I’ve been building a fence here at the house I’m renting (see blog). I ended up getting 2 sections out of one board as opposed to the 1 section I originally thought so I figured I’d use some of the material for a couple of projects. The first one is this bench, the second will be a carved screen door. This project is going to be a little tricky because I don’t really have “fresh” materials, nor do I have the thickness’s I would buy if this was going to be a project I wasn’t just throwing out there. In this case I am using material that has nail holes, it’s torn up, etc. Well basically it’s fence material. LOL. So there will be a lot of jointing, planing, and figuring. I’m sure there will be plenty of waist as well, but we will see.
To stat this off we have the materials. In the next sections I will show more of the process as I am starting the build as soon as I hit “post” to this blog.
The leg material. This is the fall off from the 2×4s used on the fence. My goal is to run one face through the jointer and then glue 2 together per leg. Then once the glue dries I will run 2 faces through the jointer and then plane to thickness. Because the material will turn Grey I’m not concerned with the grain patterns matching, etc. Hopefully it won’t delaminate in the future.
I have glued up the back rest into one plank.
Here is the material I will dig through to find the arm rests, seat slats, aprons, etc. This is also the material for the gate, and the other fence sections. What are the chances I won’t have to buy more? LOL
And this is going to be the new location for this bench.
I hope you all enjoy this series, and I will do my best to be as descriptive as I can. As always I welcome constructive criticism, positive or negative.
5 comments so far
Dick, & Barb Cain
home | projects | blog
7036 posts in 1194 days
posted 107 days ago
We’ll be keeping an eye on this project.
DAN
6441 posts in 878 days
posted 107 days ago
me too Keith … I’m your buddy ya know !
pommy
958 posts in 586 days
posted 107 days ago
This will be interesting to watch and a good test of your skills
Andy
-- cut it saw it scrap it
25801 posts in 1295 days
posted 107 days ago
Definitely interesting.
14922 posts in 746 days
posted 103 days ago
Ive’ seen the result. Great job Keith.
