I have to apologize for not taking pictures while building it – thought about it only later. there are some photos of the end of this stage at the bottom of the page.
So, I looked at my timber rack and found that the only reasonably sound “beam” I had is 3×4. However, it was a wonderfully dense heart Rimu. So, I denailed it (hard work – its from recycled buildings and taking out these 3 3/4” nails out of it is really hard) milled it to just under 3×3 and started experimenting with making the round parts. I started with cutting on the bandsaw Rimu arcs that would “complete” the square to circle. this did not work well. the parts were too thin and splitted the minute any force was applied to them.
So, plan B. I cut circles of 1” oak on the bandsaw, marked the square on them and then cut the inner square (extending the lines) so I got two L shaped pieces that when joined together makes a circle with an empty square in its middle. hukked them in place with 2” screws – I hope this will hold…
Next – the ribs. denailed, milled and cut some more Rimu to 2X2, made a template for the arc, maked and cut the arcs on the bandsaw. attached it in place using 2” screws again – this should hold as the forces on the ribs actually hold it together.
I have also denailed milled and bandsaw the supports for the collars, but didn’t take pictures – beefy pieces of 8×2 heart Rimu – they take most of the load so should be strong.
Last thing for today – I am worried about the thickness of the pole, so I am beefing it up with some oak. I have just glued it in place so will continue tomorrow to drill the holes for the handles and add some bolts to prevent the pole from splitting from the force.
Here is what I ended with today:
-- The woods are lovely, dark and deep, but I have promises to keep...
6 comments so far
Kindlingmaker
home | projects | blog
2650 posts in 1723 days
#1 posted 1030 days ago
You really are having too much fun! Wish I were closer to watch this !
Dennis Fletcher
455 posts in 1251 days
#2 posted 1030 days ago
Wow, can’t wait to see how this folds out.
-- http://www.ahomespecialist.net, Making design and application one. †
helluvawreck
10904 posts in 1063 days
#3 posted 1030 days ago
This is great; we will be waiting to see how it turns out.
Dennisgrosen
10851 posts in 1312 days
#4 posted 1030 days ago
good luck with it :-) I will follow the progress with excitment
if you have to drag the chunk of wood over the ground with the winch
then make some rollers you can put under as the vikings did when they transport
there Dragonboats over land
it work little like the belt on a Tank
put the rollers in from the front for every ½ -1 meter and when they come out in the back
you simply take them up and walk to the front with them and put them down again
it will be 30 times easyer for you to do it that way
if its still too havey for you then use two dubble tackle-blocks on the robe
best wishes for your little big project :-)
Dennis
Edit: the tackle-blocks work like a gear
we have used both tecnics many times as boyscouts
moshel
845 posts in 1880 days
#5 posted 1029 days ago
Dennis, we are going to use rollers (it is mentioned in the background section). and block and tackle. and 5 man…
I actually made the pullies myself. maybe will write a blog about them if they work well.
still, moving a log like that is not trivial…. not trivial at all…
Dennisgrosen
#6 posted 1029 days ago
sorry it slip thrugh when I was reading the first blog
I was a little pisst on my down load (cuoldn´t get the vidio the first 10 times)
I called my Daughter to see it (ten year) and she was blown away over the tecnic in it :-)
and you are right about moving havey stuff like this, you have to stay on your toes
it can easely go wrong….....lets hope not :-)
take care
Dennis
