl ones
you see in the box stores
they have a finned barb that holds in a 1/8” x 7/16” deep grove
just sand the edge of the saw kerf slightly
as the sharp corner can catch the vinyl and make it ‘pucker’ when inserted
cut them to fit the casing and with the door closed
they aren’t mitered
as they fold together with no gaps in the corners
i make a temp block to mark with
the width of the stock i use and add 5’16”
for the weatherstrip itself folded
running the block and marking the inside edge to the casing jamb
and placing the trim there to that line
i screw them in place as i have found nails just work loose
from time and tide over the years
and they too can be removed if the door opening calls for that extra width
for moving furniture or tools thru the opening
the advantage of these weatherstrips is they can be removed or replaced as needed
for any painting or re-finishing work needed without having them in the way
and getting paint or finish on them
this is a quick and cheap way to close that doorway
to traffic or just temporary
till you get the dream door installed
thanks for looking
have a safe build
33 comments so far
View grizzman's profile
grizzman
7836 posts in 3206 days
#1 posted 06-15-2013 01:20 AM
really nice build here david, all of its right on…and i like the the whole jam, with butter and …oooppss wrong jam, the door jamb and weather seals are spot on….now onto the pancakes, with jam….:)
-- GRIZZMAN ...[''''']
13594 posts in 3244 days
#2 posted 06-15-2013 01:25 AM
hmmm
pancakes
might need to make some for dinner tonight
great idea grizz
View DIYaholic's profile
DIYaholic
19535 posts in 2578 days
#3 posted 06-15-2013 01:28 AM
Those look like a great “utilitarian” paneled door. I will remember these should the need arise.
It is great that you take the time to “pass on the knowledge”, by doing these tutorials. They are packed with great ideas and insights.
THANKS, for taking the time to educate a moron like me!!!
#4 posted 06-15-2013 01:36 AM
hey son
glad you remember where it comes from
i am the village idiot here
(it helps when i go to town
as i can communicate better
with the locals)
View amagineer's profile
amagineer
1415 posts in 2500 days
#5 posted 06-15-2013 01:58 AM
Thanks David, your knowledge is of great use to me. I will keep this stored away for the future.
-don
-- Flaws are only in the eye of the artisan!
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#6 posted 06-15-2013 02:05 AM
Thanks David, I need to build new doors for my dove house as my last one warped beyond all belief. This should be a much better design. Treated lumber/exterior ply with some good quality paint?
View Joe Lyddon's profile
Joe Lyddon
10021 posts in 3955 days
#7 posted 06-15-2013 03:32 AM
Looks nice…
I don’t see any door knobs… just temporary Nails for now?
Looking GOOD!
Thank you.
View littlecope's profile
littlecope
3071 posts in 3405 days
#8 posted 06-15-2013 05:10 AM
Doors on… check…
How are the lights coming? Did you get the rest of the fixtures in? Switches? Wall plugs?
And what about the Exhaust Fan… and the Air Conditioner??
Has the painting begun on the interior??? :)
#9 posted 06-15-2013 05:27 AM
glad to be able to help don
i’m good with everything but the PT frame andy
that stuff is still green (not just the color)
and unless it is held securely (like for framing for a deck)
it can dry and twist and change as it goes thru the weather
this is a border i did for the front of my deck ramp
this board was straight and true when placed
here it is after a couple of years
michael couldn’t believe it either
when he was here
i will replace it with redwood soon
go with that and you should be lovey – dovey lol
no knobs yet joe
just some twist wood holders so far
hold your horses there michael
doing the best i can there
almost ready for the next part of the build blog
got frustrated last night
and came in and watched ‘dumb and dumber’
to chill out
View stefang's profile
stefang
15784 posts in 3237 days
#10 posted 06-15-2013 07:44 AM
Great tutorial David. Always something useful to learn from them.
View bluekingfisher's profile
bluekingfisher
1247 posts in 2882 days
#11 posted 06-15-2013 08:12 AM
As always, excellent tutorial David, simple enough in design, which can often be overlooked when trying to build something for yourself.
Thanks again for the advice.
-- No one plans to fail, they just, just fail to plan
View ellen35's profile
ellen35
2734 posts in 3335 days
#12 posted 06-15-2013 10:21 AM
Neat… you always have the best tutorials. And… they are practical too!
Glad to see everything coming along.
Ellen
#13 posted 06-15-2013 01:53 PM
thanks mike
as you well know
learning at our age
can sometimes take longer
than doing
you got that right blue
we can and do over think many things
making them hard to get done sometimes
thanks again ellen
when the chips are down
and money and time are short
got to use what we can find
to do the job
they can always be re-done later
in a better way
littlecope
#14 posted 06-15-2013 02:18 PM
Yeah, well… Okay…
Do what you want, you’re going to do it anyway…
Just do the best you can… BUT DON’T TAKE ALL DAY!! LOL
#15 posted 06-15-2013 06:00 PM
that’s good of you michael
ever since you left
i have had to do all my work
myself
showing 1 through 15 of 33 comments
