miter devider
Blog entry by patron posted 09-24-2009 03:26 AM 1990 reads 8 times favorited 16 comments Add to Favorites Watch
this is a jig i made years ago, it devides any angle for miters .
the circles have mesh teeth that rotate both sides together .
i originaly used sand paper , but it wore out quick , and the
circles slide singularly .
i found some rubber “v” grooved mat , and glued it to the sides
of the circles so they mesh , ( it’s not the best , but it works for now )i had to re-cut parts for this new improvement ,
as there wasn’t room for the mat .
it is registered to the table with dowels , that fall in holes for them ,
and is centered in the cut line .
with a board parallel to the RAS fence , i placed the stops on the circles,
so they are straight across and paralell to the fence.
( i will probably make them with smaller dowels also soon ,
and make various mounting positions for them on the wheels .
you turn the wheel , it turns the other one in reverse ,
put your adjustable angle against the stops , and turn the wheels until it
matches . in the front right of the jig , is a thumb screw that holds the wheel from turning .
DON”T FORGET TO RAISE THE SAW , or you will cut the jig !
this is just a model , maybe charles maxwell will teach us how to make gears sometime ?
the idea is that it could have positive stops at major angles , just like the chopsaws.
arms can be extended with stops for frames or multiple pieces .
this first pic. is just truing the wheels around its dowel
in picture below
when set .
notice thumb screw in pic. below
16 comments so far
View poroskywood's profile
618 posts in 3295 days
#1 posted 09-24-2009 03:47 AM
OH Wow! Brilliant. Your ingenuity is unsurpassed David. I suppose someone could incorporate this idea onto a crosscut sled for a table saw?
Your like this old country singer I know, I’ve been playing music with this guy for over ten years, I mean hundreds of songs, and he’ll say to me “here’s one I haven’t played in a while” and it will be a song I have never heard before, and it will be awesome. I’ll say “In all the years we’ve been playin music you never once played that song.” He’ll say “I forgot I knew it.”
-- There's many a slip betwixt a cup and a lip.--Scott
View cabinetmaster's profile
10874 posts in 3489 days
#2 posted 09-24-2009 03:54 AM
What a great idea. I wish I had my RAS back now…......................lOL
View degoose's profile
7228 posts in 3286 days
#3 posted 09-24-2009 04:10 AM
How fantastic is that.,... but I still don’t like RAS’s
-- Don't drink and use power tools @
13598 posts in 3272 days
#4 posted 09-24-2009 04:28 AM
scott ,
i have designed one for the tablesaw ,
but it requires linkage or cables to go over the saw blade ,
as the wheels must work opposite of each other .
mucho complicado !
larry you could use one on the beastie ?
View littlecope's profile
3071 posts in 3433 days
#5 posted 09-24-2009 04:35 AM
Slick trick, David!
I bet your bag of tricks has more in it than Felix the Cat’s!!
View davidroberts's profile
1027 posts in 3417 days
#6 posted 09-24-2009 06:10 AM
That is just too ingenious. How do you keep the wheels from moving from one cut to the next? Maybe they are tight enough against each other and it’s not a problem?
-- Better woodworking through old hand tools.
View scrappy's profile
3506 posts in 3362 days
#7 posted 09-24-2009 06:56 AM
Very Cool idea! Could have lots of fun with this on a RAS.
Thanks for the demo.
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
117029 posts in 3508 days
#8 posted 09-24-2009 07:00 AM
cool jig david
-- wood crafting & classes
View stefang's profile
15874 posts in 3265 days
#9 posted 09-24-2009 11:43 AM
Brilliant jig David. It always amazes me to see how many ways tools can be made to perform different tasks.
Just the same I’m glad I have a sliding miter saw, because I have just about run out of wall space to hang more jigs.
Enjoyed your blog.
View spanky46's profile
995 posts in 3322 days
#10 posted 09-24-2009 11:54 AM
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
View moshel's profile
865 posts in 3615 days
#11 posted 09-24-2009 01:07 PM
good stuff! I guess it would also work with sliding compound (I have neither :-)
-- The woods are lovely, dark and deep, but I have promises to keep...
#12 posted 09-24-2009 01:10 PM
yes it would , and much less trouble finding the correct bisect .
View Blake's profile
3443 posts in 3805 days
#13 posted 09-24-2009 06:29 PM
Great idea!
-- Happy woodworking!
View SCOTSMAN's profile
5851 posts in 3516 days
#14 posted 09-24-2009 06:39 PM
Very well done my best friend, a genious you are me boy.And no mistake.Alistair
35112 posts in 4332 days
#15 posted 09-25-2009 05:37 AM
David: A great performing jig. That looks like it should be made with a track and a crank handle to move the two discs in sync.
You should be able to do the same for a table saw if the disc’s were bigger and the blade was further out to the front. Maybe a big gear to the operator side driving a smaller gear underneath the disk that holds the wood. That would allow the blade to get into the area where your disks are touching on this version.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
