ez sled #1: toy tablesaw sleds - simple tutorial tip
Blog entry by patron posted 07-14-2012 02:09 AM 3050 reads 7 times favorited 29 comments Add to Favorites Watch
no previous part Part 1 of ez sled series no next part
i have gotten tired of making things
and halfway thru the process
find i need to make one of something again
and the tools are set for some jobs still ongoing
so having seen some great sleds by LJ Andrew Betschman
http://lumberjocks.com/projects/67727
i whipped a couple small ones together last night
no frills or whistles
‘just the facts ma’am’
turns out they work great
the first is a flat miter
for box parts
the second is a small straight crosscut sled
with the short side to the saw fence
at some point i will make some cadillac sleds (yea right)
the thing i wanted to share
is the simple way to cut lengths
i clamped a block to the saw fence
back a bit and measure my longest boards to it
(the fence as usual can be ‘tweaked’ for a perfect fit)
from the cut line in the sled
then since i wanted the grain to wrap around the box
(i had butterflied the boards)
i just made a spacer for the shorter board
and butted to it (be sure to remove the block
before cutting)
when i do boxes this way
i find the inside of the butterfly
is the better match
so i unfolded the board lengthwise end for end
and marked the parts roughly
and number the corners
1-2 2-3 3-4 4- 1
then 1a-2a 2a- 3a 3a-4a 4a- 1a (etc)
so regardless of how many parts are involved
i can always get them to each other correctly
(like when sanding final and gluing)
so as not to cut out of phase
one end has a side and an end
and the other has the same but in reverse
they have to be cut correctly
or the grain will not match
here they are folded open
and how they need to be cut
as i was scrounging boards from wherever
and had to jump back and forth with these processes
i was able to cut the parts for 10 boxes
in about 3 hours (including jointing
planing and sanding)
the one thing that will stop me from pushing ahead
is when the shop proces becomes to much like work
so i am a happy camper today
and though to pass this along
for you all to help make the shop fun
enjoy
29 comments so far
View JL7's profile
JL7
8672 posts in 3018 days
#1 posted 07-14-2012 02:46 AM
Hey Happy Camper – looking good! Carry on!
-- Jeff .... Minnesota, USA
View eddie's profile
eddie
8565 posts in 2667 days
#2 posted 07-14-2012 02:50 AM
thanks David , need these too your are a cleaver one ,the tutorial was great ,thanks for sharing .this a keeper going on favorites ,
-- Jesus Is Alright with me
View tomd's profile
tomd
2160 posts in 3823 days
#3 posted 07-14-2012 02:55 AM
Nice sled, I am an advocate of KISS.
-- Tom D
View JoeyG's profile
JoeyG
1275 posts in 2678 days
#4 posted 07-14-2012 03:07 AM
This is very similar to how I do things. While the big fancy sleds are cool and all, I find the light little “throw a ways” are usually easier to use. I lost a set of 1970’s bookshelves that should have been trashed in the 70’s, LOL, and the particle board that is still good is destined to become my next set of sleds. I figure they will look a lot like yours. Thanks for sharing. I am glad I am not the only one who does this.
Joey
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
13610 posts in 3394 days
#5 posted 07-14-2012 03:22 AM
thanks guys
the next one up
the pointy one
for making flat frames
the small ones are so user friendly
and can be changed and stored
so much easier
than those big ones for cab parts
i didn’t even ‘dial’ these in
i just made sure my fence was good with the blade
so the bases are square to begin with
and cut the dadoes for the runners from it too
View Joe Lyddon's profile
Joe Lyddon
10152 posts in 4105 days
#6 posted 07-14-2012 03:37 AM
Hi David!
COOL & simple KISS sleds!
In that last picture… Did you resaw your board to get two identical pieces… To get bookmatched pieces?
... is that what you mean when you say you “butterflied” your boards?
COOL technique / procedure!
Thank you!
#7 posted 07-14-2012 03:49 AM
that’s what i did joe
re-sawed a thicker one
and used the inner faces
on the outside
if you don’t
the grain change can look very different
on the two sides of the board
and they don’t come together as well
of course with this way
two corners diagonally
are ‘folded’
and the other two are book matched
or ‘mirrored’
Joe Lyddon
#8 posted 07-14-2012 04:01 AM
COOL point… using the CUT surfaces on the OUTSIDE… that’s as close as you can get to Matching grain! LOL
NICE tip!
Thanks again!
I have to remember this!
(the hard part!)
View KOVA's profile
KOVA
1363 posts in 2431 days
#9 posted 07-14-2012 04:16 AM
ERES UN GENIO DAVID:
PERO LO BUENO ES QUE TE TENGO DE AMIGO PARA APRENDER DE TÍ ;-D
YA ME PONGO A HACER ALGO PARECIDO Y PUBLICO FOTOS :-)
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
View rance's profile
rance
4259 posts in 3213 days
#10 posted 07-14-2012 04:45 AM
I could use a KISS sled or two. Thanks for posting.
View Bob Kollman's profile
Bob Kollman
1798 posts in 3244 days
#11 posted 07-14-2012 05:22 AM
Nice Sleds David, I love the sleds…..I even made one for cross cutting up to 30”. I was up early this morning with the jig saw…...I found out what a wonky cut is, never start work before you have finished that first cup of coffee. I agree with Kova also, your a Genius David!!!!
-- Bob Kenosha Wi.
View Dez's profile
Dez
1166 posts in 4130 days
#12 posted 07-14-2012 07:28 AM
The difference between Cadillac and Chevy is only in the name! Both can get you to the same places!
-- Folly ever comes cloaked in opportunity!
View bluekingfisher's profile
bluekingfisher
1250 posts in 3032 days
#13 posted 07-14-2012 08:15 AM
I’m sure they will come in handy for future jobs too. It’s always to have a jig on hand made some time in the past which can be put straight to work.
-- No one plans to fail, they just, just fail to plan
#14 posted 07-14-2012 08:21 AM
i have 4 saws
1 cab
1 job
2 table tops
and hope to make sleds for all of them
then can just jump around without stopping
maybe 1 for dadoes and rabbets
(course they are on the back porch
just parked now)
View stefang's profile
stefang
15881 posts in 3387 days
#15 posted 07-14-2012 09:36 AM
Great tutorial David. ALL of my jigs are Chevys. I’m not against beauty in the shop, but I am too lazy to make it that way. I’m not bragging, just stating the facts.
showing 1 through 15 of 29 comments
