2 x 4 Challenge #2: All Is Revealed!
Blog entry by mot posted 165 days ago 469 reads 0 times favorited 22 comments Add to Favorites
« Part 1: Throwing My Hat in the Ring Part 2 of 2 x 4 Challenge series no next part
After gluing up the blank in the first part of this series, I moved over to the miter saw. I set the angle for 15 degrees, setup a 15 degree stop and a sub fence/base for zero clearance to minimize tearout.
I cut the 2×4 into a bunch of little pizza slices and got ready for the next step. That step involved finding out if my mitre saw read 15 degrees accurately!
Two half circles were made, and the pieces taped together. I didn’t have any of the fancy blue tape that those lucky guys that do veneering use, but settled for the green stuff that us lowly turners have on hand!
I pulled clamps from my dust collector pieces box, and daisy chained them together for my glueup. I was off by a smidgen so I used a chisel to keep the two halves taught. I’ll workout how to correct the error later. I was still thinking at this point.
After my glue was dry, I ran both half circles through the drum sander in order to make they perfectly flat and equal. This step may have been unnecessary as I’m going to have to do this again, as you’ll see.
After using a compass with the halves held together, to mark circles, I set the bandsaw table to 22 degrees and cut out my half circles. Many of you have guessed, by this point, where this little 2×4 is headed.
After cutting out the half circles, I glued them into rings. The error I had with the angle being slightly less than 15 degrees, was taken out with my tablesaw sled and a quick swipe. The rings took another trip through the drum sander, at this point, in order to make sure they had perfectly flat glue surfaces.
I then glued, stacked and clamped my rings! Those of you that guessed a hat from the band Devo? Well, you’re wrong! Close though! I was a little dissappointed in how little gluing surface I left on this. The bowl itself will be just around 1/4” thick. I think that, for a spruce bowl, this will really be a test to turn it.
With a little creative chucking, the project is starting to take shape! The wood was VERY dry, the step on the rings left for a VERY thin wall, and I had a heck of a time turning this.
After a lot of sanding and some very tentative turning to keep from blowing this thing into a bunch of pieces, out came the bowl. This is a picture of the bowl, the building block and some of the waste. Those of you that turn, know that that’s about 1/4 of the mess that came off the lathe. I kept the rim pretty thick for two reasons; the bowl had to be turned too thin because of the ring overlap, and with it being so dry, turning the rim was pretty exciting with the the wood so dry, so once it was round, it didn’t get too much more treatment.
Well, Mr. 2 X 4, I’m pretty pleased with what you had to show me! Thanks for looking, folks!
Cheers!
Tom
View mot's profile
mot
4831 posts in 427 days
The bantering and ramblings of a hobby woodworker/lumberjock!
Entry tags/keywords
View Blog Archive
22 comments so far
View scottb's profile
scottb
2742 posts in 718 days
posted 165 days ago
Awesome!
-- The opposite of war isn't peace. It's creation. -- Wood T's: http://www.printfection.com/snbcreative
View RobS's profile
RobS
1000 posts in 697 days
posted 165 days ago
Awesome and incredi-bowl. Great work.
-- Rob (A) Waxahachie,TX
1635 posts in 412 days
posted 165 days ago
Well done Tom.
View USCJeff's profile
USCJeff
754 posts in 459 days
posted 165 days ago
I’ll leave it at, “Wow”
-- Jeff, South Carolina
11555 posts in 791 days
posted 165 days ago
Great job Tom.
Nice chips. The bowl isn’t too shabby either.
View GaryK's profile
GaryK
8183 posts in 379 days
posted 165 days ago
Nicely done Tom!
lazyfiremaninTN
262 posts in 344 days
posted 165 days ago
Fantastic. Truely original.
View rikkor's profile
rikkor
6489 posts in 265 days
posted 164 days ago
Holy cow! That is a fine looking 2×4. Are you going to stain it?
-- Maplewood, MN
10984 posts in 551 days
posted 164 days ago
and the salad looks delicious.
(great photo).
well done, Tom. Well done
View toyguy's profile
toyguy
398 posts in 228 days
posted 164 days ago
I could have sworn it was going to be a hat from that band DEVO… But a bowl full of popcorn is cool too.
View Russel's profile
Russel
1027 posts in 330 days
posted 164 days ago
Way cool. Creative to say the least.
-- If at first you don't succeed, try again. Then quit. No use being a darn fool about it.
View Tomcat1066's profile
Tomcat1066
556 posts in 187 days
posted 164 days ago
OK, now that’s cool!
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
View MorningWood70's profile
MorningWood70
29 posts in 176 days
posted 164 days ago
I think I might have to get a lathe now
-- Eric, www.themorningwoodshow.com
7806 posts in 213 days
posted 164 days ago
The imaginative effort that is present here is truly amazing. I can honestly say I will never look at a 2×4 in the same light anymore.
Thanks for the inspiration.
View Patrick Jaromin's profile
Patrick Jaromin
151 posts in 223 days
posted 164 days ago
Awesome. Color me impressed. And to think, growing up in Buffalo, NY I thought Canada was only good for Hockey, Labatts and Rush!
Strong work Tom.
-- Patrick, Chicago, IL www.TenonAndSpline.com
View mot's profile
mot
posted 164 days ago
Thanks for all the comments, folks. I’m just going to leave it natural. I’ll take a picture of it with a light in the bowl. It’s paper thin. With it being so dry I might put some poly on it, but probably not. It was a really fun project to make, with lots of inspiration amongst the LJ community. I was showing my father some of the projects and he said, “Wow. Get that group together and with some 2×4’s you’ll not only build the house, you’ll furnish it too.”
Cheers!
View Napaman's profile
Napaman
1359 posts in 468 days
posted 164 days ago
“That’s Incredible!” (remember that show???) Wow…tom…looks great….
-- Matt, Napa, CA...SING WITH ME: "Sum...sum...sum...summ...summ...summ...summertime..."
View mrtrim's profile
mrtrim
1484 posts in 271 days
posted 164 days ago
great project mot well done !
-- if you aint the lead dog the scenery never changes
View Kerry's profile
Kerry
91 posts in 181 days
posted 164 days ago
Nice job Tom.
Kerry.
-- Alberta, Canada
View Mario's profile
Mario
686 posts in 442 days
posted 164 days ago
Very cool project.
-- Hope Never fails
View Zuki's profile
Zuki
638 posts in 468 days
posted 164 days ago
Excellent job Mot!!!!!!
View jeanmarc's profile
jeanmarc
503 posts in 107 days
posted 30 days ago
impressing. beautiful work
-- jeanmarc manosque france
Bookmark And Share This Page
