tutorial #2: wavy wood build in small scale
Blog entry by patron posted 10-28-2012 02:30 AM 3352 reads 9 times favorited 32 comments Add to Favorites Watch
« Part 1: RIBBONS ANYONE ? Part 2 of tutorial series Part 3: horizontal curve top box »
from my recent project post
http://lumberjocks.com/projects/73330
it seems many like the ‘wavy’ design the most
here is how it evolved
i started out with a piece of melamine
and drew a line across it
and divided it into equal parts
and with a can big enough to give it a smooth curve alternating
back and forth took it to the bandsaw and cut it there
i made some strips with my ‘thin strip’ guide
(1/8”x3/4”)
on the table saw
and put one maple and one imbullia (sp ?)
and clamped the form with the two
which immediately broke both strips
so back to the drawing board
after cleaning up all the glue everywhere
now i made a sled for my surface sander
with a stop on the end and ran the strips one by one (very lightly)
flipping and turning over and over
till i had them to 1/16” thick
(i had to hold them down on the end
and in the middle as they wanted to rise up and bow )
so back to the mold again
( the pony clamps were nowhere near the pressure needed
so i got the 3/4” pipe clamps)
and two by two glued them together
as the wood was dry it creaked and groaned
but taking my time it worked ok
(maybe the glue moisture helped them bend some)
and just added two more each time
to the original ones after clean up
(lot’s of waiting for glue)
did this till i ran out of stock
which was at about 1” wide
now i took it to the bandsaw
and re-sawed the piece into 3 parts
and glued them together too
well now i used a different sled with a thicker stop
and sanded (the same as the other one) till it was 1/8” thick
and glued it to the inner top piece of curly maple
from here it was just a matter of trimming it to fit the rabbets on the box
(and getting it lined up right as i had made it over-sized to begin with)
one problem i have always had with sealed box glue-ups
is cleaning up the dried glue in the inside corners
so this time i tried a new approach i had read about
i waxed the pieces inside before the glue-up
(making sure to not get any wax where the glue would be)
turns out it worked pretty good
it was still there inside but did come loose without
ripping up wood with it or discoloring the corners
after all was said and done some BLO and wax
and cut the top and clean inside
and do the hinges (surface mount stop hinges)
as the parts were only 1/4” thick
(i bought brass screws from #1 to #5 years ago
from 1/4” to 5/8” just for all these odd hardware pieces
and different wall thicknesses)
thanks for checking this out
be safe !
32 comments so far
View Woodwrecker's profile
Woodwrecker
4164 posts in 3632 days
#1 posted 10-28-2012 02:36 AM
Very nice David.
Thank you.
TopamaxSurvivor
18316 posts in 3733 days
#2 posted 10-28-2012 02:36 AM
Kool blog David. Another trade secret is out ;-)
View Dave's profile
Dave
11429 posts in 2897 days
#3 posted 10-28-2012 02:40 AM
Holy cow that’s is the way to NOT give up. Way to get it done David.
Did steaming the pieces ever come into play?
13611 posts in 3398 days
#4 posted 10-28-2012 02:55 AM
yup ‘the secret is out’ alright bob
bigger is easier by far
imagine what martyn (britboxmaker)
goes thru
his boxes are all small too
dave – i though of soaking them
and putting them in the microwave first
but was afraid of what the water might do
to such small pieces and the shrinking
after it was in the box
and didn’t want to mix colors in the glue-up
from bleeding across the glue
View JL7's profile
JL7
8673 posts in 3022 days
#5 posted 10-28-2012 03:28 AM
Pretty clever David…...like how you stuck with it and got-r-done. I have to give this a whirl some time…...good blog.
-- Jeff .... Minnesota, USA
View KOVA's profile
KOVA
1363 posts in 2435 days
#6 posted 10-28-2012 04:36 AM
BIEN HECHO CARPINTERO DE 68 PARA 69 :-D
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
#7 posted 10-28-2012 04:41 AM
gracias carpintero de 51
pero te equivocaste
tengo 67
y voy para los 68
voy a seguir en este plan
hasta los 25
JAJAJAJAJAJAJAJAJAJAJA !
View KOVA's profile
KOVA
#8 posted 10-28-2012 04:54 AM
QUÉ VIEJITO MENTIROSO JAJAJAJAJAJAJAJAJAJA
PERO YO HASTA EL 3-11-12, TENGO 50 AÑOS :-)
#9 posted 10-28-2012 05:00 AM
sera que los dos
somos mentirosos ?
puede ser posible
pero lo dudo
el viejo
en el espejo
no me miente
View KOVA's profile
KOVA
#10 posted 10-28-2012 05:33 AM
TE ENVIÉ UNA SOLICITUD DE AMISTAD EN FACEBOOK :-)
DALE, ACEPTAME AHORA ASÍ CHATEAMOS ;-D
View degoose's profile
degoose
7237 posts in 3411 days
#11 posted 10-28-2012 08:33 AM
Again with the superb information on a fairly difficult technique… made simple..
View ellen35's profile
ellen35
2738 posts in 3489 days
#12 posted 10-28-2012 10:25 AM
Sometimes I have difficulty following some of the tutorials (am I obtuse??)... this one is easy to understand and looks great!
Thanks, David.
View Sheila Landry (scrollgirl)'s profile
9231 posts in 2977 days
#13 posted 10-28-2012 10:33 AM
This looks killer David! Wonderful tutorial! :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
Craftsman on the lake
2796 posts in 3495 days
#14 posted 10-28-2012 11:04 AM
Very cool. This and the previous technique are really something to remember for possible application to some project in the future.
View jap's profile
jap
1251 posts in 2111 days
#15 posted 10-28-2012 12:33 PM
nice
-- Joel
showing 1 through 15 of 32 comments
