After gluing up the blank in the first part of this series, I moved over to the miter saw. I set the angle for 15 degrees, setup a 15 degree stop and a sub fence/base for zero clearance to minimize tearout.
I cut the 2×4 into a bunch of little pizza slices and got ready for the next step. That step involved finding out if my mitre saw read 15 degrees accurately!
Two half circles were made, and the pieces taped together. I didn’t have any of the fancy blue tape that those lucky guys that do veneering use, but settled for the green stuff that us lowly turners have on hand!
I pulled clamps from my dust collector pieces box, and daisy chained them together for my glueup. I was off by a smidgen so I used a chisel to keep the two halves taught. I’ll workout how to correct the error later. I was still thinking at this point.
After my glue was dry, I ran both half circles through the drum sander in order to make they perfectly flat and equal. This step may have been unnecessary as I’m going to have to do this again, as you’ll see.
After using a compass with the halves held together, to mark circles, I set the bandsaw table to 22 degrees and cut out my half circles. Many of you have guessed, by this point, where this little 2×4 is headed.
After cutting out the half circles, I glued them into rings. The error I had with the angle being slightly less than 15 degrees, was taken out with my tablesaw sled and a quick swipe. The rings took another trip through the drum sander, at this point, in order to make sure they had perfectly flat glue surfaces.
I then glued, stacked and clamped my rings! Those of you that guessed a hat from the band Devo? Well, you’re wrong! Close though! I was a little dissappointed in how little gluing surface I left on this. The bowl itself will be just around 1/4” thick. I think that, for a spruce bowl, this will really be a test to turn it.
With a little creative chucking, the project is starting to take shape! The wood was VERY dry, the step on the rings left for a VERY thin wall, and I had a heck of a time turning this.
After a lot of sanding and some very tentative turning to keep from blowing this thing into a bunch of pieces, out came the bowl. This is a picture of the bowl, the building block and some of the waste. Those of you that turn, know that that’s about 1/4 of the mess that came off the lathe. I kept the rim pretty thick for two reasons; the bowl had to be turned too thin because of the ring overlap, and with it being so dry, turning the rim was pretty exciting with the the wood so dry, so once it was round, it didn’t get too much more treatment.
Well, Mr. 2 X 4, I’m pretty pleased with what you had to show me! Thanks for looking, folks!
Cheers!
Tom
23 comments so far
scottb
home | projects | blog
3391 posts in 1205 days
posted 652 days ago
Awesome!
RobS
1231 posts in 1184 days
posted 652 days ago
Awesome and incredi-bowl. Great work.
-- Rob (A) Waxahachie,TX
2987 posts in 899 days
posted 652 days ago
Well done Tom.
USCJeff
899 posts in 946 days
posted 652 days ago
I’ll leave it at, “Wow”
-- Jeff, South Carolina
25271 posts in 1278 days
posted 652 days ago
Great job Tom.
Nice chips. The bowl isn’t too shabby either.
GaryK
9496 posts in 866 days
posted 652 days ago
Nicely done Tom!
lazyfiremaninTN
528 posts in 831 days
posted 652 days ago
Fantastic. Truely original.
rikkor
11338 posts in 752 days
posted 651 days ago
Holy cow! That is a fine looking 2×4. Are you going to stain it?
14089 posts in 1038 days
posted 651 days ago
and the salad looks delicious.
(great photo).
well done, Tom. Well done
toyguy
698 posts in 715 days
posted 651 days ago
I could have sworn it was going to be a hat from that band DEVO… But a bowl full of popcorn is cool too.
Russel
2030 posts in 817 days
posted 651 days ago
Way cool. Creative to say the least.
Tomcat1066
776 posts in 674 days
posted 651 days ago
OK, now that’s cool!
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
MorningWood70
30 posts in 663 days
posted 651 days ago
I think I might have to get a lathe now
-- Eric, www.themorningwoodshow.com
20040 posts in 700 days
posted 651 days ago
The imaginative effort that is present here is truly amazing. I can honestly say I will never look at a 2×4 in the same light anymore.
Thanks for the inspiration.
Patrick Jaromin
284 posts in 710 days
posted 651 days ago
Awesome. Color me impressed. And to think, growing up in Buffalo, NY I thought Canada was only good for Hockey, Labatts and Rush!
Strong work Tom.
-- Patrick, Chicago, IL http://www.TenonAndSpline.com/blog
mot
4901 posts in 914 days
posted 651 days ago
Thanks for all the comments, folks. I’m just going to leave it natural. I’ll take a picture of it with a light in the bowl. It’s paper thin. With it being so dry I might put some poly on it, but probably not. It was a really fun project to make, with lots of inspiration amongst the LJ community. I was showing my father some of the projects and he said, “Wow. Get that group together and with some 2×4’s you’ll not only build the house, you’ll furnish it too.”
Cheers!
Napaman
3409 posts in 955 days
posted 651 days ago
“That’s Incredible!” (remember that show???) Wow…tom…looks great….
mrtrim
1700 posts in 758 days
posted 651 days ago
great project mot well done !
Kerry
129 posts in 668 days
posted 651 days ago
Nice job Tom.
Kerry.
-- Alberta, Canada
Mario
880 posts in 929 days
posted 651 days ago
Very cool project.
-- Hope Never fails
Zuki
1218 posts in 955 days
posted 651 days ago
Excellent job Mot!!!!!!
jeanmarc
1750 posts in 594 days
posted 517 days ago
impressing. beautiful work
-- jeanmarc manosque france
Matt Vredenburg
47 posts in 292 days
posted 246 days ago
Very creative work. This just shows us all that we shouldn’t throw away all those short 2×4 scraps, well if you have room to store them all and don’t kill yourself tripping over them.
Mot – great job of turning a cool bowl turned out of pieces of 2×4. Awesome work!
-- Matt, Arizona
