Here’s my take on an econo miter guage.
There’s quite a few out there and many costing a lot more than this one but this does the job for me so far.
If you feel you need a new miter guage as well this may not be the rignt one for you.
6 comments so far
Robb
home | projects | blog
324 posts in 421 days
posted 392 days ago
Thanks for sharing, Bob. I haven’t upgraded my stock miter gauge yet, so I appreciate your thoughts on this one. You’re right about not necessarily needing to get the most expensive one; it’s easy to get caught up in thinking you have to spend a fortune to get something that will be functional.
-- Robb
1953 posts in 509 days
posted 392 days ago
Hi Robb: I have always believed in ”critical mass” as a function of wood working.
By this I mean , you must have all the tools necessary to produce a project.
The second phase should be upgrading the first stage. <g>
There is much to be learned by starting out humbly.
Tony
573 posts in 518 days
posted 392 days ago
Thanks for the post -
I do not use the most expensive Miter Gauge either – but I do use the Osborne
EB-3 Miter Guide. It is not the most expensive, but I find it exteemly stong, acciurate and more importantly repeatable cuts. At just over a $100 – I wonder if its worth buying all the materials to make one – apart from the fun and experience.
posted 392 days ago
Hi Tony:
I can see some similarities between the Osborne guide and this one.
That follower riding the miter slot has me fascinated.
What happens when you get a wide board that reaches the edge of your table saw?
The video showed several cuts for miters shich seem dependant on the stop guide for accuracy rther than the triangle effect.
Still and all a good looking system.
Is is difficult to store?
Tony
posted 391 days ago
Hi Bob
If I have to cross cut very long boards, then I use a Miter/Chop or Radial Arm Saw, If I have to cut panels, I use a Panel jig or a Circular saw. I have used the Osborn for the full 42” without problems, I just find it easier to use another saw for long boards (especially heavy wood such as Oak and Maple)
What I like about the Osborne is the use of the bar for setting the angle. Not only does it add stability to keeping the angle, it also gives some rigity to the gague. (triangle are remarkably strong).
The stop guide only adjusts the length of cut – I used the Osborne for making the Latice boards – any errors with so many joints definitely show up.
posted 391 days ago
Tony, you and I work a lot alike.
I recognized that Osborne set up being superior to most guides in that it makes the guide rigid where the others depend on the miter slot for stability.
I use a crosscut sled on my table saw for most short straight cuts and to be truthful, I have not needed a mitered cut of any extent since I did my office in tongue and groove clear cedar. Even then I used the miter saw (CMS) with extensions.
Cheers
