After seeing the neat job that MOT/ Tom did with his shooting board I was enticed to make one of my own.
I am in the middle of milling some wood for small boxes so I will needed something to handle these small gauge materials.
I am a pack rat and wood hoarder by genetic make up so when I dug through one of my precious piles of scrap I found an old poplar plywood shelf, a piece of arborite (Tom’s idea) and a piece of 3/4” fir flooring plywood.
The rest were off cuts of oak walnut etc that would have been firewood.
Once I milled the stops to dead flat and square the rest went fairly quickly.
You have to get the stop lined up with the shooting edge at or very near 90 degrees and the shooting edge should be almost perfect in length and vertical as possible.
The reason I split the stop in two pieces was to allow for an alignment should the need occur.
I can shim the walnut piece on either end to shift the workpiece to plumb.
Once the board was assembled I could use my plane to flush trim the stop block and align the guide edge up to the stop block. Tom was right about the arborite under the plane ,it really reduced the drag, I had to cut a 1/2” relief under the top board to let the arborite slip under for a good fit.
Next I tested with my low angle block plane. Not a really good one but it does the trick.
It cut the African black wood like a butter knife and gave me a nice sharp 90 degree angle.
Next I made the 45 degree attachment for lining up flat boards as per picture frames and box corners etc.
These have to be dead on so take your time if you are making one of these.
The final shot was a jig to get 45’s on the bevels . I have always had a problem with this cut and spent many moons sanding the wood until it was too short. I’m hoping this jig will eliminate a lot of that.![]()
The next step is to get some decent plane irons so Mr. Hock will be getting a call soon.
Here are references for the plans I used
Enjoy
12 comments so far
WayneC
home | projects | blog
5693 posts in 484 days
posted 149 days ago
Very nice Bob. Looks like a great addition. You will have to make a miter plane to go with it.
mot
4829 posts in 423 days
posted 149 days ago
Looks like a worthy beast!
7733 posts in 208 days
posted 149 days ago
This looks like a nice jig to add to your shop.
Thanks for sharing.
jcees
389 posts in 185 days
posted 149 days ago
Sweet! I’ve just made this one a keeper. Thanks.
I am assuming that arborite is a phenolic laminate product like Wilsonart or Formica?
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
1625 posts in 408 days
posted 149 days ago
jcees, you are right, forgive the parochail dialect. We are what they tell us we are.
I shall stay with “phenolic laminate product ” in future.
11418 posts in 787 days
posted 149 days ago
Looks nice a nice tool there Bob.
I would have thought that the bevel attachment would be higher to give you more support on the workpiece.
GaryK
8182 posts in 375 days
posted 149 days ago
Looks great Bob! I like the attachments.
Eric
491 posts in 170 days
posted 149 days ago
Very nice!
-- Eric at http://adventuresinwoodworking.com
Dorje
1692 posts in 383 days
posted 149 days ago
How did you ever function without it? I recently made one too…what a treat to have.
rikkor
6435 posts in 261 days
posted 149 days ago
Great shooting board.
-- Maplewood, MN
Tony
518 posts in 417 days
posted 149 days ago
NIce one Bob! – I still have not made one of these yet, I do not ever seem to need it – one day!
posted 149 days ago
Karson: ” I would have thought that the bevel attachment would be higher to give you more support on the workpiece.”
It can be modified to suit the occasion. I built this one for small boxes but making it taller is not too difficult.
