wooden winch #3: holes and bottom frame
Blog entry by moshel posted 08-24-2010 05:56 AM 2480 reads 0 times favorited 6 comments Add to Favorites Watch
« Part 2: the pole Part 3 of wooden winch series Part 4: upper frame »
First, I drilled the holes for the handles, here it is with one 3/4” pipe in place (I don’t have two…):
I also added screws to help with the shearing force. not sure if it was wise:
another addition was more screws to hold the parts of the circle together, as i was afraid the edge will catch:
now I could set my mind on the frame… first comes denailing. For those of you who never worked with recycled timber, here is a photo if a relatively easy to denail piece of Rimu:
usually each piece has about 10-20 nails per meter… the worse ones are the 3 3/4. they nailed them into the frame while the timber was still wet and it shrank around them. very hard to denail…
Lengths of timber were cut to length (about 1.2M long) drilled, counterbored and joined with coach bolts:
Couldn’t resist a small test:
So far so good!
now for the vertical supports:
they were actually pretty hard to put in place as I only had 4” bolts so had to drill deep. I should also get some extra long drill bits. I should have gone with different joining method, as i think this will make the bracing too weak.
Finally for today, the back brace:
If you are wondering what is the black arrow, its just marking a nail that was broken in the timber.
tomorrow i wont be able to work on this, so i am not sure it will be ready for the weekend.
worse comes to worse, i’ll bring it with me and finish it there.
Thanks for reading!
-- The woods are lovely, dark and deep, but I have promises to keep...
6 comments so far
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3526 days
#1 posted 08-24-2010 06:33 AM
We have got to see how this works! Really cool projrct!
View moshel's profile
moshel
865 posts in 3683 days
#2 posted 08-24-2010 07:23 AM
i would bet good money on it splitting to pieces in the first field test :-)
no matter, i can rebuild it. I have the technology. I can make it better, stronger, faster…
(I do hope anybody still recognize the quote. I feel so old sometimes)
View SPalm's profile
SPalm
5320 posts in 3881 days
#3 posted 08-24-2010 02:07 PM
This has been fun to watch.
I think your pipe(s) is going to bend. Pipes are not very strong. So maybe bring along some timber that could be used to replace them. I don’t know where you could get hardened metal rods of that length for cheap.
Can’t wait to hear how it works,
Steve
-- -- I'm no rocket surgeon
moshel
#4 posted 08-24-2010 02:14 PM
I also have uncomfortable feeling about the pipe. might have to “stiffen” it with some timber. I can’t really make the hole any bigger without making the pole very weak.
View helluvawreck's profile
helluvawreck
31092 posts in 2866 days
#5 posted 08-24-2010 02:24 PM
Now what exactly is it that you are going to pull with this? I’ll have to go back to the beginning.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3712 days
#6 posted 08-26-2010 05:27 AM
Hopefully it will cost you less than 6 million to rebuild it….yup I recognize the quote :-)
