The Beginnings of a Workbench
Blog entry by nobuckle posted 300 days ago 921 reads 0 times favorited 10 comments Add to Favorites Watch
I picked up these pieces of Maple butcher block at my local Habitat for Humanity Restore for $13.91. I plan to use them as the top of my workbench. I want to join them together at the ends to make one long top but I am unsure about how to do it. Any suggestions?
-- Doug - Make an effort to live by the slogan "We try harder"
10 comments so far
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
6589 posts in 815 days
#1 posted 300 days ago
Rip them down to 4” pieces and re-glue in a staggered, finger-joint style of interlock maybe? A lot of work, but it’d create an integrated top. Interested to hear what other responses you get.
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View BTimmons's profile
BTimmons
1162 posts in 681 days
#2 posted 300 days ago
I think Smitty has the right idea. You can’t count on simply butting the existing pieces together and expect them to be flat.
-- Brian in Arlington, TX - Laziness is the foundation of efficiency.
View Roger's profile
Roger
9479 posts in 1000 days
#3 posted 300 days ago
Should be a fabulous top. If there is a cabinet shop in your area, you may be able to have them run it through their industrial sized drum sander for a few bux.
View bladedust's profile
bladedust
124 posts in 463 days
#4 posted 300 days ago
I wonder if you can finger joint them and use a tortion box underneath to ensure flatness.
-- ok, is it cut once measure twice, cut twice measure once???? I know....I'll just keep cutting until it's long enough.
bladedust
#5 posted 300 days ago
View waho6o9's profile
waho6o9
3059 posts in 773 days
#6 posted 300 days ago
Spline joint?
Finger joint?
Domino it.
waho6o9
#7 posted 300 days ago
View MShort's profile
MShort
1396 posts in 1615 days
#8 posted 300 days ago
Looks like the makings of a nice new bench. Looking forward to the finished project.
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
View Robb's profile
Robb
644 posts in 2130 days
#9 posted 299 days ago
Just as an additional suggestion, if you didn’t want to rip it all down, you could Kreg screw / biscuit / tenon the pieces together at the joint. Then you could add additional support across the joint by gluing more stock across the bottom. I’d wager that after doing that, by the time it’s all supported by a strong bench frame, you’d have a very strong top. I think no matter which direction you go, it’ll be quite a bit of work to get that joint as strong as you’d like it to be. I’m interested to see which direction you pursue. Good luck!
-- Robb
View SPalm's profile
SPalm
4174 posts in 2078 days
#10 posted 299 days ago
Put a sunken tool tray between them – different but less work than staggered ripped sections. I doubt that a butt joint would stay really smooth over time.
Steve
-- -- I'm no rocket surgeon
