This borders on a “knitpick” IMO, but for the sake of clarity and truth in advertising, I think it deserves to be addressed. I frequently read phrases like “perfectly flat bottoms” and “absolutely perfect” in regards to grooves and dados cut from stacked dado sets. No doubt, some are better than others, and the very best are really, really good, but nearly all the stacked dado sets I know of use beveled teeth on the outside cutters to help minimize tearout (Freud, Forrest, Infinity, Ridge Carbide, Systimatic, Oshlun, CMT, Amana, etc). In order to be of any benefit, the beveled teeth must protrude slightly above the flat teeth of the inside chippers. The protruding beveled teeth leave tiny grooves at the outside of the cut…a trait often called “bat ears”. The better sets tend to stagger some flat teeth in between the beveled teeth to minimize the depth of the bat ears, but they’re there. It’s minor enough that a lot of people don’t even realize it, but it’s not realistic when manufacturers or owners claim that these sets leave truly flat bottoms, when indeed they don’t. It’s likely that there are sets that don’t have any beveled teeth on the outside cutters and use all flat top ground teeth, which will leave a flat bottom, but those sets will also tend to exhibit more tearout in cross grain cuts than the better sets that use beveled teeth. The other option for truly flat bottoms is from a router bit, but there are other drawbacks to that method as well… there’s never a free lunch!
There’s really not an important point to this post, but just wanted to point out the reality of the results that most of us get from even our premium stacked dado sets.
This graphic from “Woodhelp” illustrates the “bat ears” effect and the cause:
Here’s another pic from Forrest’s website that shows the correct orientation of the cutters…it also shows the bat ears left by the beveled teeth:
Here’s another gross example from a cheap Harbor Freight dado set…ignoring the poor linearity across the bottom, you can clearly see the large bat ears in each corner.
9 comments so far
PurpLev
home | projects | blog
7729 posts in 1813 days
#1 posted 976 days ago
I only have one thing to say:
Stopped Dadoes
RonPeters
709 posts in 1045 days
#2 posted 976 days ago
I have a $100 Freud Diablo dado set and it’s not exactly ‘flat’ either – poor linearity. I also have a cheap $30 Harbor Frieght set, and each blade is a little different size.
I figure the glue has to go somewhere, maybe this is where?
Joe Watson
295 posts in 1711 days
#3 posted 976 days ago
you need a router plane. you cut the dado then use the router plane to flatten the bottom of the dado.
-- Got Wood?
swirt
1864 posts in 1137 days
#4 posted 976 days ago
What Joe said, or better yet a dado plane in the width you commonly use for dados. They are simple and work great.
You can can find a lot of old wooden rabbet planes around. Some are in not great, but useable shape. The odds of finding one in exactly the width you need are slim. However if you find one that is a bit over-sized you can bring it to an exact fit for your dado set with a belt sander. It would work well at cleaning up the bottom of your dado with only one or two passes.
canadianchips
1773 posts in 1162 days
#5 posted 976 days ago
I use a #39 stanley plane. It has a scewed blade. Does a remarkable job cleaning up dado’s.
RonPeters
#6 posted 976 days ago
A router plane? Now you tell me! ;-)
I just did a quick search and found this helpful site http://www.wkfinetools.com/contrib/cSchwarz/z_art/routPlanes/rPlane2.asp
also in my new Lee Valley & Veritas catalog I find on p73 a router plane for $155 with fence. Very nice.
Searched for the #39 stanley plane and they vary in price (about half of the Veritas) at Handplane Central…
I’ll have to investigate further… Thanks!
TopamaxSurvivor
13192 posts in 1841 days
#7 posted 976 days ago
Geez, there sure are a lot of subtle things to watch out for in these premium tools!! :-(( thanks for the post Knottscott.
Eagle1
2041 posts in 1229 days
#8 posted 976 days ago
After reading your post. I went out to the shop and looked at my Freud Diablo Pro set. The out side blades, every other tooth is flat. And the chipper’s are flat also. I would possible check out someother Freud sets and check them out. I don’t know if the pro set is any different or not.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
RonPeters
#9 posted 975 days ago
My set is the same as yours. Every other tooth…
