Hi Folks,
Here’s Part II of my Turning a Bowl Series: Hollowing the Bowl.
Thanks for watching and I hope everyone had a great weekend!
Tom
| Blog entry by mot | posted 848 days ago | 1018 reads | 1 time favorited | 14 comments | ![]() |
| « Part 1: Turning the Bottom | Part 2 of Turning a Bowl series | Part 3: Finishing Cuts, Sanding, Oil » |
Hi Folks,
Tom
| Latest Projects | Latest Blog Entries | Latest Forum Topics
14 comments so far
Douglas Bordner
home | projects | blog
3421 posts in 957 days
posted 848 days ago
Mot-
Great job! Just noticed that when you say “friends” in the CyberSkillShare intro, you sound just the slightest bit like Fred (Mr.) Rogers.
You mentioned something about wall thickness being “too thick for solid wood” (not an exact quote). Is there a hazard to the bowl in some regard if walls are let too thick? Made me wonder if wood moving across the width of the grain would cause a split.
Second, nice teaching point to point out the changes in the sound of the scraper as the bowl wall thins.
You inspired me to hit the now dwindling boxelder stash over the weekend, so the video is having the desired effect. Thanks for the time and effort put into the series.
14156 posts in 1054 days
posted 848 days ago
well done – again.
It is fascinating to watch a bowl develop.
The video really helps with the tips – rather than the written word. We can “hear” the lessons as they happen
scottb
3402 posts in 1221 days
posted 848 days ago
Funny Douglas, I heard the same thing!
mot
4901 posts in 930 days
posted 848 days ago
I’ll shoot a new intro with me changing into my inside shoes. LOL. Douglas, there isn’t really a problem with wall thickness in a dry bowl. My comment was more motivated by a wet wood bowl where it’s good to leave a fair amount of wall thickness in order to be able to turn the bowl round after your chosen drying method. As far as the dry bowls go, I could have tuend that one thinner, I just like some meat to my bowls.
Joel Tille
214 posts in 1138 days
posted 848 days ago
Thanks Mot – I have tried to turn a couple of bowls, it sure seems easy. They turned out ok, but i will continue to watch and pick up tips that will help me.
Thanks,
-- Joel Tille
scottb
posted 848 days ago
Hey Darth Tater… you needs ta change your signature line… or is Potato Parker dressed up for a Sci-Fi Con?
WayneC
5981 posts in 991 days
posted 848 days ago
Great video Tom. Looking forward to your next one.
Dorje
1767 posts in 891 days
posted 847 days ago
Alright! Thanks Tom – I’m all caught up and ready for number 3!
I’m with Douglas; I may have to set up the lathe this weekend and have a go (if I’m lucky)! Haven’t done that for awhile. No box elder for me though! Drats!
PanamaJack
4447 posts in 971 days
posted 847 days ago
Tom, Great Job! Thanks for sharing with us. Lots of good insite.
-- Carpe Lignum - Seize The Wood,
Cathy Krumrei
344 posts in 1080 days
posted 742 days ago
I enjoyed the video, these are great for a novice like me! ? what is the reason of having the hole in the middle first? (see a real novice ?) Is it the centering point? Do you drill this or use the tool? Where is the first video? I see I am going to have to sweeten up Santa for some tools. Thanks for any info.
Krum
-- Cathy Krumrei
mot
posted 742 days ago
Hey Krum,
If you look at the top of the page, you’ll see the navigation to the first part of the series as well as the rest of the series. The hole is drilled to accept the screw from the chuck for turning the bottom of the bowl. I show why in the first video. The series is a chaptered blog with the first part here.
3037 posts in 915 days
posted 742 days ago
Another good “seggie” Mr. Mot.
Bob ( Still AKA ninefinger)
Napaman
3486 posts in 971 days
posted 705 days ago
awesome…
PhilipR
17 posts in 680 days
posted 678 days ago
It was nice to see you using the scraper so extensively. I had been told by several turners prior to watching your video that the scraper is really only good for finishing cuts, but you obviously used it for more than that. When I tried using a scraper recently (first time actually) on the inside of a bowl, I found it difficult to control. The scraper seemed to want to cut in very easily, so I would react by pulling back. In the end, once the bowl stopped turning, it looks like the scraper bounced along the inside of the bowl leaving little divots all over the place. I guess practice makes perfect!
Thanks for a great video!
