simple and effective holddowns
Blog entry by moshel posted 181 days ago 508 reads 6 times favorited 9 comments Add to Favorites Watch
I have been looking for a way to add holddowns to my benchtop for a while. All the plans i saw called for either complex cuts or glueups or special hardware or reaching under the bench.
I ended up with making these, which I find so far VERY satisfying. Actually, they are much better than i thought they would be. The overall cost for the pair is ~5$.
ok, lets do it:
From 270509 hold down
these are the things you need:
1) 2 lengths of threaded rod (i used 8mm). they should be (the thickness of your bench) + (the thickness of the work you aim to hold) + 3-4cm. don’t make them too long, it will make work awkward. you can make another set of longer rods if needed. I used 15cm pieces of rod
2) 2 knobs that fit the rod you used. i used knobs from hafele just because i had some. you can make your own knobs from t-nuts and piece of plywood the niki way.
3) 2 heavy washers
4) two pieces of softwood (I used Douglas fir)
5) some T-nuts that fits 8mm rod
Thats all!
Drill some 10-11 mm holes in your bench all the way through where you want the holddowns to be. I drilled 8 holes. use the threaded rod, the washer, a nut and a spanner to pull the t-nut firmly into the bench on the bottom of the holes. this is how it looks from below.
Assemble the holdowns: knob, washer and piece of wood all on the threaded rod
to use, just drop the holdown into the hole and turn the rod several times so it will catch the t-nut. now adjust the knob.
sometimes when the edges of the piece are fragile, you might want the pressure to come from above. one way to do that is to notch the piece of timber (wide V). I just put another piece of timber on the back.
and they can also be used as a very versatile bench stop (that can have an open section in the middle or slanted sides)
-- The woods are lovely, dark and deep, but I have promises to keep...
9 comments so far
View kiwi1969's profile
kiwi1969
601 posts in 336 days
posted 181 days ago
thats what I call useing the K>I>S>S principle. I like this idea a lot. Thanks
2379 posts in 235 days
posted 181 days ago
wonderfull !
after long and extensive thought and trials ,
in the end
the simplest
are the best !
if only we could
find them first !
thanks !
View Splinterman's profile
Splinterman
4826 posts in 255 days
posted 181 days ago
Simple and effective.
View tmblweed0429's profile
tmblweed0429
42 posts in 205 days
posted 181 days ago
Very clever idea. I can’t believe we haven’t seen such a great idea before… I will have to try that on my bench.
-- Trent Tidmore, Grapevine, TX
16776 posts in 471 days
posted 181 days ago
If it works go for it well done
View stefang's profile
stefang
1647 posts in 228 days
posted 180 days ago
Great idea. Keep them coming, we (I) need them!
-- Mike, American in Norway
View Moai's profile
Moai
721 posts in 288 days
posted 180 days ago
smart solution!...thanks for sharing!
-- Francisco Luna, San Francisco Bay Area.
View moshel's profile
moshel
478 posts in 578 days
posted 180 days ago
Thanks all,
its simple, it works, I made it and I can make as many as I like in minutes – I think that workbenchs and hold downs should be simple and that you should not worry all the time that you will scratch your workbench or damage your hold downs – they are tools, not art form
View Dusty56's profile
Dusty56
3462 posts in 582 days
posted 178 days ago
Nice idea …thanks for sharing it with us : )
