random wavy jig for lenny
Blog entry by patron posted 12-08-2010 03:55 AM 1989 reads 7 times favorited 29 comments Add to Favorites Watch
lenny asked about the bathroom door panels i made
for my own bathroom and if they were decals
http://lumberjocks.com/projects/40732
here is the jig and the process
this is a sliding tray for the 1/4”x2 1/2” slats
(mill 3/4” in half and save wood)
i leave them over sized in thickness by about 1/32”
it will be sanded to finish size later
the router base i drilled a 1/16” hole in
and inserted a finish nail as a center pivot
cut the nail so it only goes into the top of tray snugly
and did a center hole in the tray for it to pivot around
slide the slat in and turn the router
with a straight bit set to say 3/32”
move the slat forward (random or equal spaced)
as you like and continue till the slat is to your liking
here’s the hard part (LOL)
turn every other slat around !
now i take a brush (1”) and swab the cuts with the finish
i will use for the finished door (lacquer in this case)
i used to spray but found that brushing seals better
to keep the paint from bleeding into the grain
and leaving a messy line
now paint i use wal-mart hobby craft paint
(stay in the sealed part)
but just about anything will do
even fingernail polish ladies lol
be sure to dob it in good to paint the sides too
and when the brush gets drier
rub it through the cut to smooth it out good
(don’t want any clunks or pools)
now sand the slats and i do the edges
with a 1/16th round over bit
they are slim and flex somewhat
so when i place them in the frame
i use ‘spaceballs’ to push them together
the finish ‘glues’ them that way
so make sure they are all in plane
look at the panel parts from different angles
being sure they are all correct
and the colors not all bunched together
when you have them the way you want them
mark the ends with some code
to be sure to get them all correct
when you do the frame glue-up
i hope this explains the process well
if not i have more pictures
i just went to the important ones
ask if you need more info
happy working
be safe
29 comments so far
View Pawky's profile
Pawky
278 posts in 2771 days
#1 posted 12-08-2010 04:32 AM
“now i take a brush (1”) and swab the cuts with the finish
i will use for the finished door (lacquer in this case)”
So, that just prevents paint being left outside the groove after you are all done? Will sanding it not remove the paint if you don’t have a finish down? Thanks
View Lenny's profile
Lenny
1593 posts in 3494 days
#2 posted 12-08-2010 05:08 AM
Wow, ask and thou shalt receive, huh? Thanks for the thorough response David. What a neat idea/process.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View jockmike2's profile
10635 posts in 4214 days
#3 posted 12-08-2010 05:12 AM
WOW DAVID, YOU DO HAVE SOME IMAGINATION. WHERE IN HELL DO YOU GET YOUR IDEAS? DO THEY POP UP IN YOUR DREAMS OR DO YOU CHEW SOME PAIOTE sp BEFORE YOU START? I JUST CAN’T FATHOM WHERE YOU GET YOUR IDEAS. HELP AN OLD BUD WOULD YOU? I’M STILL LOOKING FOR YESTERDAYS SOCKS. LOL. M
35111 posts in 4368 days
#4 posted 12-08-2010 05:29 AM
Cool David. You are always working out in left field.
Wait, outside the box.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3074 days
#5 posted 12-08-2010 05:32 AM
Mercy! What a fertile mind.
View Joe Lyddon's profile
Joe Lyddon
10048 posts in 4019 days
#6 posted 12-08-2010 05:49 AM
JockMike,
He is a gifted artist that can see into the 4th dimension and then has the talent to make something of it. :)
View lanwater's profile
lanwater
3111 posts in 2901 days
#7 posted 12-08-2010 05:55 AM
Neat jig!
It definitely makes life easier.
-- Abbas, Castro Valley, CA
View ND2ELK's profile
ND2ELK
13495 posts in 3741 days
#8 posted 12-08-2010 05:58 AM
David, you cease to amaze me! What a God given talent you have, when it comes to woodworking. After doing woodworking for 40 + years, I always considered myself a pretty good wood worker, but compared to you buddy, I got a long ways to go. Thank you for teaching this old dog some new tricks. I truely enjoy seeing what you are going to come up with next.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View BarryW's profile
BarryW
1015 posts in 3874 days
#9 posted 12-08-2010 06:04 AM
David, I read this and you are so smart and knowledgeable….swabbing the lines with lacquer to prevent bleeding….genius…I wouldn’t have thought of it…what an idea….that’s a lesson that will stick with me forever.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View Bob Kollman's profile
Bob Kollman
1798 posts in 3158 days
#10 posted 12-08-2010 08:36 AM
Cool little set up!!!!
-- Bob Kenosha Wi.
View stefang's profile
stefang
15881 posts in 3301 days
#11 posted 12-08-2010 12:07 PM
Don’t forget to bring the jig with you David!
View ellen35's profile
ellen35
2734 posts in 3400 days
#12 posted 12-08-2010 01:24 PM
David,
Not only are you clever and talented, but you can explain it so we all understand the process.
And… you are generous to a fault … you share so much knowledge with us.
You make it “look” easy… hmmmm!
Ellen
13600 posts in 3308 days
#13 posted 12-08-2010 01:41 PM
ellen
universal truths
are
universal
the planets are in balance
a boat works in the universe
if it is in balance too
our lives work when in balance too
if something works somewhere
it can be transposed to work
somewhere else
confusion say
it’s OK
View Cozmo35's profile
Cozmo35
2200 posts in 3003 days
#14 posted 12-08-2010 03:41 PM
Patron, If you were an Indian, we’d call you ”Chief Kickin Booty”! Great explination and project!
-- If you don't work, you don't eat!.....Garland, TX
#15 posted 12-08-2010 03:53 PM
coz
that’s a step up from
hey you
that they usually call me
thanks
showing 1 through 15 of 29 comments
