some of you might remember my previous blog about my rain/snow gutters ,
i finally got some time to progress on them ,
as i have been working away from home for a while now ,
http://lumberjocks.com/patron/blog/16257
the first two pictures are from that post , about the cutting jig ,
and an actual 6” PVC x 20’ pipes cut 1/4 out of ,
making a tube that wraps up and over my metal roof to catch rain,
and stop the snow from sliding off the roof ,
both of which have been just wasted water for me ,
as i have to buy water for the house ,
this is the jig and a pipe ready to cut on a track for the skillsaw to follow ,
top and side .
here is the cut tube , ready to be processed for the gutter .
here is the tube painted the house color with ‘fusion’ plastic paint ,
notice the white ends , taped off , then ready for some ‘bitchathane” ,
PVC shower liner , that i will use to bond the ends together and paint too .
the fittings for this size pipe cost anywhere from $30 to $75 apiece ,
and are big and bulky , i don’t have money for that , so i am inventing as i go .
here are brackets i fashioned from 2×10 pine , i had to plane and mill them as they cupped badly by the time i got to them , and i put a plywood strap glued and screwed behind the fascia , so they don’t split from the weight of the pipe they are thru bolted to the porch rafters , every 4’ and hold the tube very well .
here is the first one in place , the lower fascia edge will be back screwed to a window seal gasket thru the fascia,so as not to leak there . i can use my air ratchet and hex pro-panel screws by reaching in from the roof side to attach them , and plumbers galvanized strapping bolted to the top edge of the tube , and down the face of the brackets , so they don’t split either .
the idea is to have something higher than the roof , to stop snow from just sliding down and dropping off the roof . and to channel the water to a large water tank , where i can use it for house or garden needs ,
the down spouts , i will make from 3” PVC , hole sawed thru this one and glued to it and profiled inside .
as all these gutters will be 54 ft long , for a total of 172 ft , i wont have any pitch to them ,but water will find it’s own level , so i think i am OK . if i put pitch on them , they would be to low at one end to do me any good .
WHY WASTE IT ?
IT’S FREE !
thank you for looking ,
play safe .
41 comments so far
tyskkvinna
home | projects | blog
1294 posts in 1157 days
#1 posted 1054 days ago
Hey that looks like progress! :)
I agree with you – it’s free, why waste it?!
I will admit, your original post on this subject caused me to look long and hard at my water usage in ways I never had before. I’ve always been a city dweller of one sort or another… but any saving of water is good, right?
I also agree with you – water will find its way down, one way or another.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
87309 posts in 1748 days
#2 posted 1054 days ago
Looking good David nice color too. That’s one heavy duty gutter.
12070 posts in 1512 days
#3 posted 1054 days ago
thanks lis ,
i have installed many metal and plastic gutters ,
and all they do is channel the rain to a corner and down ,
when they get clogged ,
or snow is sliding over them ,
they usually just get ripped off the roof ,
worth less to me .
and they cost quite bit too .
#4 posted 1054 days ago
thanks jim ,
i don’t want to have to pay ,
some strutting moron ,
to come and fix my hose someday ,
i might be in a wheelchair ,
screaming at him ,
while he messes everything up ,
and takes all my money !
degoose
6598 posts in 1526 days
#5 posted 1054 days ago
Genius at work.. Water is getting dearer here.. will have to hook up my tank to the main house for use…Busy doing other things first..
wseand
1549 posts in 1213 days
#6 posted 1054 days ago
I must say that is a great idea, the brackets are just perfect.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
BarryW
1013 posts in 2078 days
#7 posted 1054 days ago
Necessity is the mother of invention….great ideas…you’re thinking way too much…but that’s not all bad…in fact, not bad at all….it’s great.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
Dennisgrosen
10854 posts in 1286 days
#8 posted 1054 days ago
your progress with the gutters looks gooood man
thank“s for sharing David
Dennis
stefang
9500 posts in 1505 days
#9 posted 1054 days ago
I like self sufficiency David, and your mounting idea and installation look very good to me. I expect there will be fountains, flowers and a huge green lawn around your house in the near future which you will be able to enjoy looking at from your pool area.
-- Mike, American in Norway
BertFlores58
1537 posts in 1093 days
#10 posted 1054 days ago
David,
Next thing will be your filtration for producing a drinking water…. We have an LJ member Bill Davis who had mentor a way to filter water from a fishpond… Visit his web Read this to believe… You can use his filter…. thanks.
-- Bert
10636 posts in 2418 days
#11 posted 1054 days ago
Wonderful job David. Looks like a lot of hard work. Has to be worth it though. Quite an engineering feat. Looks good too.
ellen35
2442 posts in 1603 days
#12 posted 1054 days ago
Nice work David. Shows your creativity knows no bounds!
Ellen
dustbunny
1148 posts in 1466 days
#13 posted 1054 days ago
You’ve been busy !
This project is looking great,
Can’t wait for the finish and RAIN !!
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
#14 posted 1054 days ago
good morning all .
my neighbor came by ,
and offered to get the water tank ,
out of the hole it’s in ,
with me this week !
things are looking up !
SPalm
4118 posts in 2053 days
#15 posted 1054 days ago
Nice project.
But man, do you have an eye for design. There are many ways of accomplishing the routing of water, but you have put a very artistic spin on it. Good for you.
Steve
-- -- I'm no rocket surgeon
View all comments »
showing 1 through 15 of 41 comments
