Yet Another Router Table Project #3: Making the router table plate
Blog entry by ww_kayak posted 98 days ago 311 reads 0 times favorited 7 comments Add to Favorites
« Part 2: Carcass Part 3 of Yet Another Router Table Project series Part 4: Holy Plate »
OK, slight diversion, I know this overkill, but it is fun. I decided to make my own router plate because I was able to pick up a piece of T6 ( almost 3/8” thick) on the cheap. The plate will be just under 9×12 and I have enough to make either 2 plates and a couple rings, or 1 plate and a bunch of rings. How many of the insert rings do most of you really use? and what sizes?
Plate1
plate2
plate3
penny
Cutting
Rugh cut…
size
finish
finish cuts…
router
Tomorrow I’ll make some holes…
-- Tom, Central New York
View ww_kayak's profile
ww_kayak
68 posts in 111 days
Entry tags/keywords
View Blog Archive
7 comments so far
View GaryK's profile
GaryK
8182 posts in 375 days
posted 98 days ago
Check Woodpeckers site to see what rings they offer, and what they supply with their tables.
7746 posts in 209 days
posted 97 days ago
Tom,
You have too much time on your hands!! :) I cannot ever remember anyone making their own router plates. But go for it. I really don’t use any inserts. I run two tables. One has a 1.5” opening for round overs, flush trim bits, ... basically small profile bits. The other table has a 4” opening for my raised panel bit.
To tell the truth after I am seriously thinking about making a table with several replaceable tops and dedicating each top to a specific bit. This saves setup time and they can be stored in a relative small area. I currently have 5 routers so several sit idle a lot of the time anyway.
View rikkor's profile
rikkor
6436 posts in 261 days
posted 97 days ago
This is an ambitious project. I get by with two inserts, like Scott.
-- Maplewood, MN
teenagewoodworker
1676 posts in 155 days
posted 97 days ago
wow that is a great project. i’m looking to build a router table to so its cool to see things like this made. thanks for the post.
View Dick Cain's profile
Dick Cain
4288 posts in 686 days
posted 97 days ago
Nice project!
You have to make your own plates, otherwise your milling machine would be sitting idle.
-- Dick Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1
View joey's profile
joey
234 posts in 291 days
posted 97 days ago
I made mine out of a piece T6 1/4 plate I didn’t access to a mill or I would made my own rings also I cut a 2 1/2” hole I was hoping to later figure out a ring system for it. I repair a friends computer in trade for enough alum to make 2 plates and several rings, he worked at a shop that build custom dragsters parts. so far I been please with mine, I haven’t gotten any makes on the wood from the alum like everyone said I would, but if ever became a problem I was just going to put a piece of laminate on it.
Joey
-- Joey~~Sabina, Ohio http://sleepydogwoodworking.blogspot.com/
ww_kayak
posted 97 days ago
Good point about the marks, joey. I think I’ll polish it up and wax it, that should prevent most of it. I think I’ll draw the line at Anodizing it myself, although … I did find a great site explaining how to do it ;)
Bookmark And Share This Page
