Well, I procrastinated on this little project enough. Our two year old son, Mot Jr. (aka The Vandal,) needs a Christmas Gift from the shop. My daughter wants an iPod. What’s a guy to do. I settled on a plan from Lee Valley for a nice little rocker and started the build 2 nights ago.
I started by grabbing some wood from the rack. I chose red oak because it’s what I have in abundance and after an attempt to resist it’s downfalls, I’ve become quite used to working with it and it’s special considerations. (ie. end grain porosity and ease of tearing fibers)
After doing some remedial grain matching and layout, I started to cut some pieces to make panels. The plan calls for the grain running parallel to the lines of the horse, so a panel for the body, neck, head, and tail need to be made. Most of my wood is under 6” as I prefer these widths. Most of what we have around here is rift sawn, so it’s advantageous to glue up smaller boards, with alternating grain, to resist cupping. The Festool MFT 1080 and TS55 plunge saw made very easy work of this part of the project.
After cutting pieces, I jointed, planed and ripped them to dimension. My jointer is a short bed so I prefer to work with smaller pieces. As I’m not a production shop, I don’t mind not making perfect use of my time by jointing, planing and ripping larger boards and then cutting them. I’m ready to make some panels. As this is a toy that is going to be beat around I used the Festool Domino with 5mm domi’s to help strengthen and align the edge glued panels.
The panels are glued and ready for clamping. I use green tape to keep the squeeze out off my clamps. I’ve tried all sorts of other means like wax paper and the like, but a run of tape, put the panel on, then peel the tape up that isn’t needed to facilitate the clamp sliding to position and crank em down.
After the panels were dried, I scraped most of the glue off, ran them through the drum sander, instantly wished that I scraped more than most of the glue off and the proceeded to spend the next 2 hours scraping, planing and sanding the burnt glue streaks on my new panels. Lesson learned. I tossed away the destroyed abrasive on the Performax 16-32 and then spent another 30 minutes piddling around with putting a new strip on. This is not typically a time consuming thing, but I should have just left the shop and took my migraine to bed. I’m on a deadline now though.
I used the Domino and 8mm x 50 mm domi’s to join up the panels. I could have used Dowelmax to do this part, but I didn’t have any 2” dowels and I wanted to get as much glue surface area as I could. I hope you can see what I mean by the direction of the grain running parallel to the lines of the horse now.
This did present some clamping challenges, but the MFT1080 helped out alot. I could have used dogs on my bench too, but this surface isn’t piled up with tools and other crap.
I used a jigsaw and a Bosch blade whose teeth have a neutral rake, to cut out the shape of the horse.
And we have something that more resembles a horse.
I have to run and get some walnut for some inlays for the tack and to make the saddle. I’ll make up the legs tonight and get ready to make the rockers. I haven’t worked out how I’m going to do that just yet as I want it to be a rocking horse, not a wobble horse. The plan calls for a trammel, but to save some dust, I’ll make a template and then pattern route them
The build continues!
Cheer!
Tom
7 comments so far
home | projects | blog
2991 posts in 900 days
posted 694 days ago
Great project for you Tom, you get to use lots of tools and your little man will be pleased as punch.
That will probably become one of those cherished family heirlooms.
When are you starting work on building the iPod?
Cheers
Thos. Angle
4015 posts in 841 days
posted 694 days ago
looks pretty horsey-fied. Why not a pony for the boy?
-- Thos. Angle
25279 posts in 1279 days
posted 694 days ago
A true request from the cowboy. Looking great for the Faux horse.
mot
4901 posts in 915 days
posted 694 days ago
Bob, you were supposed to come to the shop to help with the iPod. Any project where I get to use lots of tools is on the short list!
Tom, I’ve got place to keep one, and people to take care of it when we can’t, but I’m not a horse person. Personally, I’d rather wrestle a crocodile than ride a horse. I might take a spin on this one when it’s done though.
3709 posts in 858 days
posted 693 days ago
Hey Mot;
May I suggest a custom saddle from Tom, when your done with the horse?
Nice job!
Don’t worry about wasting time with lessons learned. They seem to be the ones that stick! The more painful, the better remembered.
mot
posted 693 days ago
A custom saddle…hmmmmm….not bad, Lee…not bad!
bryano
546 posts in 812 days
posted 693 days ago
Nice job Tom. Looks like labor of love.
-- bryano
