Using a hand chisel as a lathe chisle????
Blog entry by nobuckle posted 05-12-2012 03:22 AM 13551 reads 2 times favorited 19 comments Add to Favorites Watch
Okay, I just watched this video and was shocked by what I saw. This guy uses a hand chisle as a lathe chisle. Have you ever heard of such a thing? At first I thought he was going to use the hand chisle to remove some more of the high spots, you know, by hand. No, no, he uses it as some sort of scraper. It seems to work pretty well, but I sure wouldn’t put my good Marples through that.
-- Doug - Make an effort to live by the slogan "We try harder"
19 comments so far
View mikema's profile
mikema
180 posts in 2552 days
#1 posted 05-12-2012 03:50 AM
I have used bench chisels on the lathe. They work similar to how a parting tool would. One thing to remember, is most turning tools are simply a type of chisel. I wouldn’t use my pfeils on it as it will dull a chisel quick, but I have used my old craftsman chisels with good results.
I wrote most of this before watching the video. I think I would still use a good rough gouge to round the piece first, and if the lathe is moving too much, a) bolt it down, b) slow it down
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
View woodworkerscott's profile
woodworkerscott
361 posts in 2779 days
#2 posted 05-12-2012 04:44 AM
I don’t see a problem. It is the same principle as most lathe tools. I have tried a pocket knife on the lathe just for fun and it was a success. Can’t see any reason to not use a chisel.
-- " 'woodworker'.....it's a good word, an honest word." - Sam Maloof
View YorkshireStewart's profile
YorkshireStewart
1130 posts in 3867 days
#3 posted 05-12-2012 08:42 AM
Here’s a link to his way of turning with woodworking chisels
Unorthodox eh? Clearly it works very well for him.
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
View hunter71's profile
hunter71
3158 posts in 3152 days
#4 posted 05-12-2012 11:15 AM
I have made several specialty lathe tools out of all kinds of things. Actually on of my favorite custom scrappers is made from a plainer blade. Mind you, I am just turning small projects. I save any OLD OR WORN OUT HSS steel tools in a drawer for such special project needs.
-- A childs smile is payment enough.
View Roger's profile
Roger
20923 posts in 2769 days
#5 posted 05-12-2012 12:50 PM
Very interesting.
View hairy's profile
hairy
2655 posts in 3498 days
#6 posted 05-12-2012 12:56 PM
Check this out http://www.youtube.com/watch?v=8UuRonR575Q
The tang on a bench chisel is much shorter than a turning tool. You could get hurt .
-- My reality check bounced...
View willie's profile
willie
533 posts in 2420 days
#7 posted 05-12-2012 01:09 PM
I wonder how long his chisels will last if he sharpens them like lathe chisels. Constant grinding should make for a short life! I think I would have used a gouge for roughing first but he got what he wanted. I would imagine that if you wanted to use a handplane, you could do the same thing. It might work but it’s just not right!
-- Every day above ground is a good day!!!
View Alan S's profile
Alan S
181 posts in 3283 days
#8 posted 05-12-2012 01:31 PM
Aren’t most bench chisels made of carbon steel, whereas lathe chisels are high-speed steel? The bench chisel would dull much more quickly. I also worry about the tang length like hairy said.
Alan
View steliart's profile
steliart
2595 posts in 2654 days
#9 posted 05-12-2012 01:48 PM
What ever works for you… as they say
there’s no argument here
nice video nobuckle
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions
willie
#10 posted 05-12-2012 02:07 PM
After watching the video that hairy posted, tang length should be the least of that guy’s worries. That is an accident waiting to happen!
View David Kirtley's profile
David Kirtley
1286 posts in 2963 days
#11 posted 05-12-2012 02:42 PM
Well, a chisel is a chisel. Modern high speed steel tools are a pretty recent invention.
He is using horrible technique for a carbon steel chisel though. He is scraping which generates the most heat. He should be using it like a skew. Here is Roy Underhill doing the same thing…. (But a lot better).
View nobuckle's profile
nobuckle
1120 posts in 2726 days
#12 posted 05-12-2012 03:23 PM
I don’t want to give the impression that I think his method is wrong. I’ve just never seen anyone use bench chisels as lathe chisels. It’s obvious that this method works for him and I can see his point about spending the money for a good set of latrhe chisels. I’m almost tempeted to try it myself.
View derosa's profile
derosa
1572 posts in 2801 days
#13 posted 05-12-2012 06:51 PM
Actually CJ, handplanes will work just fine if you support them. I used one to finish sizing legs on the lathe by having a couple boards of the same height and slope. Worked perfect and didn’t seem to damage or bother the plane in the least.
-- --Rev. Russ in NY-- A posse ad esse
View NormG's profile
NormG
5955 posts in 2969 days
#14 posted 05-13-2012 02:52 AM
I have never used them. I have seen ther do so
-- Norman - I never never make a mistake, I just change the design.
View bandit571's profile
bandit571
19729 posts in 2649 days
#15 posted 05-13-2012 03:16 AM
Whenever I’ve wanted to make sure a cylinder was round, I would just sit my block plane up there at an angle, and go the length of the piece. Made nice little curly things. Plus, when the plane no longer bounced up and down, it meant that section was done. A big old wide chisel would sometimes work as a scraper tool, just to hit the high spots. It worked even better when it WAS dull, as it was more like a regular scraper that way.
