HANGING AROUND - made easier
Blog entry by patron posted 782 days ago 3236 reads 7 times favorited 44 comments Add to Favorites Watch
throughout my career as a woodworker/carpenter
i have hung many new doors to existing jambs
the hinge placement its critical
as i must leave the existing hinges in the jamb
and transfer that to the door
the hinges are usually different sizes
with different corner details
and offset to different dimensions
depending on the pre-built standards
of any given door maker
(they are never the same just visually close)
over the years i have come to know and struggle with these diferences
you have someones new door
they are all waiting watching
something is not right and you start to wish they had never called
after measuring and marking with a tape
(a hit and miss event)
and making story boards
(which i still do)
to make the following hinge jigs
to help me get it right
the evolution of these jigs took some time to do right
this is a typical first try made by marking and cutting the hinge profile
with a table saw and a jig saw
today i make them much better and faster
here’s how
start with a thin strip
usually the thickness of the hinge inset off the edge of the door
rip a piece of stock (i use ply or particle board)
wider than the hinge inset on the door
(there must be room for the router bit to enter and exit
without eating the jig or leaving the front hinge cutout round)
and glue and pin this to the strip
(you want to do this against a straight piece
so it doesn’t curve and wander)
now take the hinge itself and put it against the filler block
(watch the hinge pin)
and butt more stock to the hinge
and cut it to the edge of the middle or next hinge
and glue and pin also
repeat this process till you have as many hinges as you like
now pin and glue the other side strip to the jig
i make then different sizes by 1/16” to give the door heel some clearance
so it doesn’t rub the jamb as it closes
and has room for the finish if that has not been done yet
make sure you have the top end of the jig to the top of the door jamb
and mark it for the reveal of the door top (1/16 or 1/8 or whatever)
and the bottom marked as well
now its just a matter of screwing nailing or clamping the jig to the door edge
with the right edge to the door edge
(remember the jamb clearance here)
and route this way by setting the router bit to the jig and hinge thickness
a note here
i use mostly short 1/2” patterning bits
as the standard 1” one is to long
and requires a thicker jig
so the bearing has a place to ride
the 1/2” bit also leaves me a 1/4” round hinge corner
it that is the type of hinges used
if they are square corner
i use my chisel to ‘clip’ the corner of the cut out
before removing the jig
sometimes making a big one is too much under the work conditions
so i have a set of open ended single jigs
for different hinge sizes and corner details
and use them to the special needs
so a quick review
1 – make the jig to the top of the jamb
and mark the door clearance there
in the jamb butt it tight
on the door move it to the door clearance mark
2 – use the appropriate edge of the jig on the door and jamb
(or it will be to tight and the door wont close)
3 – use a short router bit of a smaller size
(unless you are doing those 1 1/4’ round corners
which require a hand made corner detail)
with them i usually use my single jig
and mark things carefully
4 – don’t count on any two doors to be the same
(if they are all pre-hungs from the same maker
you might luck out)
but usually the exterior doors are different
5 – this can be done for smaller doors (cabinets and such)
and boxes too
it just takes time and attention to smaller details
hope this helps someone
if you have any questions
call A1jim lol
44 comments so far
87040 posts in 1744 days
#1 posted 782 days ago
Did someone call? Good blog David .The only thing I think might be better is if you used purple heart for all your jigs like kent. LOL
View donjoe's profile
donjoe
1349 posts in 1198 days
#2 posted 782 days ago
David, very informative as well as useful info. Thanks for putting this one on.
-- Donnie-- listen to the wood.
12051 posts in 1508 days
#3 posted 782 days ago
good point jim
as long as it lasts
then i can quit altogether
and watch TV
View Woodwrecker's profile
Woodwrecker
3005 posts in 1743 days
#4 posted 782 days ago
I think this is about my 20th “thank you” to you David.
I think you are #1 on my favorited stuff list.
-- Eric
View davidroberts's profile
davidroberts
952 posts in 1653 days
#5 posted 782 days ago
Very clever sensei, and useful.
-- david roberts, spinning Tales from Topographic Oceans, no, really.
View ShopTinker's profile
ShopTinker
862 posts in 935 days
#6 posted 782 days ago
Great Blog, I’ve never tried it with a jig. I’ve always marked the new door off of the old door. Cut inside the lines and hand fit each hinge. I think your system is way faster.
-- Dan - Valparaiso, Indiana, "A smart man changes his mind, a fool never does."
#7 posted 782 days ago
dan
when i make custom doors
and jambs
i see if one i have comes close
and use it
saves me lot’s of time for sure
View lilredweldingrod's profile
lilredweldingrod
2498 posts in 1274 days
#8 posted 782 days ago
Now we know why there has to be an apprenticeship program in woodworking. I can only imagine what it would be like to get to spend a year working with you. Definitely a young woodworkers dream. Thank you for the info. Rand
View devann's profile
devann
1718 posts in 860 days
#9 posted 782 days ago
Thanks David, wish I’d meet you long ago. I already have the Porter Cable plastic jigs. You take three of them and attach them to a strip of plywood in the proper spacing and wa-la. I’ll make one of your kind the next time I do big doors with four hinges. The pattern bit that comes in the Porter Cable jig is cool, it cuts a square corner with that round bit. It has a funny shape to it and you set the hinge jig square side inside and 1/8” big. You flip the adjustment over for round hinge or square and set to the proper hinge length.
And while we’re talking doors David, I have a small Stanley vise that kinda looks like one of those hobby vises that rotates and can be clipped on a 2x, sawhorse, deck rail etc. I like it for holding the door so I can work on it. I got it at Big Lots for $5. If you see one, snag it.
View Bob Kollman's profile
Bob Kollman
1779 posts in 1358 days
#10 posted 782 days ago
Good timing David, I have to build new screen doors this spring for
the front and back door of the new place. We have all these great
brand new windows but no screened doors to let the fresh air in better!
I’ve never made a door before- or installed one.
bob
-- Bob Kenosha Wi.
View rivergirl's profile
rivergirl
3200 posts in 1005 days
#11 posted 782 days ago
I could have used this blog 3 days ago….. :) But it’s nice to have it today.
-- Homer : "Oh, and how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain."
View littlecope's profile
littlecope
2325 posts in 1669 days
#12 posted 782 days ago
Smart, Fast, and Accurate…
That New Shop you’re building… You should give some thought into making it into “The Patron’s School of Advanced Wood Working and Carpentry”
If you need a cafeteria cook, let me know!! :)
View tdv's profile
tdv
1113 posts in 1237 days
#13 posted 782 days ago
David I use a similar method I bought a Trend hinge jig & found it very limited it would only cut fixed spacings & it doesnt work in rebated door casings. So I started making my own like your small versions to do one hinge at a time . Just one addition if I may? a lot of the old properties I work in (around 19th century) are in poor repair with hinge recesses that look like they were carved out with a screwdriver. So I made a version with a bigger pocket & cut out the old hinge recess & fill it with a dutchman (I carry a supply of milled stock with me to fit my jig) then just cut the new hinge to current standard into new wood & it always makes a neat job
-- God created wood that we may create. Trevor East Yorkshire UK
#14 posted 782 days ago
good solution to the old loose screws
and torn parts trevor i’ll have to do something similar
job site ‘dutchmen’ take to much time
. michael you will have first choice
i used to be a dishwasher in greasy spoons
we could help each other
and have more time in the shop
. bob and kelly i need to build a door soon
will do a full tutorial about it
stay tuned
. darrel i’ve used various jigs too
but the price for some rigs
is just to much for the ocasional door work i do
and some are set within standards
so doing off size and custom
is just to hard for them
TopamaxSurvivor
13192 posts in 1843 days
#15 posted 782 days ago
I don’t think I’ll change any doors after all, unless David is coming north for a few days ;-))
showing 1 through 15 of 44 comments
