Tools #3: Incra Mitre Express / Incra 1000SE Mitre Gauge - VIDEO
Blog entry by mot posted 904 days ago 1518 reads 0 times favorited 12 comments Add to Favorites Watch
« Part 2: Veritas Mk.II Sharpening System Quick Review - VIDEO Part 3 of Tools series Part 4: Nova DVR-XP Standing Coin Test - VIDEO »
I wanted to add to the mitre gauge posts. Wayne posted a photo tour of the Jessem System, and David posted initial impressions of the Kreg System.
The incra 1000SE is seen here in the Incra Miter Express sled. Both are available at Woodpeck.com You can see the kerf where the mitre sled straddles the blade in the tablesaw allowing for the cutoff piece to be coplanar with the workpiece. This decreases the chance of the saw flinging the cutoff piece back.
The Incra guage is adjutable in half degree incriments with detents every 5 degrees from +90 to -90 degrees.
The mitre bar is extendable for longer cross cutting applications by loosening a set screw and extending the bar.
The stop block is microajustable with both gross movement, and ultra fine movement for repeated cuts.
The mitre gauge easily moves to +/- 90 degrees and is stabilized in the sled with two set screws. These are not necessary but they are a nice addition. The mitre gauge moves forward or back in the sled in order to always be able to support the workpiece.
The sled has a hold down that slides along it’s entire width for stock of varying widths and thicknesses.
Here is a video of the operation of the sled:
12 comments so far
View WayneC's profile
WayneC
5962 posts in 989 days
posted 904 days ago
Great video Tom. Thanks. Looks like a great tool.
View David's profile
David
1982 posts in 1031 days
posted 904 days ago
Tom -
Another excellent K & T Woodworking video episode! The Incra is an awesome system. Thanks so much for this posting! Looks like that new camera is working out well. Excellent job linking the three systems. I think this will be a good resource for anyone looking at a miter gauge upgrade.
View foneman's profile
foneman
16 posts in 986 days
posted 903 days ago
Tom,
The video is great and show some excellent points I was unaware of with the Miter Express. I really like all of your videos!!!!
John
25794 posts in 1292 days
posted 903 days ago
Great Video Tom. I have outfitted my sliding table with the incra track so that I can use the micro adjust and I’ve also put the extension slider in each end of my track so that I can extend it closser to the blade.
When I extend the extension on the left I can go greater than 8’ so I can make cutoffs from plywood to the 1/32” scale.
I like incra systems.
View mot's profile
mot
4902 posts in 928 days
posted 903 days ago
I hear at the end of the video I referred to “David’s Jessem Setup.” I meant, of course, Wayne’s. I have to start scripting these. I was laughing at the beginning…not only the headless woodworker, but the stacatto woodworker. I started the videotaping and forgot what the sled was called so I was trying to read the sticker with the sun glarring at me. LOL…The biggest tool in my shop is me. Thanks for watching!
WayneC
posted 903 days ago
Lol David and I are interchangeable except for in the Emergency room.
View furnitologist's profile
furnitologist
190 posts in 905 days
posted 786 days ago
Hi Tom:
I was wondering about the extra table on the right side of the blade. Does that table slide forward with each cut or is it pretty much stationery. Magnet, snug fit or something????
This is the second time I’ve come back to the video….......this winter I plan on more solid wood and my excalibur mitre fence gets in my way. If I go with your Incra here, I can still rip panels, but not have to deal with my current fence which is great for sheet goods, best word would be “clumbsy” with smaller solid wood pieces.
Thanks…...................Neil
View mot's profile
mot
posted 785 days ago
Hi Neil,
The right hand table has a guide that fits into the right hand mitre slot. The table gets positioned before the cut, but does not slide with the cut. I hope that helps.
Tom
View Dorje's profile
Dorje
1768 posts in 889 days
posted 642 days ago
Tom – just when I’m ready to watch this (I’ve been putting off getting a decent miter gauge), the video doesn’t seem to play. Any way to fix it? The intro and end are there but no middle Incra content…
View mot's profile
mot
posted 641 days ago
I’ll take a look at it Dorje. There was another video that doesn’t seem to be playing on Jumpcut, either. I may have to move them all to Blip.
Dorje
posted 641 days ago
Thanks! Look forward to viewing it!
Dorje
posted 640 days ago
Thanks for fixing this up – that was a ton better than the Incra promo video (which gives you 28 seconds of info – just not enough). What a great complement to the text reviews I’ve read…
Thanks Tom!
