Tool Cabinet #2: Respect to all cabinet builders...
Blog entry by Sgt_Lobo posted 245 days ago 491 reads 1 time favorited 14 comments Add to Favorites
« Part 1: Requesting input on my plans... Part 2 of Tool Cabinet series no next part
For all of you cabinet builders on this site, my hat is off to you! I never fully realized the work that is involved in making a cabinet and how even the smallest mistakes can compound so very quickly…
Right before Christmas I posted this blog asking for input on plans for a tool cabinet. Well, I took all the advice I received and have been furiously building over the holidays.
Here is where I stand—I have completed the actual “cabinet” portion of the project. The project isn’t really close to complete however, if you look at my plans from my last blog, there is still a lot for me to do. But, I wanted to get the base cabinet done so I could start utilizing it and free up some workbench space in my ever so cramped garage. I am pleased with the results so far and have already loaded this sucker up. It is working as I envisioned, and I can now see the entire top of my bench for the first time in many months…
Below is a picture story of the trials and tribulations that this project has bestowed upon me. (Pictures will be cropped from this site, you can click on them to see the full picture.) I ran into one problem (err, learning experience) after another. Most I was able to overcome, some I just covered up as best I could. The end result though is a new, extremely useful addition to my workshop.
I didn’t start taking pictures until the initial cabinet glue-up. In this first picture you can see the basic cabinet box being assembled. I went with 3/4” cabinet grade oak ply for this part.
Cabinet Box Assembly
In this picture you can see how I re-enforced the inside corners with blocks. This helped during glue-up and will also hopefully help prevent some of the twisting forces this cabinet will be subject to.
Blocked Corners
Here I decided to attach the wheels early on so I could move the project around and out of the way as I built it. I reinforced the bottom with 2×4 studs to attach the wheels to.
Wheels
Reinforcing the cabinet box and trying my damnest to ensure it is all square. I also added the apron to the bottom to cover most of wheels. At this point I also used oak veneer on all the exposed edges of the plywood.
Here is a picture of me making sure all my drawers fit. Obviously this is a huge gap in the pictures. This is because I was spending so much time cussing, banging my head against the wall, and kicking my power tools that I didn’t have time to devote to the picture taking. These drawers were hell on earth to get right, and I’m still not even close to right (as you will see in later pictures). I screwed and unscrewed, and then screwed again all of the drawer slides so many times trying to get everything to line up, unsuccessfully. The best I can tell, the cabinet box wasn’t quite square, or my drawers weren’t very square, or probably a combination of the two.
Freakin Drawers!!!
Here I have all the drawer fronts attached. Thank goodness for drawer fronts, as they can cover a multitude of mistakes. I had to shim 4 out of my 5 drawers on one side or the other to get the drawer fronts to sit flush on the cabinet box. 2 of my shims were 1/2” thick if that gives you any idea of how out of whack my drawers were. The drawer fronts were made from ceder and I used and ogee bit around the edges. I chose the ceder for the drawer fronts just to add some visual interest to the cabinet…
Drawer Fronts
Finally, the finished cabinet. I used minwax polyshades (polyurethane mixed with pecan stain) for all the oak. I used amber tinted shellac for the ceder drawer fronts.
Front of finished cabinet
Here is a picture of the cabinet fully functional and in use.
Caninet in use
And finally, a picture of my biggest “oops”. This is one of the shims I was talking about between the drawer and the front.
Oops
And that is where I am at for now. Again, if you look at my previous blog, you will see that I still have a whole lot of work to do before this project is finished. But, at lease the hardest part is done and I have something I can use right now!
A couple of lessons I learned so far:
1. I am not a cabinet maker, nor could I even play one on TV.
2. If things are even slightly out of square, it all adds up.
3. Not square drawers will never fit perfectly in a not square cabinet no matter how many times you move the slides.
4. Kicking your table saw does nothing except possibly spraining your big toe. The table saw doesn’t feel a thing…
-- Sgt_Lobo -- Montgomery, AL
View Sgt_Lobo's profile
Sgt_Lobo
87 posts in 310 days
View Blog Archive
14 comments so far
View GaryK's profile
GaryK
8411 posts in 440 days
posted 244 days ago
You are now a cabinet maker whether you think so or not.
Good job.
View David's profile
David
1812 posts in 590 days
posted 244 days ago
Sarge -
Excellent! I need to fly you to Portland to help me build the cabinet for the workbench I am building. I may need to ask for advice! I like how you do a “hot wash” of “lessons learned” . . . brings back very fond memories of my time in the Navy!
David
3989 posts in 670 days
posted 244 days ago
Sarge, the cabinet really looks great. One suggestion I would give you: Building a seperate face frame and attaching it to the cabinet adds a lot of rigidity to the final project, especially if you added mullions between the drawers.
View Zuki's profile
Zuki
823 posts in 529 days
posted 244 days ago
I gotta say Sgt_Lobo . . . that is one mighty fine oops. Did you ever figure out how that happened?
The cabinet did turn out nice though. I liked how you added the aprons to cover the wheels.
8584 posts in 273 days
posted 244 days ago
Actually it is pretty good for a first cabinet. Mine (cherry wall corner cabinet) was so bad that I relegated it to a plant stand on the deck. Overall I think it is pretty good especially since it is a tool cabinet. Norm can make his shop cabinets look like first class furniture but in my opinion functional cabinets in the shop work just as well.
Thanks for sharing. I look forward to seeing your next cabinet. This is one skill that does improve with practice.
View mrtrim's profile
mrtrim
1524 posts in 332 days
posted 244 days ago
i think it came out fine . it works right, so that alone makes it a success . well done
-- if you aint the lead dog the scenery never changes
View Tomcat1066's profile
Tomcat1066
556 posts in 247 days
posted 244 days ago
I’m no expert, but it looks good to me!
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
12736 posts in 852 days
posted 244 days ago
That a large skew on the drawer front. But the cabinet looks great. Good job.
View motthunter's profile
motthunter
1172 posts in 250 days
posted 244 days ago
making cabinets is easy.. making good ones takes skills. This is nice!
-- making sawdust....
View Jiri Parkman's profile
Jiri Parkman
552 posts in 264 days
posted 244 days ago
That is very nice cabinet.
-- Jiri
View Mario's profile
Mario
697 posts in 503 days
posted 244 days ago
Thank you for posting this, I am one who also struggles at times to make things work and feel like I am the only other one who messes things up. It is very nice to see such truthfulness. As you can see from my profile I have not posted a project yet and part is due to the work that I am doing on my shop and part is because I do not feel that they are good enough yet. On a side not I put the last 20 sheets of OSB on the ceiling of my shop over the holiday break while My son was home from college and will be posting in a blog this week.
-- Hope Never fails
View rikkor's profile
rikkor
7201 posts in 326 days
posted 243 days ago
That is a nice cabinet. It is functional, but it looks almost too nice for a shop. Good job.
-- Maplewood, MN
11656 posts in 612 days
posted 243 days ago
impressive!
View gene's profile
gene
2132 posts in 335 days
posted 220 days ago
Hay! Sarge, You did a nice job with this !
God bless
-- Gene, a Christian in Virginia
Bookmark And Share This Page
