Garden Bench with Table #3: Finished
Blog entry by Greg Wurst posted 56 days ago 143 reads 0 times favorited 4 comments Add to Favorites
« Part 2: I hate drilling dowel holes Part 3 of Garden Bench with Table series no next part
Got to work on the bench Friday evening and today. I started Friday by cutting the armrests to shape. The rear had to be notched at a 7 degree angle, which I did on the bandsaw for one piece and the scroll saw for the other.
I then cut the front and rear table pieces from the 2×8 blocks. I used Sketchup to print a scale model of the curve to transfer to the pieces. I then cut a couple cup holders, which I somehow cut one closer to the side than the other. I thought both were 4 inches from the edge, but I obviously measured wrong. If it really bugs me I’ll cut a new piece. I used a hole cutter to cut the outline and then a smaller forstner bit to remove the material. I then drilled a 1” hole for drainage.
I then attached the armrests. The fronts are attached with dowels and the rear is screwed to the side of the char.
The table supports are screwed to the sides.
At this point I put all the pieces on the bench just to see what it would look like.
I then started to apply the first coat of finish. It is supposed to be a cedar-look finish, but it looks a bit darker than normal to me.
I made the mistake of using a regular brush to apply the finish to the bench. It took me 2 hours and until midnight to finish for the evening. Saturday I switched to a foam brush and it went 3x as fast.
The table top pieces and seat slats are each attached with 4 screws and can be replaced if needed. I put the bench out by the swing set so Melissa can watch the boy when he’s playing.
Overall, I’d say not bad for eyeballing someone’s project and creating a plan. The bench is nice and sturdy, and should hopefully last for awhile.
View Greg Wurst's profile
Greg Wurst
411 posts in 283 days
Entry tags/keywords
project progress
View Blog Archive
4 comments so far
View steveosshop's profile
steveosshop
178 posts in 77 days
posted 56 days ago
That looks soooo familiar…...... ;). Nice job. I like the added cup holders.
-- Steve-o
View lew's profile
lew
956 posts in 206 days
posted 56 days ago
Sweet looking bench!!
Lew
View SPalm's profile
SPalm
702 posts in 333 days
posted 55 days ago
Sweet. Congrats at completing it. The finish looks good from here.
Steve
View thetimberkid's profile
thetimberkid
1512 posts in 154 days
posted 55 days ago
Nice job!
Thanks for the post
Callum
-- Look great, get your TTK merchandise now! http://www.printfection.com/thetimberkid/ Check out my site http://thetimberkid.blogspot.com/
Bookmark And Share This Page
