Lots of pictures, so I’ll keep the text to a minimum:
I started by putting the center cabinet together. The holes are too small for a drill driver, so I had to get creative with installing the pocket screws.
I went ahead and added the drawer slides before the top went on. A piece of 1/2” MDF makes a perfect spacer.
Here’s the center cabinet with drawers sans top.
I then moved on to the right side cabinet and started attaching the pieces.
A quick shot of the left and center cabinet sitting next to each other.
Right cabinet with dust collection box and cutouts for router and router fence bolts.
Attaching top to center cabinet after adding dust collection elbow for saw.
Adding wood edge banding to the cabinets.
All cabinets sitting next to each other waiting for attachment. If you notice the right side cabinet is backwards. I edge banded the wrong side and ended-up removing and flipping the top the correct direction.
Attaching the cabinets with 1/4” bolts. I didn’t have enough room to drill the holes in the top left cabinet so I had to remove the side. I should have clamped the sides together earlier and drilled the holes.
Attaching the bottom brace.
Workstations bolted together and wheels attached.
Workstation with table saw and drawers. The table saw will have to be raised about 1/2” to be even with the tops, which are just sitting there in this picture.
I attached the back and rolled it away for the evening. I’ll have to remove the one back piece to cut the dust collection holes for the router and downdraft table. I still need to trim, laminate, and attach the tops, as well as the door and drawer fronts.
A lot of work, but it’s starting to come together. It is solid as a rock and I was able to sit in the middle section without any flexing. So far, I am pleased.
11 comments so far
GaryK
home | projects | blog
8486 posts in 473 days
posted 149 days ago
That looks fantastic! Great!
Mark Shymanski
514 posts in 197 days
posted 149 days ago
An incredible cabinet. Thanks for the great photos.
-- ....next big purchase is wood for the next project, Mark
9086 posts in 307 days
posted 149 days ago
This is an outstanding piece of work. Your cabinet will markedly improve the functionality and usefulness of the table saw.
Well done!!!
TedM
1370 posts in 217 days
posted 149 days ago
It’s coming along just fine! I keep looking at my saw with its mishmash of undershelves, etc. and keep thinking of doing the same. Seeing this is bringing me closer of making the plunge.
SPalm
727 posts in 367 days
posted 149 days ago
That is great. That is going to help a lot.
Note to self: build more storage.
blackthumb
16 posts in 182 days
posted 149 days ago
Very interesting
Todd A. Clippinger
2536 posts in 584 days
posted 149 days ago
Great use of available space in a small shop! I love the progress photos. Anybody should be able to figure out the construction from that series of shots.
Mark D.
70 posts in 253 days
posted 149 days ago
I’ve not followed this series closely and it took till the tenth picture for me to realize I was seeing a real version of the sketchup model I posted a comment on a while back… ;-) Great construction photos. It looks like you overcame all the little set backs quite well. The mark of a craftsman :-) Lucky you discovered the upside down case prior to knocking out the side panel and drilling holes…
-- Looking for free wood working plans? Visit us at www.AwlFreePlans.com
Partridge
158 posts in 441 days
posted 149 days ago
now where is the stool going
-- Do it right the first time. Becuase fixing it is a wast of time.
gator9t9
282 posts in 189 days
posted 149 days ago
oh my .. you are a craftsman yes…..what a nice table. Great pix and oh wow ….good job …
I am never ceasing to be amazed at the quality of LumberJocks ..
thank you for posting
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
thetimberkid
1520 posts in 188 days
posted 149 days ago
Great job!
Thanks for the post
Callum
-- Look great, get your TTK merchandise now! http://www.printfection.com/thetimberkid/ Check out my site http://thetimberkid.blogspot.com/
