making a 'bow tie' circle pattern - tutorial
Blog entry by patron posted 01-10-2011 05:23 AM 26693 reads 85 times favorited 44 comments Add to Favorites Watch
my
‘did it my way board’
http://lumberjocks.com/projects/42141
was done like this
the tangents are the square of the circle
the thickness of the stock is that height of the square
the width of the stock is the square and the two wings
of the circle combined
(for my 1 1/4” bits it was 1”x1 1/2”)
cut and mill the stock
run the round edges first
so the flat is still good for the coves later
the fence and the cutter tangent want to be exact
so there is no loss in width
and centered to the side of stock
flip stock over and do the other side
i didn’t turn the stock end for end
because if the cutter height was micro off a shade
it would be the same off on the other side
from the center of the stock
keeping all the ends the same direction
i went to the other router
that had the coveing bit and a fence
and again tweaking the fence
tried some scrap till the cove edges were just cented
and even sharp the same
and ran the length over that and flipping again for the other side
now the ‘keeping the parts and grain constant”
i drew a line down the cove (1 side)
so i cut them all the same ( in case the saw was off by a smidge)
and marked each end with a dot on one side of the end as i cut them
and stacked them as the had been cut
ready to lay out
now the lay-up and why the dots
in some patterns you need to mark one side
or the parts get ‘flipped’ and the grain goes off
‘tumbling blocks’ are a good example of that
and the clamping
i set the whole thing next to the clamping wax paper
and one by one brushed glue into the coves (one cove for the edges)
and chop chop put them into their place
and with the stops and clamps ready
(this is where you can loose to much time with any glue-up
if you aren’t ready with everything )
clamped the sides some loose then the ends
as i tightened the clamps
i could see where the glue was coming up
and where not so i loosened some and tightened others
until i had glue every where even and clamped them all good
and here we are after sanding and rounding over edges
and oil
i thank you for looking
and hope this has helped clarify the build
work safe
44 comments so far
View lew's profile
lew
12153 posts in 3810 days
#1 posted 01-10-2011 05:27 AM
Clever idea, David!!
Like the guy said, you can never have too many clamps.
Lew
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4012 days
#2 posted 01-10-2011 05:32 AM
Your the man! This isn’t as hard as it looks…thanks!
View DraftsmanRick's profile
DraftsmanRick
112 posts in 3115 days
#3 posted 01-10-2011 05:38 AM
Very, very, cool! First time ive seen this. Great job!
-- Jesus was a carpenter
13611 posts in 3395 days
#4 posted 01-10-2011 05:39 AM
unfortunately the cutters i used 1 1/4”
were the biggest made as router bits
there may be bigger as shaper cutters
but i don’t go there to much
to expensive for the little use i give them
View hooky's profile
hooky
365 posts in 3373 days
#5 posted 01-10-2011 05:50 AM
patron that is simply brilliant
i never thought of using curved interlocking patterns but this is something i now have to give a try
thanks for showing and explaining how you did it
Hooky
-- Happiness is a way of travel , not a destination (Roy Goodman)
#6 posted 01-10-2011 05:58 AM
more than welcome to it
i’m about ready to make a jig
that will do this with flat stock
should be easier
than these dedicated router bits
View Bovine's profile
Bovine
114 posts in 3382 days
#7 posted 01-10-2011 06:20 AM
David, I’m with Hooky….this is both simple and brilliant in its design. I’m assuming it’s Maple and Walnut by the pictures and I’ve always been a fan of that combination of wood. Thank you for explaining how you did it!
-- Kansas City, KS "Nothing is as permanent as a temporary solution"
#8 posted 01-10-2011 06:23 AM
bov
it is rosewood and rock maple
it is a project here
View majuvla's profile
majuvla
12579 posts in 2922 days
#9 posted 01-10-2011 06:46 AM
Hi David,
Awsome and unique.Thanks for showing us a process.
-- Ivan, Croatia, Wooddicted
View Dave's profile
Dave
11429 posts in 2894 days
#10 posted 01-10-2011 07:06 AM
Thats a new one on me great stuff
View degoose's profile
degoose
7237 posts in 3409 days
#11 posted 01-10-2011 07:30 AM
Oh so simple.. when you know how…Really enjoy all your lessons, Master.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3237 days
#12 posted 01-10-2011 08:07 AM
That is crazy good. Thanks for the tutorial, really well thought out and executed.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View Joe Lyddon's profile
Joe Lyddon
10153 posts in 4107 days
#13 posted 01-10-2011 08:42 AM
Very good, David!
With your help, I have hence figured out how construct, via Geometry, your Bow Tie!
Very interesting!!
Draw a Circle with Radius R.
Divide the Circle into 4 parts by:
1. Draw a line through the center of the Circle.
2. Bisect that line resulting in another line through the center of the Circle.
3. Circle is now divided into four sections.
With the compass set at radius R, bisect a Qtr section on the Circle to get the outside Radius (R) point of the Cove Cuts, which start & end at the Qtr section boundaries.
Do the same thing to the opposite Qtr section resulting in making the Bow Tie.
The other 2 Qtr sections remain unchanged (the original circle), the outward parts of the Bow Tie.
It turns out that the amount CUT out for the Cove, will be replaced perfectly by the Circle Qtr of the Bow Tie.
In my test drawing, I used a Radius, R, of 3/4”; made a Circle of 1.5”.
After I drew the Coves, it appears that the Cove cuts span a tad more than 1” (more like 1-1/16”)
Cutting the Coves so they span the Qtr sections perfectly, I guess, is the most Critical cut in this process.
Very Slick and Very COOL!
Now, it’s another thing to cut it out of wood!
TopamaxSurvivor
18313 posts in 3730 days
#14 posted 01-10-2011 08:53 AM
This is too deep for me ;-)) What do you do with all the saw dust? :-)) Awesome work!!
View Lenny's profile
Lenny
1607 posts in 3581 days
#15 posted 01-10-2011 01:36 PM
David, I think I see the shroud of Turin in there. No, wait now I see Jimmy Hoffa. Seriously though, in the photo with the red dots, I can see birds of some species…American eagle or duck or something. As someone suggested on your other post on this project, it has an Escher-esque look to it. Wonderful design and craftsmanship David and a great tuturial.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
showing 1 through 15 of 44 comments
