J. Kellogg Jack Plane
Blog entry by nobuckle posted 09-01-2012 11:26 PM 3269 reads 0 times favorited 13 comments Add to Favorites Watch
Today I visited a local thrift store. While I was there I picked up an old wooden jack plane. Here it is;
As you can see it’s in pretty rough shape. I have to clean it up and make a new tote. The sole is not as flat as I’d like it to be and neither of the sides are square to the sole. I began to clean it up a bit and found a maker’s mark.
After some magnification and some investigation I discovered that it was made by J. Kellogg of Amherst Massachusetts. I came to this conclusion based on the shape and style of the mark. This website shows the marks used by James Kellogg.
The mark is located in the are circled.
The iron was made by the Humphreysville Mfg. Co.
After a bit of TLC I was able to clean up the blade and bring it to a nice keen edge.
Before I continue with this restoration I need some information. I need to know the best method for flattening the sole. I also need to know the best material to use to make a new tote. I think the plane is Beech but I’m not sure. Furthermore, I need to know if Boiled Linseed Oil is the only finish that one can use on a restoration of this type.
I look forward to your comments and suggestions.
-- Doug - Make an effort to live by the slogan "We try harder"
13 comments so far
View chrisstef's profile (online now)
chrisstef
17429 posts in 3035 days
#1 posted 09-01-2012 11:31 PM
Doug, ive been working on a transistional plane and needed to flatten the sole. I gave it a very very light pass on the jointer but stopped after one pass. If you get too deep it’ll open up the mouth too much. I went to sandpaper on glass just like a metal bodied. Litttle bit of 120 then to 220 and thats it. You can employ the method of pencil lines acroos the sole to see when its flat. I used BLO but i dont see a reason you cant use tung oil, walnut oil, or the finish of your choice. Id stay away from poly personally but thats just me.
BTW – i like the old woodie jacks, and the story behind it even more. Way to dig up the manufacturer info and savin it from the burn pile.
View KOVA's profile
KOVA
1363 posts in 2407 days
#2 posted 09-02-2012 05:32 AM
PARA APLANAR LA BASE, LO MEJOR ES LA LIJADORA DE BANDA: LA BASE Y LUEGO LOS LATERALES A 90 GRADOS ;-D
TERMINACIÓN: UNAS MANOS DE CERA PARA QUE SE DESLICE SIN DIFICULTAD ;-D
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
View nobuckle's profile
nobuckle
1120 posts in 2790 days
#3 posted 09-02-2012 01:23 PM
Here are some more pics.
nobuckle
#4 posted 09-02-2012 05:54 PM
I really appreciate the input all of you have provided. I am making progress with this restoration. I decided to use the sandpaper method to flatten the sole. Here is how it looks now.
I would still like to make the sides square to the sole but that would take away to much of the patina. Stay tuned for further updates.
nobuckle
#5 posted 09-02-2012 07:07 PM
Bill, to be more specific I prefer that the right side be square to the sole in order that I might use it in conjunction with my shooting board if need be.
View Don W's profile
Don W
18756 posts in 2596 days
#6 posted 09-03-2012 12:18 AM
Another one comes back to life. Nice job.
View WoodThings's profile
WoodThings
5 posts in 1944 days
#7 posted 02-26-2013 04:19 PM
I don’t know much about planes except that I think yours looks identical to mine, color and all, and mine is also missing the tote which I’m currently making from oak. Mine is stamped “Ohio Tool Co” in the same location as your label. The stamp is in a straight line with the rectangular background pressed inward making the letters stand out to the same level as the rest of the plane. The name is in all caps, italics and with serifs. I have rubbed the plane with sun-bleached linseed oil and it brought out a dark color. I think the plane is of oak but I’m really not sure.
Don W
#8 posted 02-26-2013 04:28 PM
woodthings, i have some ohio tools info posted here. http://lumberjocks.com/donwilwol/blog/24091
I think its probably chestnut which looks a lot like oak.
WoodThings
#9 posted 02-26-2013 10:32 PM
Thank you Don W for the information on Ohio Tool Co. I read some of it and will read more later. I was interested that you commented that my plane is probably chestnut. I have no experience with chestnut and wouldn’t recognize it as lumber or as a tree.
Don W
#10 posted 02-26-2013 11:52 PM
I’ve never come across a production made US plane made of oak. I have seen several chestnut however. I’m certainly not a wood bodied plane expert, so its just more likely its chestnut, but no guarantee.
View mariva57's profile
mariva57
666 posts in 2033 days
#11 posted 03-01-2013 09:52 PM
Hello nobuckle,
in my forum you can see the restoration of my planers
hand.
-- The common man thinks. The wise man is silent. The stupid man discusses.
nobuckle
#12 posted 03-02-2013 09:32 PM
Thanks for all of the positive feedback. Take care.
View Tugboater78's profile
Tugboater78
2746 posts in 2221 days
#13 posted 07-02-2013 02:54 AM
I ended up with a similar plane recently haven’t found a maker on the body yet but the blade is By the same manufacturer in process of making it useful. Gonna use the 3 part BLO,wax,mos to clean up the wood and see about flattening the sole.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
