My 2007 Table Saw Blade Comparison
Blog entry by knotscott posted 01-05-2010 06:16 PM 7038 reads 16 times favorited 9 comments Add to Favorites Watch
This is a revised saw blade comparison I did in 2007. It includes general purpose blades, crosscut blades, and bulk rip blades. The general purpose blades are grouped and compared to each other based on cut quality in various materials with different types of cuts, feedrate, and their ability to do many things well. The crosscut blades were judged more on cut performance and freedom from tearout than versatility or feedrate. Inversely, the bulk rippers were evaluated more on feedrate and ability to chomp through thick material than cut quality or versatility. The charts for each type of blade show the same parameters, but the emphasis changes for each, and the overall ratings were derived differently for each category because the criteria was different. It’s possible to draw some conclusions of individual cutting characteristics across charts, but the “Overall Task Ratings” are only relevant within each of the three classification charts compared to similar blade types.
This is by no means intended to be a scientific or comprehensive blade review. It’s just some guy playing with saw blades in his garage on an average saw tuned by an amateur, and documenting some observations. Some of the ratings are just opinion and some are subject to several sources of variability, though I’ve tried to reduce those as much as possible. There are undoubtedly flaws in my evaluation method as well as my approach to the documention. Even a slight change to the criteria and calculations changes many things. Note that most of the blades are excellent performers for their respective tasks that I’d expect very good results from, regardless of the ranking.
My saw was a 1-3/4hp hybrid at the time, and I tended to favor good quality 3/32” thin kerf blades for the easier feed rate and lower strain on the motor. I have since switched to a full 3hp cabinet saw that’s less fussy about the blade selection, and have tried several full and thin kerf blades that are not listed in this comparison. Note that I’ve never had a significant issue with deflection with high quality TK blades. I’ll emphasize the importance of high quality with that statement. Some of you will prefer full kerfs for your own reasons, and if you’ve got a full 3hp+ cabinet saw, there’s less reason to consider TK’s. Modern high end TK’s have excellent alloys, construction, and precision. In every case when I compared a comparable high quality full kerf to a thin kerf, the TK had a noticeably faster feed rate, which inherently leads to lower burn rate and the ability to rip thicker stock with a smaller saw. The ratings reflect this and should be considered when comparing blades. Just as importantly, the TK’s cut as cleanly as the mid and full kerf blades.
One valuable lesson I’ve taken from experimenting with various blades, is that similar designs made to similar quality levels tend to have similar performance. The cuts from blades like the 40T WWII, TS2000, DW7657, and Gold Medal are just about indistinguishable from each other for all intents and purposes, though feedrates vary due to kerf width. I’ve gotten similar or even better performance from the Infinity Super General, and would expect similar from the Freud P410 Fusion. Provided that the initial quality level is high enough, choosing the correct blade for the task makes far more difference than brand, model, or price. Interestly, some of the best examples of the more value oriented blades aren’t too far behind the top priced models. There are differences mind you, but the results from some of the better bargains leave acceptable cuts for most given applications. Don’t confuse the “better bargains” with the cheap, low quality blades that are waste of money. There are some excellent $45 blades on the market that I consider bargains, but unfortunately, there are also a lot of poorly made blades too. The examples of poor performers that were included in this comparison (Skil, Vermont American, Oldham Industrial, Delta Sidekick, etc.) were published primarily as a reference and as a reminder of a hard learned lesson that it’s often more expensive to spend too little.
GP/Combo blades:
This chart includes blades intended for general or multi purpose use. They typically range from 40 to 50 teeth, but there are a few exceptions. The Freud LU88 is listed as a 60T “crosscut” blade but it features a 15 degree hook that helps it rip well, thus it’s very capable of GP type work. The Freud LU82 is a 60T TCG blade billed as multipurpose blade. And tbe 30T Forrest WWII is simply a lower tooth count GP blade with the same geometry as the 40T version. These blades are designed to be versatile and rip and crosscut well in alot of different materials. The have a very broad operating range, but tend to not excel in any one particular area. The better examples will give glue line cuts in the vast majority of situations, and are suitable for most circumstances. My ratings emphasized their versatility, feedrate, and cut quality. On the whole, the full kerf blades suffered slower feedrates on my saw….a non issue for saws with larger motors, but a reasonable concern for more modest saws. As you can see the differences between the top 5 are essentially numeric “decimal dust”, and even the next 3 were merely victims of my weaker saw, and still have excellent cutting characteristics. Any of the top 14 are well suited for the task of general purpose use.
Individual comments:
The LU88 is a 60T ATB TK with a 15 degree hook and a Permashield coating. It quickly earned it’s way toward the top of my list. True to it’s categorization as a crosscut blade, it offers a very clean cut, free from tearout and swirl marks, and tends to be a better choice in sheetgoods and crosscuts compared to most general purpose blades. As mentioned earlier, it also rips very respectably with a reasonable feedrate in materials up to ~ 6/4”, making it an excellent lower cost choice for many applications. An excellent compliment to a good 24T ripper.
The 30T Forrest WWII has different strengths than the LU88, but is equally versatile and capable but in a slightly different thickness range. It employs the same geometry as is more popular sibling, the 40T WWII, with an ATB grind, and 20 degree hook. This “GP” blade will hang with many of the 24T rippers in thick stock, while offering a cleaner cut. The cut quality is remarkably close to the 40T and 50T GP blades. IMHO, this is the closest you can get to a single blade that will do it all. An excellent compliment to an 80T Hi-ATB crosscut blade, but it cuts cleanly enough that it will likely see 95% of the cuts.
The 40T Forrest WWII is the industry gold standard by which all other blades are measured. Versatile, clean cutting, very well made, and always a pleasure to use. You’ll rarely encounter a situation where this blade is out of place.
The 50T Infinity Combomax proved to be the best overall 50 tooth combination blade I’ve tried (still true as of 4/26/15). This is a very well made blade that uses a unique ATB/R configuration that features a chamfered raker instead of the traditional flat top raker. It has very low tearout for this class of blade, and is particularly good in sheetgoods compared to other 50T ATB/R configurations, while maintaining good ripping abilities due to it’s 12 degree hook. Another top shelf well made blade that’s very forgiving and easy to get good results with. (full or think kerf available)
The Ridge Carbide TS2000 proves to be every bit the equal of the vaunted 40T WWII, and is the closest in geometry and workmanship IMHO. Like the WWII, it’s American made and is available in two kerf widths in the 10” diameter. It sports teeth that the manufacture claims are 35% thicker than their competition…a claim I can confirm to be true.
The Tenryu Gold Medal is another top shelf 40T GP blade made to world class Japanese standards. It’s only available in one unique kerf width of 0.111”, vs 0.98” for most TK’s and 0.125” for most full kerfs. A very nice blade that suffered slightly slower feed rates than it’s TK counterparts on my saw.
The DeWalt DW7657 is a relatively low cost dark horse in this group. At < $50, this British made precision GP blade offers similar geometry and performance as the WWII. Cutting performance was on par with the other top contenders. It too suffered slower feedrates than it’s TK counterparts on my saw, but remains an excellent budget conscious choice for larger saws. Note that this blade was part of the DW series 60 line, but is now also available as the Delta 35-7657…often seen in the $40 range (or less!) A terrific bang for the buck in the full kerf GP class.
The Tenryu RS25550 is another relatively low cost top tier performer. This well made Chinese blade features a fairly traditional 50T ATB/R combination configuration with a 15 degree rake, in a 0.126” full kerf width. It’s about half the cost of it’s more expensive “Gold Medal” sibling but offers well more than half the performance.
The LU86R010 40T TK is perhaps my favorite of the bargain blades. It’s readily available shipped for ~ $35, with sale prices dipping into the $25 range. It has much in common with the higher tooth count LU88’s geometry and features. It doesn’t perform quite to same level as the LU88 and other $100 performers, but considering the entire class of GP and combo blades is a design compromise, it’s hard to ask more for the price, and not likely that you’ll actually need more. An unsong hero for sure!
The German made Irwin Woodworker 50T combo by Leitz is essentially the same blade as the H.O. Schumacher & Sohn TK combo blade. It’s not readily available anymore with the Irwin logo, but can be purchased under the Schumacher logo in the $65 range. It features a variable pitch teeth to reduce noise, in a 50T ATB/R configuration. A very good blade to be sure, but the other stellar performers make for some stout competition in this price range.
The Tenryu RS25540 is a Chinese made 40T GP blade that offers an unusual tooth grind…an alternating top bevel alternating face (ATAF), with a 15 degree hook. The ATAF is an interesting approach that is essentially an ATB grind with alternating angled faces. It offers very good performance at the very low asking price of ~ $30 shipped from select dealers.
The Chinese made Leitz 40T is the stock blade that came on my 22124. Nice stock blade as stock blades go, but there’s not much incentive to choose it over any of the other high performing low cost blades here.
The LU84R011 is traditional 50T combo blade in an ATB/R configuration, and perennial popular choice. This is the full kerf version, which like the other full kerfs, didn’t feed fast enough for my liking. The performance is very good nonetheless, though not quite on par with the WWII and it’s elite competitors. It’s available as a TK in the LU83, which would likely be a better choice for me and others with typical home shop saws.
The Porter Cable Razor 100VT50 is a 50T ATB/R configuration with staggered teeth to help reduce noise. It doesn’t shout high quality like the Infinity and Ridge Carbide do, but its available anywhere, costs ~ $30 and its performance is “good enough” for glueline rips and typical GP applications.
The LU82M010 from Freud’s Industrial line is a departure from the design of most of the other GP and combo blades in this group. It’s a 60T TCG configuration in a full kerf width. It’s well made, but offers little advantage for woodworking cuts over the impressive competition in this group, thought it’s the triple chip tooth grind should hold up better to hard use than the others, which would make it an excellent choice for laminates, manmade sheetgoods, and other well known blade killers.
This Skil 36T full kerf GP blade had an unusual tooth grind that appeared to have a concave face. I didn’t like it much, can’t even recall the model number. The two TS blades I’ve used from Skil so far are the types of blades that prompted my search for higher quality and better performance. Move along…nothing to see here.
The 36T Delta Sidekick that came with my first Delta 36-600 TS is pretty much a waste of carbide and is a ding in Delta’s armor IMHO. Even as newbie I could easily tell that it wasn’t good enough for woodworking.
CROSSCUT BLADES:
The same parameters were evaluated and charted for the crosscut blades, but the emphasis was placed more on cut quality and performance in sheetgoods than versatility and feedrate.
The 80 tooth blades tended to outperform the 60T blades at the task of crosscutting. Since the purpose of a dedicated crosscutter is typically to make an ultra clean cut in hardwoods or sheetgoods, I don’t see much need for a 60 tooth version unless you need to crosscut very dense thick material that tends to be scorched by the 80 toothers, or you want more versatility and some ability to rip thinner materials.
The Freud F810 has since been replaced by the LU80R010. It’s the same 80T full kerf Hi-ATB grind with a near zero degree hook, but now has a Permashield coating. This is the cleanest cutting blade I’d tried at the time of this comparison. In fairness I don’t spin a crosscutter very often and haven’t tried the comparable models from companies like Forrest, Infinity, or Ridge Carbide. This model is also available as a TK in the LU79R010. (edit 12/23/10 – I’ve since tried a Forrest Duraline, CMT 210.080.010, CMT ITK 255.080.010, and Infinity 010-060 that are roughly equivalent…though the CMT ITK 255.080.010 is very good, I don’t consider it quite to the level of the Infinity, Freud, Forrest or CMT Orange versions)
The DeWalt DW3218 is an 80T TK ATB design with a 5 degree positive hook. It also did a super job for me in those rare occurrences that I use a dedicated crosscut blade. It’s nicely made and sports nice big teeth. The DW3218 is from DW’s upper series 40, and is made in the UK. (Since B&D’s purchase of Pentair (Delta and friends), it appears to me that the series 40 line has been revamped as the “Precision Trim” (PT), and now sports a yellow coating….I’m not positive that this is the case, but it appears the series 60 is becoming the Delta Industrial line.
The LU74R010 is an 80T TK ATB design with a slightly positive hook. It’s basically the TK equivalent of the popular LU85. It also did a super job for me in those rare occurrences that I use a dedicated crosscut blade. Like other Freud Industrial blades, it’s top quality and is made in Italy.
The DeWalt DW7647 is an 80T full kerf ATB configuration with a negative 5 degree hook. It’s from DW’s top series 60, which is morfing (or at least expanding) into the Delta Industrial line..the DW7647 is available as a Delta 35-7647. It’s a nicely made blade from the UK, and did a superb job. The negative hook makes it especially void of tearout.
The German made Leitz Pro 80 has a similar geometry to the DW7647, but is a TK. It currently resides in my CMS for fine crosscuts but is equally adept at plywood and sheetgoods where an ultrafine edge is needed.
The Ridgid R1060C is made by Freud in Italy and appears to be made to similar standards as their Diablo and Avanti line. It’s a 60T TK ATB configuration with a titanium coating and a positive 15 degree hook. The 1060 cuts cleanly and offers a more versatility than most of the other crosscutters, with better ripping ability than the others. It’s configuration is similar to the LU88 that I listed in the GP chart. The kerf width is given as 0.090” which makes it the thinnest of all the TK’s in this group…as stated earlier, I’ve never had a deflection issue but I wouldn’t want to push it either. Nonetheless it’s a really nice balde and a solid performer that’s not outrageously priced. If you’ve got one enjoy, if you don’t, I think one of the 80T choices would make a better dedicated crosscutter, and the 60T LU88 seems to overshadow this one a bit with more carbide for about equal money.
The German made Leitz/Irwin 60T variable pitch ATB blade is not currently available under the Irwin name, but an identical blade can be found under the HO Schumacher & Sohn name. Cut quality was good, but this full kerf higher tooth count blade bogged too much for my taste on my saw. A better choice for a full 3hp saw if you need some ripping ability and a clean cut, but IMHO it doesn’t outperform most of the better 40T and 50T blades that offer comparable cut quality and better ripping efficiency.
The DeWalt DW7646 is another very nice 60T ATB configuration with a midsize kerf of 0.118” (it’s mislabeled as a full kerf in the chart). Like the Leitz/Irwin 60T, this is a fine blade that’d likely not see much action for the same reasons stated above…YMMV. It’s also now available as a Delta 35-7646.
The Oldham 60T Industrial Finishing blade has to be one of the most disappointing blades I’ve used. I was new to woodworking when I shelled out $20 for what I thought would be a really nice highend “carbide” blade. It never did cut very well, fed slowly, wouldn’t handle thick material well, and dulled way too soon. It could be argued that a rookie abused it, but I’ve abused a few dozen others in a similar fashion since. Spend the $20 on an enjoyable lunch instead.
Bulk Ripping Blades:
The dedicated rippers were also subject to the same parameters as the other blades, but again the emphasis changed. This time feedrate and ripping efficiency were king, but with some consideration for cut quality, and versatility was heavily discounted. Even though I primarily spin a good GP or combo blade, I do frequently use a bulk ripper for heavy work. IMHO there should be at least one in every woodworker’s inventory. They can spare your good blade from the bulk work, and tend to be kinder on your saw’s motor. Since feedrate was a big factor, the kerf width also plays a bigger factor. The good TK’s enjoyed a noticeable advantage in speed over the comparable full kerfs on my smallish saw. In my relatively limited experience with dedicated rippers, the 24 toothers seem to be the happy medium between bulk and acceptable cut quality. The cut quality on the better 24 tooth blades are just barely acceptable for a glue joint, and definitely fall short on an exposed edge.
Rip Blade Comments:
The German made Leitz/Irwin 24T variable pitch FTG TK is usually my “go to” ripper. As bulk rippers go, it’s got what I want…an excellent feedrate, reasonable cut, and never seems to bog the saw. Most cuts are glueable as-is for edge joining. It’s cut to full blade height in some tough stuff…most recently it chomped through several linear feet of 12/4 quartersawn wine vat white oak without a whimper. The real kicker is that it’s been being clearanced for ~ $10, so I’ve got a couple of them. Nicely made with enough carbide to last several sharpenings. Unfortunately it’s in limited supply under the Irwin Woodworking series name but should be available as an HO Schumacher & Sohn for ~ $45.
The DeWalt DW7124TK is every bit the equal of the Leitz/Irwin ripper, but without the variable pitch. It has very similar geometry otherwise, and very similar performance. It’s also gone through everything I thrown at it with an acceptably clean cut by ripper standards. These UK made blades are getting hard to come by as the DW series 40….as mentioned earlier, I strongly suspect the new DW “Precision Trim” series is replacing the series 40. Both versions go on sale at very reasonable prices.
The German made Leitz/Delta Industrial 10T ripper was purchased mainly as a novelty just to see what it’d do….a clearance price of $15 seemed like a bargain to me. It’s a full kerf that’s got huge flat top teeth at a steep 20 degree hook and huge gullets. It feeds comparably to my top two 24T TK rippers but the cut suffers in comparison…it’s predictably rough. On a 3hp+ industrial saw, this blade would go to town on the thickest densest material you’ve got. Leitz is no longer making these blades for Delta.
The Italian made Freud LM72R010x was my first high quality ripper. It has a standard full kerf ripper format of 24 FTG teeth at a 20 degree hook with a Permashield coating. Even though it was full kerf and had a lower tooth count, it had a better feedrate and cleaner cut than my Vermont American and Skil 28T blades. Being full kerf it still bogged my saw down when I’d feed it things like 10/4” hard maple, but it’s a still a top shelf ripper that’s nicely suited for a 3hp+ cabinet saw.
The Leitz Pro 30T ripper with a negative hook was also an impulse buy based primarily on price and curiosity. It’s a full kerf that deviates from standard rippers in that it has ATB teeth and a negative hook angle. As a result it cut’s a bit cleaner than most rippers but doesn’t feed as fast. It’s really designed for use on RAS, but it functions reasonably well as an inexpensive glueline ripper (GLR).
The Vermont American 28T ATB ripper was another disappointment to me. Even in a TK configuration with ATB teeth, it neither cut well or aggressively. The icing on the cake was it’s rapid dulling. Highly recommended for that pesky neighbor you dislike!
The Skil 28T ATB ripper is identical to the Vermont American version as best I can tell. It was clearanced for $7 so I gave it another shot. This one was sharper than the VA ripper, and performed better for a short while before dulling prematurely. What can I say? ...these aren’t very good blades…
REVISION (12/23/10):
Since doing this blade comparison in 2007, I’ve tried a few blades that were not included in the review info above:
Infinity Super General 010-044 40T Hi-ATB – the cleanest cutting of any 40T or 50T general purpose/combo blade I’ve tried to date. The Hi-ATB grind excels at crosscuts/ply/clean ripping. The dual side grind makes very polished edges. It’s not quite as efficient at thick ripping (>2”) as some of the more standard 40T blades, and is a bit more prone to burning on some thicker woods, but it’s a darn impressive blade overall. The design is very similar to the Freud Fusion with bigger teeth. Not a good choice for high volume thick ripping, or for sloppy setups, or for materials that have more tendency to burn.
CMT 213.040.010 40T ATB – Unfortuntely, I got two different blades that both underperformed expectations, so it’s hard to recommend considering my experiences on two occasions. Other CMT blades I’ve tried have been good to excellent…guess I just got two defective blades from two different dealers over a year apart (rolleyes).
Infinity 010-060 60T Hi-ATB – Very low tearout, versatile design (suitable for TS, RAS, CMS, or SMCS), excellent crosscut and ply blade, also excellent for general purpose TS work < 1.5”. A terrific overall blade if you don’t to much thick ripping > 1.5”. An excellent compliment to a 24T ripper or WWII 30T. Very similar to the Forrest WWI 60T.
Infinity 010-124 24T FTG ripper – Very efficient at cutting thick stock, moderately smooth cut and crosscuts poorly (as expected from a rip blade). Leaves flat bottoms. Very similar to the Freud LU87, CMT 202.024.10, and other 24T FTG rippers. Thin or full kerf (010-024).
Amana Tool 610504 50T ATB/R – Huge industrial teeth, versatile, good cut, full kerf, very similar to other 50T ATB/R blades like the Freud LU84, DeWalt DW7640, and Tenryu RS25550.
CMT 210.080.10 80T Hi-ATB – Excellent crosscut and ply blade, limited operating range outside of that.
Oshlun 40T ATB general purpose blade – Great bang for the buck, versatile, good overall performance, full kerf
DeWalt DW7640 50T ATB/R (series 60) – Very nice combo blade, versatile, very good results overall…one of my favorite combo blades.
Amana Tool RB1020 20T FTG ripper – A very aggressive industrial bulk FTG ripper. Leaves flat bottoms, and not overly smooth cuts and crosscuts poorly (as expected), but hogs thru the thickest materials pretty easily. Full kerf.
9 comments so far
View Alonso's profile
Alonso
949 posts in 3264 days
#1 posted 01-05-2010 06:34 PM
That is a great review, is now part of my favorite list. Is you hand sore after so much typing? j/k
Thanks Scott
-- The things I make may be for others, but how I make them is for me.
27250 posts in 3848 days
#2 posted 01-05-2010 06:39 PM
Scott, this is an excellent review. I have generally used only Forrest blades but this review has certainly given me something to consider.
View knotscott's profile
knotscott
8057 posts in 3402 days
#3 posted 01-05-2010 06:40 PM
”Is your hand sore after so much typing? j/k”
Nah…I only added 2 new sentences! :D
View zlatanv's profile
zlatanv
691 posts in 3260 days
#4 posted 01-05-2010 06:51 PM
Pretty in depth review, good info.
-- Z, Rockwall, TX
Todd A. Clippinger
8901 posts in 4125 days
#5 posted 01-05-2010 10:37 PM
Have you ever tried any of the CMT blades?
One of my favorite blades is the General. It only has 40 teeth and I have great results with this one in solid and plywood.
I usually have this one in the mitersaw and a glue line rip on the table saw. I will install the General on the table saw for exceptionally clean cuts in plywood cutting with or cross grain to the finished surface.
This blade goes against the conventional thinking that you need 60 teeth or more for a great cut.
knotscott
#6 posted 01-05-2010 11:20 PM
Hi Todd – I’ve tried a few CMT blades…the 80T ITK Hi-ATB 255.080.10, the 30T GLR 203.030.10, and the Orange full kerf 40T 213.040.10. Apparantly all tried after I did these charts.
The first two were really nice, unfortunately the CMT 40T is one that seemed “not quite right”, as it left visibly rough edges on everything….I’m sure the vast majority work as expected, but this “twern’t right”. I suspect it was one that slipped thru QC on a Monday morning or Friday afternoon. I bought it to be my daily user in my new Shop Fox cab saw back in fall of 2008, but it got returned in favor of a DW7640 50T combo. There are a handful of similar 40T general purpose blades that seem to defy conventional widsom, and most are pretty similar to each other…which was one reason I was surprised at the CMT. The WWII, TS2000, Gold Medal, DW7657, the original Infinity General, and original Freud F40 are a few that are similar. One of these days maybe someone from CMT will read about my dilema and offer to send me one in effort to redeem themselves. ;-)
View Partridge's profile
Partridge
296 posts in 3982 days
#7 posted 01-06-2010 02:57 AM
i just sent two forest blades (wwII 40) in to get sharpened. thanks for the info
-- I get out in the shop when I can
Todd A. Clippinger
#8 posted 01-06-2010 11:37 PM
I have not had trouble with the blades as brand new, but I must have done something to one of them because it leaves rake lines like I ran over it with the truck.
Fortunately I have a job going right now where the wood is all to have a hand hewn and rough sawn appearance to it.
I was just thinking back and I remember making a (really dangerous) sculpting cut on the table saw and the blade grabbed the piece slamming it in to the table. It stopped the blade and blew the safety switch. I am now starting to realize that blade may have been the victim.
Yeah, sometimes I do stupid and dangerous things with my tools. While most people cut in lineal fashion, I find myself “shaping” wood with things like the table saw, chop saw, jointer, and band saw.
View blockhead's profile
blockhead
1475 posts in 3334 days
#9 posted 01-08-2010 11:24 PM
That’s a great review Scott. Thank you for the time and effort spent compiling your findings.
-- Brad, Oregon- The things that come to those who wait, may be the things left by those who got there first.
