circle inlay problem- solution: punt
Blog entry by patron posted 10-12-2012 06:58 PM 2397 reads 0 times favorited 26 comments Add to Favorites Watch
while doing some inlay work
with a router and bushings
while cutting the 1/4” thick inlay
the double sided tape gave way
and i lost the reference to continue
well i looked for one of my many compasses
to draw the line right
but the gremlins got them
so i was faced with free handing or …..
BOOING! (inspiration)
taking a piece of scrap
and driving two nails thru it
(see them sticking out at the bottom)
re-taping the part down securely this time
on a flat surface
i pushed the nails to the edge of the round inlay
and marked the other side
where the circle was right
on the edge of the scrap
and with a razor knife
cut a small ‘v’ notch there
for the sharp pencil to ride with
while pushing the block tight to the inlay
and rotating both together
after cutting close on the band saw
then sanding the edge to the line
on the disk sander
and rounding the bottom edge slightly on the inlay
i was ready for glue in the recessed wood
and using a block and hammer
drove the inlay home
from past experience
i have learned that most glues shrink some as they lose moisture
and can leave a hollow under the inlay
or suck it down further if it is thin
so with some wax paper
and clamps and a solid backer board
squeezed it good
so after all was said and done
here is the inlay
so things i learned here
1 – don’t fret to much
2 – keep an open mind
3 – innovate when necessary
thanks for looking
play safe
26 comments so far
View eddy's profile
eddy
939 posts in 3268 days
#1 posted 10-12-2012 07:01 PM
cool idea will have to rember this
thanks for sharing
-- self proclaimed copycat
View JoeyG's profile
JoeyG
1275 posts in 2529 days
#2 posted 10-12-2012 07:03 PM
Great save as always.
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 2940 days
#3 posted 10-12-2012 07:11 PM
Sound advice, David and a useful blog. Having lost the reference points for trimming on boards for EZ Mitre more times than I care to mention (usually through final sanding) I agree wholeheartedly with your three points.
View DIYaholic's profile
DIYaholic
19536 posts in 2579 days
#4 posted 10-12-2012 07:33 PM
A “kick save” and a beauty!!! Score one for the home team. Very nice recovery.
View rance's profile
rance
4256 posts in 3064 days
#5 posted 10-12-2012 07:47 PM
Always have spare parts. Your solution worked well though.
View Woodwrecker's profile
Woodwrecker
4121 posts in 3479 days
#6 posted 10-12-2012 07:47 PM
Mishaps are like knives, that either serve us or cut us, as we grasp them by the blade or the handle.
J Russell Lowell
-- Eric, central Florida / Utor praemia operibus duris
View Joe Lyddon's profile
Joe Lyddon
10035 posts in 3956 days
#7 posted 10-12-2012 08:07 PM
David…
You fixed the piece very nicely and it looks GREAT…
Looks like a beautiful project you’re working on!
But, wasn’t the problem that the Double sided tape failed to stay stuck?
If you had used more of it all the way round, & really pushed HARD on it to make Solid Contact, wouldn’t that have stopped the problem from happening?
Did I miss something? (as I usually do) LOL…
13594 posts in 3245 days
#8 posted 10-12-2012 08:23 PM
you called it right joe
not enough tape
and the bottom of the inlay part
not smooth enough
live and learn
View jack1's profile
jack1
2099 posts in 3931 days
#9 posted 10-12-2012 08:24 PM
;0) good to land on your feet
View lanwater's profile
lanwater
3111 posts in 2838 days
#10 posted 10-12-2012 09:30 PM
Very resourceful David, you got a lot of experience.
That inlay is cool.
-- Abbas, Castro Valley, CA
View Gary's profile
Gary
9293 posts in 3337 days
#11 posted 10-12-2012 10:49 PM
Another great job, David. And, by the way…your compass it’s on the floor
View JL7's profile
JL7
8633 posts in 2869 days
#12 posted 10-12-2012 10:58 PM
Wow – good save here…..very clever indeed. And the inlay is incredible!
-- Jeff .... Minnesota, USA
View Skylark53's profile
Skylark53
2661 posts in 2964 days
#13 posted 10-12-2012 11:11 PM
Nice work David!
-- Rick, Tennessee, John 3:16
View gfadvm's profile
gfadvm
14940 posts in 2594 days
#14 posted 10-13-2012 01:57 AM
Another clever save by Patron! I think you forgot more about woodworking before breakfast this morning than I will ever learn! That’s why I always run to you for advice. PS: nice inlay job.
View JJohnston's profile
JJohnston
1622 posts in 3195 days
#15 posted 10-13-2012 02:16 AM
I wouldn’t call that a punt, I’d call it recovering your own fumble and taking it in for the touchdown.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
showing 1 through 15 of 26 comments
