Jigs and Fixtures #2: Dowel Stock Preparator!
Blog entry by mot posted 713 days ago 1680 reads 9 times favorited 21 comments Add to Favorites Watch
« Part 1: Jig for hand planing small parts. Part 2 of Jigs and Fixtures series Part 3: Shooting Board Basics - VIDEO »
I’ve been fiddling with wooden hinges, and can’t get good dowel stock. Epecially dowel stock that matches the species of wood I’m working with. I gleaned this jig from another Rob Cosman video.
I took a 2” piece of walnut from the scrap pile. I drilled a 1/4” (0.247” actually) hole in it close to one face. I took a few passes through the drum sander to just show the hole cut. I chamfered one end to accept the workpiece stock. I clamped an old plane iron creating an awkward looking jig.
My first pass came out too thin. I clamped a playing card between the iron and the walnut. My second attempt came out at 0.247”. Blind ass luck to get it that close, however, my intent was to go for that diameter, so 2nd attempt or 12th attempt, I was in for the long haul.
Here’s the process of making the dowel:
I started by ripping a few 5/16” strips from the stock I’m using to make my box. Sorry Niki, I used the GRRipper. I don’t think it’s an accident waiting to happen. I use the GRRipper in conjunction with the MJ Splitter.
After I get a piece of oversized square stock, I chuck it up in my hand drill and use the belt sander to sharpen the end of it to go into the jig.
I wanted to knock off the edges to make more of an octagon to relieve stress on the jig. I could have done this on the tablesaw with the blade at 45, but this isn’t a precision maneuver, so I just used the belt sander. Next time I’m going to use a small parts clamp I have to knock the edges off first, then sharpen the end. This way, I had to hold them with my fingers, risking a slight manicure while I was doing it. I might have used the GRRipper for this too, but would have just been to torment, Niki.
I chuck the stock up in the drill, and then head to the jig.
This is a picture of the stock part way through the jig.
When I get near the end of the stock, I reverse the drill, chuck up the other end, and pull it through.
And the finished dowel, sitting atop my little jig.
Thanks for looking!
Tom
21 comments so far
View David's profile
David
1982 posts in 1031 days
posted 713 days ago
Hey Tom -
I think we are watching the same videos! I am working on the same thing. I am experimenting with using set screws to adjust the angle and set of the blade. Awesome job!
David
View mot's profile
mot
4902 posts in 929 days
posted 713 days ago
David, I would have probably come up with a better way to ajust it if it hadn’t of come out spot on so quick. I’m not touching it now. Maybe my other size jigs will be a little more sophisticated, by this little 1/4” baby is a lock.
View Blake's profile
Blake
2758 posts in 767 days
posted 713 days ago
Very cool!
I wish those Grrippers weren’t so expensive. They look so handy.
View Buckskin's profile
Buckskin
484 posts in 880 days
posted 713 days ago
Thats a cool jig!
View Mike Lingenfelter's profile
Mike Lingenfelter
457 posts in 1006 days
posted 713 days ago
I was watching Rob’s video again the other day and thought I would try the wooden hinge soon. Are you making a box for the LJ contest?
-- http://theinquisitivewoodworker.com/
View mot's profile
mot
posted 713 days ago
Thanks for the comments. Yes, F.Luna, it’s now the dowel plane!
Mike, I’m making the box for another purpose as I get the bugs out of the process. My prototypes are working fine and I’ve made jigs to set my fence and router bit height for a 1/4” hinge so that I can recreate the setup without too much fuss. As for the contest, that hinge may make an appearance.
View Russel's profile
Russel
2057 posts in 831 days
posted 713 days ago
Wow, why didn’t I think of that? Oh yeah, I’m not that creative. I was just thinking I needed some dowels earlier today. Very cool.
View YorkshireStewart's profile
YorkshireStewart
782 posts in 793 days
posted 713 days ago
I love that jig – so simple, effective and FREE!
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
View Thos. Angle's profile
Thos. Angle
4015 posts in 855 days
posted 713 days ago
Great invention, Tom. Stanley made a dowel maker years ago. Every once in a while I’ll see one or the head which cuts the dowel. I’ve passed them up but now might not. besides this is just too simple. And way too easy. Good one, Tom
-- Thos. Angle
25795 posts in 1293 days
posted 713 days ago
Great idea Tom. Nice job.
Dick, & Barb Cain
7034 posts in 1192 days
posted 713 days ago
Neat jig Tom!
It works similar to my dowel maker jig, But you don’t have to contend with a noisy router.
View mot's profile
mot
posted 713 days ago
Dick, that’s a hell of a setup… Franken-Doweler! I was pretty pleased with how quickly I got this one accurate. I’m going to be using the doweling for a little project so I’ll probably have to finagle a bit to match the radius of a router bit that it’s going to match up with. I’m interested in seeing what David’s refinements are as he’s taking into account blade set which I did not, aiming more for a pure sheer cut. For banging out quick dowel though? Man is this thing a cinch.
View Peter O's profile
Peter O
1016 posts in 767 days
posted 713 days ago
Has anybody used Dowel Plates? These have been on my wish list for awhile. Anyone willing to give a recommendation?
-- http://www.north40custom.com -- http://north40studios.etsy.com --
posted 713 days ago
I’ve not used the dowel plate that you showed.
View Hawgnutz's profile
Hawgnutz
522 posts in 969 days
posted 713 days ago
Very cool. Tom! With a varied set of drill bits, the options of dowels available would be unlimited! It sure saves the $45 for teh Lie Nelson dowel maker!
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View cajunpen's profile
cajunpen
5970 posts in 958 days
posted 713 days ago
Great Tom. I have that Rob Cosman video too and you make the jig construction look a lot easier than he did :-)). I guess I’ll give it a shot too. Thanks for the very informative post.
View RobH's profile
RobH
460 posts in 942 days
posted 713 days ago
Well, fiddlesticks. I just ordered a dowel making jig from Lee Valley. I may have to go home tonight and give this a try. If it works I might send the Lee Valley jig back.
This is really cool. Thanks for sharing.
-- -- Rob Hix, King George, VA
View GaryK's profile
GaryK
9521 posts in 881 days
posted 680 days ago
Great jig! That’s going in my favorites.
View Jiri Parkman's profile
Jiri Parkman
604 posts in 705 days
posted 656 days ago
Great.
-- Jiri
View WayneC's profile
WayneC
5963 posts in 990 days
posted 655 days ago
The dowel plate seems to work well for shorter dowels. I’ve got one.
View stefang's profile
stefang
1643 posts in 226 days
posted 57 days ago
That looks like a good jig and it was a great blog. I do it in a different way which you might also like.
I drill the most common size holes in a mild steel plate at 45 degree angles. This leaves a sharp edge on the top of the hole. I cut some square stock in the appropriate size, sharpen the end enough to fit into my drill chuck like you have done. After chucking it up, I run the piece through the angle hole and I have a nice dowel exactly (or exactly enough) the same diameter as the hole.
The only set-up required is to put the steel plate in a vice and make sure there is clearance underneath the plate for the dowel to come through. Eventually the steel plate will become dull, but it’s not difficult or expensive to replace.
-- Mike, American in Norway
