the box #3: the top
Blog entry by kolwdwrkr posted 09-08-2008 01:08 AM 950 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 2: next step Part 3 of the box series Part 4: the end »
Now that the box was complete it was time to make the top. This part is fairly easy so I won’t go on into a spill about it. My first step was to cut the pieces to width. After that I installed the dado set on the saw so I can cut my groove in the edge to house the panel. After running my groove I set up the miter gauge again with the sacrificial fence and cut my pieces to fit the leather. I decided that I needed to put an inlay in the top too. So, I ran a shallow groove on the inside of my pieces to allow for the inlayed border. After the parts were made I dry fitted them together and then proceeded with the final assembly. I glued the parts together and used the band clamp. After it dried I sanded it. I only want to sand it flat at this point so I used 120 grit sandpaper.
Now came the fun part. I decided to put some “bow ties” in for the joinery. I figured it would be a good compliment to the dovetailed keyed miters in the box. To make these I set up the router table with the dovetail bit. I raised the bit to a satisfactory height and pulled the fence forward. I ripped some stock on the table saw and started the set up. After centering the bit on the stock I ran it for the 4 passes it took to make the piece. I then cut them down to 3/8” thickness’s. I set up the bosch colt palm router with a 1/8” bit. I set it’s depth to 5/16”. This way I could sand the pieces flush. I marked all of my corners using one of the pieces of inlay, then routed close to the line. Taking a Japanese chisel, I cut out the remaining material to my line. I glued and tapped the inlays into place and let them dry. Again I sanded everything flush first using 100 then went through the courses to 150. The top was almost complete. I just had to do the inlays….............
top 1
I am hiding one side of the top for a reason. We’re not that far folks. LOL
top 2
5 comments so far
23578 posts in 3760 days
#1 posted 09-08-2008 06:30 AM
kolwdwrkr, great technique & excellent finish.
6847 posts in 3889 days
#2 posted 09-08-2008 01:36 PM
kolwdwrkr;
Great job on the top.
It’s looking real good.
Nothing like a good quality Japanese chisel.
I love ‘em.
18615 posts in 4070 days
#3 posted 09-08-2008 04:00 PM
the anticipation!!!
View cabinetmaster's profile
cabinetmaster
10874 posts in 3467 days
#4 posted 09-09-2008 01:42 AM
Ok, Why the drama?........................ That box is really looking good. Can’t wait to see all of it…..
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3499 days
#5 posted 09-09-2008 03:26 AM
no drama, just a box
