End Mill vs. Spiral Up-Cut Router Bit
Blog entry by nobuckle posted 04-07-2011 02:25 AM 4720 reads 0 times favorited 6 comments Add to Favorites Watch
Nothing special here. Just my thoughts on one type of cutter compared to another. In this video I put a 3/4” two flute high speed steel end mill in my router table to show how well an end mill will cut. The router is set at 10,000 rpm and I make two cuts that are around 3/8” deep. For me the issue is settled. But for you, will it be two flute end mill or spiral up-cut?
-- Doug - Make an effort to live by the slogan "We try harder"
6 comments so far
View Dusty56's profile
Dusty56
11819 posts in 3594 days
#1 posted 04-07-2011 04:54 AM
Good video . I’ve often wondered about end mills myself.
You mentioned the chatter marks …I think if you slowed down your feed rate , the cut would be smoother.
Thanks for this post : )
TopamaxSurvivor
18193 posts in 3582 days
#2 posted 04-07-2011 12:50 PM
Interesting video, thx
View nobuckle's profile
nobuckle
1120 posts in 2667 days
#3 posted 04-07-2011 03:19 PM
Dusty56, I would hesitate to slow the cutter down for two reasons;
1) My router will not go any slower, I had it set at it’s slowest speed of 10,000 rpm.
2) What I would do is increase the speed and not cut as deep. The groove that I created was about 3/8” deep.
Normally I would not make such a deep cut in one pass. Nor would I use such a large cutter, so the fact that I experienced some chatter was to be expected.
Dusty56
#4 posted 04-08-2011 03:29 AM
”if you slowed down your feed rate”
The feed rate is how fast you pushed the piece into the bit , not the speed the bit is turning at : )
nobuckle
#5 posted 04-09-2011 01:21 AM
Dusty56, please forgive me for mis-reading your comment. Yes, you are right. If I decrease the rate at which I feed the material across the cutter it may reduce the chatter. I’m only 42 and the senior moments are starting already. Thanks again.
Dusty56
#6 posted 04-09-2011 04:01 AM
Wait another 10 years !! LOL
Have a great weekend : )
