sunburst railing build
Blog entry by patron posted 05-27-2017 12:40 AM 1768 reads 2 times favorited 12 comments Add to Favorites Watch
USB building code calls for no more than 4” space in railings
so babies don’t get caught thru them
make a disk that size
start by finding center to top and bottom rails
and mark disk edges (lightly) from the centered disk
make board at least 1” longer than overall railing top and bottom distance
and lay board edge to disk edge mark
and bottom rail center line
mark 1 1/2” on side of both ends (opposite corners)
and connect with straight line
and cut there making 2 more or less equal pieces
(this is site work so be kind and don’t get all 1/1000 th inch fussy)
place part to disk edge line on top and same edge to centerline at bottom
mark these angles (easiest from the back)
and cut there
route the edge to match the eased edge of board
(or whatever ‘period’ style you like)
attach part to rails and using disk again
mark next space
i only cut one piece ends as this deck was old
and the post spacing was off some
from shifting over the years
so each side could be slightly different
cut the top first and try the angle
it can be adjusted as the need arises
then trim the bottom one
use disk both sides and mark edge there
and repeat thru the whole build
remembering to measure the longer length of successive rays
the bottom ‘bundle can get somewhat ‘wombly’
so i made a ‘sun’ cap for it
a curved piece with the ends rounded
and the length of the taper of the rays together
it gives the appearance of the center of the ‘sun’
with the rays coming from it
but cleans up the funky ends down there
there is some center to the sunburst
but it is not important
as the visual effect is what matters
which the eye either likes or not
this is a design effect
not a satellite part
so some leeway is fine
i closed in under the porch as kids and bugs
snakes/mice/spiders don’t mix well
hope you enjoy this build if you chose to try it
it might look nice for a second floor railing too
12 comments so far
View jack1's profile
jack1
2108 posts in 4108 days
#1 posted 05-27-2017 01:51 AM
Looks great. Those are neat techniques you used.
View Monte Pittman's profile
Monte Pittman
29653 posts in 2418 days
#2 posted 05-27-2017 02:35 AM
Great tutorial sir.
View Rich's profile (online now)
Rich
3335 posts in 670 days
#3 posted 05-27-2017 02:42 AM
Beautiful. I think it’s the mark of a true craftsman when you can make something look so simple, when it’s not. Great job Patron.
P.S. I bet we could share some killer chile recipes. (for everyone else, I’m not referring to chili).
View Woodwrecker's profile
Woodwrecker
4166 posts in 3656 days
#4 posted 05-27-2017 03:28 AM
Very nicely done brother.
That you for the disk trick.
Your work always shines David.
View tyvekboy's profile
tyvekboy
1782 posts in 3094 days
#5 posted 05-27-2017 03:36 AM
Great tutorial. Thanks.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View johnstoneb's profile
johnstoneb
2989 posts in 2253 days
#6 posted 05-27-2017 01:32 PM
I like it. Might try it on something.
-- Bruce, Boise, ID
View Bricofleur's profile
Bricofleur
1450 posts in 3273 days
#7 posted 05-27-2017 01:36 PM
David, using a disk as spacer in that particular situation is very clever ! I must remember this one.
Great job buddy. You are quite smart !
Best,
Serge
-- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com
View Jim Bertelson's profile
Jim Bertelson
4192 posts in 3245 days
#8 posted 05-27-2017 03:55 PM
Some good ideas here, thanks for the tutorial…
-- Jim, Anchorage Alaska
View Joe Lyddon's profile
Joe Lyddon
10204 posts in 4133 days
#9 posted 05-27-2017 10:50 PM
Very good, David!
That 4” disk is the key to get the outer spacing correct to Code…
... after that, you will know How many slats you will need…
... you just have to join them in the center…
Very COOL approach… and Logic…
Thank you very much…
24122 posts in 3931 days
#10 posted 05-28-2017 12:34 AM
Well done buddy.
View htl's profile
htl
3997 posts in 1240 days
#11 posted 05-28-2017 03:22 AM
Cool have always loved this look!!!
Great How To!
-- Learn More About Making Wooden Models. An Index Of My Model making Blogs. http://lumberjocks.com/htl/blog/116729
View helluvawreck's profile
helluvawreck
31972 posts in 2947 days
#12 posted 06-02-2017 11:07 AM
David, you have done a fine job on this tutorial and I really like the design.
helluvawreck aka Charles
