Hi Folks,
Wanted to share a few pics of my shop upgrade in progress, I’m a bit into it now but nothing that is too advanced – just some basic framing. I’m working out of a 2-car garage and wanted to maximum my shop space while still retaining some use of the garage.
The major tools that I needed to accomodate were:
- Grinder
- Drill press
- Spindle sander
- Mini lathe
- Bandsaw
- Tablesaw
I built the bench to hold the grider, drill press, sander and lathe with a spare bay as an ‘assembly station’. I also installed a Delta AP400 dust collector with the hoses running under the worknbench. At each station there is a blast gate mounted flush with the bench and next to the dust collector I have a floor sweep.
I still need to run an auxilaary line to connect on the table saw and planer – once I get one!
Here’s a picture of the bench -
The worbench is 21 3/4” deep, this makes it flush with the door leading into the house. There’s still room a the opposite end to store our lawnmower and access the water heater.
I try not to waste anything in the shop so for the bottom shelves I used random pieces of 2×4’s to create cross-support braces – reminiscent of setting up a waterbed frame in you remember those. Since they won’t be visible they only needed to be functional and not visually pleasing.
Here’s a pic showing one of the supports:
My plan for here is to finish closing in the worbench. I’ll add 2 doors at each bay. For the bottom shelf I’m going to use drawer slides to make a sliding shelf for easier access.
Still to come are a rolling bench to be used as a miter saw staion, possibly with a router table integrated. Once everything is situated this should still leave 1/2 where a car can be parked if needed.
Any comments or suggestions are welcomed and appreciated!
-- Tim D. - Woodstock, GA
7 comments so far
home | projects | blog
7762 posts in 210 days
posted 130 days ago
Tim,
This is a nice space. I particularly like the mats in front of the bench. The bench looks pretty solid. I am interested in seeing the finished pictures as well.
GaryK
8182 posts in 376 days
posted 130 days ago
Looks like it will do the job for sure.
11538 posts in 789 days
posted 130 days ago
Great Tim. Looking great.
Mario
686 posts in 439 days
posted 129 days ago
Nice work, keep that pics comming.
-- Hope Never fails
HallTree
562 posts in 155 days
posted 129 days ago
Looks like you are off to a good start. Looking forward to see the projects that come from all of it .
-- Ron in Osseo, Minnesota
lance
129 posts in 376 days
posted 128 days ago
Great! Good Luck.
-- Bob Lance, DE
davidtheboxmaker
248 posts in 193 days
posted 128 days ago
The bench looks very solid and dependable – just what you need.
I’m jealous of your space – I work in 8’ x 10’ – its good, but I’d look more room.
