mexican tile 'cut and switch' #1: simple stacked cuts - tutorial
Blog entry by patron posted 11-10-2012 12:25 AM 5495 reads 14 times favorited 34 comments Add to Favorites Watch
no previous part Part 1 of mexican tile 'cut and switch' series no next part
this is how this box tiles were done
the box is here
and as a received gift here
started with 4 different woods
all the same size
and stacked them 4 colors in each pile
and made a holder to run them random freehand
thru the bandsaw
with a pressure ‘thumb’ on it
after cutting thru them curvy to the same corner
i switched and glued all the 4 different colors together
and cleaned them lightly on the disk sander
so they would be flat
for the sled with a square stop
and trimmed two connected sides
making that corner square
and then just trimmed the other two sides the same
and glued them all together with some ‘grout’ between them
and glued the whole shebang down to a good 7 ply piece
and made the top out of it
and as they say
‘the rest is history’
thanks for looking
as mads likes to say
‘i hope this inspires you’
34 comments so far
View jack1's profile
jack1
2117 posts in 4226 days
#1 posted 11-10-2012 12:55 AM
What clever ideas you have. You need to call the patent office and get you patented! ;0)
View Dave's profile
Dave
11429 posts in 3039 days
#2 posted 11-10-2012 01:00 AM
I will have to try this someday. The jigs are not difficult and the results are very nice.
This is a great use for the scraps that I wont toss out.
13640 posts in 3540 days
#3 posted 11-10-2012 01:04 AM
make’s me laugh jack
looked there a few times
but money and lawyers to do searches
is way over my head
remember dave
nothing goes into the stove
unless it is firewood
View Dave's profile
Dave
#4 posted 11-10-2012 01:06 AM
I have been burning shavings and tubafores.
#5 posted 11-10-2012 01:11 AM
some folks that come by
from time to time
seem to think my stove is a trash bin
and try and burn paper and wrappers there
i stop that right away
the ashes they leave
are a stove clogger
and actually can block the heat
View JL7's profile
JL7
8690 posts in 3164 days
#6 posted 11-10-2012 01:48 AM
Pretty cool David – gotta give this try….the results are amazing…......thanks.
-- Jeff .... Minnesota, USA
View Joe Lyddon's profile
Joe Lyddon
10320 posts in 4251 days
#7 posted 11-10-2012 01:58 AM
David,
Do you mark Starting points for the Curvy cuts so they start at the same places?
I assume that your Pressure ‘thumb’ misses the final cut?
How thick are those small squares?
...... size of square?
Grout! What kind? Did you color it? If so, how?
My memory was close…
Thank you for the refresher!
GREAT JOB!
View LittlePaw's profile
LittlePaw
1571 posts in 3277 days
#8 posted 11-10-2012 02:22 AM
That would be a fun project to tackle – someday!
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View DIYaholic's profile
DIYaholic
19706 posts in 2874 days
#9 posted 11-10-2012 02:23 AM
A very imaginative and ingenious process. I see many people “stealing” this method. I sure will!!!
#10 posted 11-10-2012 02:28 AM
joe
the curved cuts go to the same point
from the outside in
(notice roughly from center off each side
and the corner too)
i don’t mark them
that’s how they get ‘random’
i always make the parts bigger to begin with
as the kerf’s make them smaller
and the edges don’t line up properly
from the missing kerf’s
why i re-trim them after glue-up
the ‘grout’ is a mahogany strip
these parts are 1/8” thick
and about 1 1/2” square
(i don’t remember that far back
but most likely were 3/8” thick to start
then re-sawed and sanded to 1/8” in place
View tomd's profile
tomd
2175 posts in 3969 days
#11 posted 11-10-2012 02:46 AM
Thanks for the tutorial. Nice work.
-- Tom D
#12 posted 11-10-2012 02:56 AM
randy
here are other same idea ways
to cut and switch these
this one is the tile shown in the box
just arranged differently
Joe Lyddon
#13 posted 11-10-2012 04:21 AM
AWESOME!
View ellen35's profile
ellen35
2739 posts in 3631 days
#14 posted 11-10-2012 05:04 AM
Ingenious… or is it just genius!
#15 posted 11-10-2012 05:14 AM
d’nough ellen
i call them simple
and easy to do
i used to cut one board
and use it to mark the next
and then try and fit them to each other
with rasps and planes and sanding
these ‘cut and switch’
make tight seamless joints
(unless you slow and try and correct the cut)
showing 1 through 15 of 34 comments
