Bedrock 605 Restoration
Blog entry by knotscott posted 10-06-2011 02:40 PM 10315 reads 2 times favorited 12 comments Add to Favorites Watch
This restoration took place a couple of years ago, but thought I’d add it to the blog.
I acquired a Bedrock 605 Type 6 at a local antique coop. It was made between 1914 qand 1918 and was pretty rough. I opted to restore it the best I could with reasonable effort and cost. I fixed broken tote, cleaned up as much rust as I could, replaced the front screw on the rear tote, honed the blade, painted the top, and generally just gave it some TLC and elbow grease.
The process included disassembling everything down to the screws, then I plastered the rusty parts with Krud Kutter Rust Remover (a diluted phosporic acid best I can tell), alternated between wire brushing the rust, and resoaking with rust remover until most of the visible rust was gone. (I’ve since learned that Evaporust is highly regarded, so will try that the next time). Then I took 150 grit sand paper to the exposed metal surfaces of the base, the blade, and the cap iron. Then I followed by 220 grit on the lever cap and the afore mentioned parts. Lots and lots of sanding, wire brushing, and occasional WD-40. I painted the top with black enamel and baked it an hour or so. The top of the base is still fairly pitted, but I wasn’t willing to do any more about it. The rear tote repair was done with standard yellow glue and clamp pressure. I filled any gaps in the break with Superglue, and followed coat of poly spray to both handles.
12 comments so far
View Don W's profile
Don W
18935 posts in 2685 days
#1 posted 10-06-2011 02:49 PM
Super job!! Glad this got brought back to life. You were right about one thing, it looked pretty sad to start with. Good for another 100 years.
View racerglen's profile
racerglen
3112 posts in 2898 days
#2 posted 10-06-2011 02:57 PM
Very nice work. Congrats on a great save.
-- Glen, B.C. Canada
View blackcherry's profile
blackcherry
3338 posts in 3940 days
#3 posted 10-06-2011 03:35 PM
Nice one to save for sure, it should bring plenty of enjoyment in the shop….BC
Beginningwoodworker
13345 posts in 3790 days
#4 posted 10-06-2011 03:39 PM
Beautiful plane.
View WayneC's profile
WayneC
13770 posts in 4214 days
#5 posted 10-06-2011 03:44 PM
Hopefully he is getting daily use now.
View redryder's profile
redryder
2393 posts in 3219 days
#6 posted 10-07-2011 07:21 AM
You really cleaned that up nicely. What did that rust bucket cost you from the antique store??????
-- mike...............
View knotscott's profile
knotscott
8120 posts in 3493 days
#7 posted 10-07-2011 01:40 PM
That’s the best part….$6! I think the Krud Kutter cost more than that!
Don W
#8 posted 10-07-2011 02:43 PM
that’s a great $6 well spent.
Douglas Bordner
4025 posts in 4181 days
#9 posted 10-08-2011 05:34 PM
He lives! Excellent save, Scott.
View flippedcracker's profile
flippedcracker
91 posts in 2570 days
#10 posted 10-11-2011 09:51 PM
wow, that cleaned up nicely.
View Bob817's profile
Bob817
672 posts in 2500 days
#11 posted 01-16-2012 09:46 AM
Nice, Very nice job!
-- ~ Bob ~ Newton, N.H.
View Johnnyblot's profile
Johnnyblot
319 posts in 2393 days
#12 posted 06-02-2012 12:00 PM
I don’t own a No.5, but that one would do nicely. Well done that man!
Cheers
John
-- Gossamer shavings just floating around the back yard….-Bandit
