Entertainment Center #5: Day 6
Blog entry by kolwdwrkr posted 02-14-2010 05:42 AM 1901 reads 0 times favorited 8 comments Add to Favorites Watch
« Part 4: day 5 Part 5 of Entertainment Center series Part 6: bleed through »
Well I was anxious to start the day priming today. I went out to see where I left off and to my surprise EVERYTHING needed sanding. I thought I did a lot of that and was almost done with it. If I had to guess I was thinking I was done with it because I confused it with a job at work or something. To top it off I must have put the crap face in on a few of the pieces. It looked better at the time, but upon closer review the fibers are raised and torn.
To remind you all I’m not usually the painter, and nobody has complained about materials before. I can assure you I will pay the extra money next time for a better grade of ply. I used maple, just shop grade. This is a budget job, but I’ll probably have more time in fixing crap then if I would have just bought better material. So lesson learned and shared. So out came the bondo to do some patchwork. That took forever.
So once everything was bodoed and sanded I set up the airless. Turns out the gasket on the tip was shot so off to the paint store we went. Let me tell you right now, if you want something from Dunn Edwards go far in advance. The wait is rediculous. It’s like the workers busy themselves with things just to put you off. Then when they help you it’s like they don’t know what they are doing. I wanted the simple little rubber washer and had to buy the whole tip. And to find that out he had to go to the back to ask someone, and came back with 0 information. So I told him I just wanted to buy item pointed at and $20 later I had my little rubber gasket. They didn’t have the size I would need of tip, so I still had to use the one I had. So literally $20 for something the size of my pinky nail. Talk about a rip off, and a $40 minute ding in my day.
Anyhow, we carried the cabinets through the house into the back yard, making sure to bang them a few times on the way through. After a little sanding I started priming. I went like a mad man and still didn’t get everything. And it so happens that the primer I had to get takes 2 hours before I can recoat. I had to get the Eco Shield because the homeowners kid has super alergies and could possibly die if he happens to smell wet paint. Whatever, that’s new to me. They didn’t ask for formaldahyde free material so I would assume that would be worse. AANNYHHOWW I finally got the priming done on what was ready by 7 tonight and began the process of banging them off the walls and doors on the way back out to the garage. Yippee, tomorrow I can try to fix the damage and reprime. I’m leaving the center section in the garage this time. Heavy turd. So I put plastic over some tools and put paper on the floor. It should be safe there until we bang it against the homeowners doors and walls while installing. LOL.
So here is the progress of day 6. Tomorrow it will look the same, maybe whiter. LOL. But hey, maybe I’ll post anyhow. Who knows.
as always I welcome constructive criticism, positive or negative.
8 comments so far
TopamaxSurvivor
18248 posts in 3643 days
#1 posted 02-14-2010 05:47 AM
Looking good from here Kieth :-) Those little lessons of saving a buck in material are never forgotten are they! BTW, take some spackle for the homeowners walls and save a trip ;-)) :-))
117063 posts in 3544 days
#2 posted 02-14-2010 05:47 AM
Hey Keith
The Paint grade cabinets are supposed to be the easy ones LOL
TopamaxSurvivor
#3 posted 02-14-2010 05:49 AM
That’s only if you use the 1/4” thick self leveling paint!
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3557 days
#4 posted 02-14-2010 05:57 AM
I think I will start charging more for paint grade then stain grade. The bondo is what is supposed to make it easy because you can fill all the voids, damage, etc. But the paint isn’t forgiving and finds every little tiny void and sags in it. Then it looks like crap. I stopped using wood fillers for the nail holes because it sags. I use bondo on everything. (paint grade obviously) But in crappy garage lighting you can only see so much as well. I guess I need to set up my work lights. It’s all a good experience though. I need to refresh my paint skills. I relied on to many people all the time to do the work. I am trying to do this project with only help from Heidi with the sanding and help from my brother with the heavy lifting. Other then that I’m on my own. Have to see how long a build should take start to finish so that I can do job costing. My pricing is starting to look to low. LOL
Beginningwoodworker
13345 posts in 3640 days
#5 posted 02-14-2010 06:01 AM
Looks good.
13600 posts in 3308 days
#6 posted 02-14-2010 06:09 AM
keith ,
after all that ,
i does look good !
i wish there was some kind of warning light ,
for some of these jobs ,
then you could just say no ,
and walk away .
View beginrbldr's profile
beginrbldr
99 posts in 3010 days
#7 posted 02-14-2010 06:42 AM
Dont mind the ding I put on the left upper cab. lmao
-- Jeff, Laguna Hills CA
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3253 days
#8 posted 02-16-2010 12:24 AM
Ah! A typical day in the life of a woodworker. I don’t paint much anymore, but for years I did. Gee, I don’t miss it at all.
Hang in there. A year from now you won’t remember the frustration.
-- http://shepherdtoolandsupply.com/
